Mitsubishi DLP screen has dots? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-08-2013, 12:10 PM - Thread Starter
DemonGT's Avatar
A few months ago i noticed a single white dot in the middle of my screen and since then they have been spreading. Some are white some are black. Dose anyone know what would cause this?
pics
DemonGT is offline
post #2 of 12 Old 07-08-2013, 12:11 PM - Thread Starter
DemonGT's Avatar
Forgot to add the model
WD-73733
DemonGT is offline
post #3 of 12 Old 07-08-2013, 03:25 PM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
A somewhat common problem with any DLP, irrespective of model. The DMD (DLP chip) is beginning to fail. What you're seeing are a scattershot of the DMD's micromirrors becoming stuck, as opposed to being normally capable of moving freely throughout their range.
Various factors, including heat and electrical effects are responsible for this failure.
You can:
Call Mitsubishi and complain.
If they don't help you you can:
Replace the whole optical engine (fairly easy but somewhat expensive)
OR
Replace just the DMD chip IN the optical engine. This is a bit more difficult, but is the least expensive option. You might also find a technician in your area who can do either of the above for you.
Soulburner likes this.
taichi4 is offline
post #4 of 12 Old 07-10-2013, 09:49 AM - Thread Starter
DemonGT's Avatar
How expensive is a DMD chip? Are there any write up on how to change one out?
DemonGT is offline
post #5 of 12 Old 07-10-2013, 01:45 PM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
You need to do some searching on this forum, as there are many on AVS who have replaced their optical blocks and their DMDs. There's a lot of details there, but you need to take the time to search. Let your fingers do the work.
Just browsing the net I came up with these:
https://www.youtube.com/watch?v=eyAykjZ3zs4
http://www.fixyourdlp.com/2012/05/15/mitsubishi-white-death-can-be-solved-for-under-200/
taichi4 is offline
post #6 of 12 Old 07-11-2013, 03:13 PM
Ron Jones's Avatar
Quoted: 903 Post(s)
Liked: 908
Posted in another tread:
Mitsubishi is replacing these DMD IC chips nationwide under an unannounced kind of recall for model #’s WD60C9, WD73733, WD57734, WDY657, WD73734, WD65735, WD60735, WD65C9, WD73840, WD65833, WD65733, WD73735, WD73833, WD57733, WD65734 and others. Call them @ 800-332-2119 and give them your model, serial # and date of purchase, tell them you have the white spots, they will set up a workorder with a local Mitsubishi servicer to come to your home and replace the DMD chip. Mitsubishi will supply the part (part # 276P595010) for free, but you must pay $200 in labor. BUT…if you ask for Shantell Hebert when you call Mitsubishi, and really push the issue, she may also pay half of the $200 labor fee.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #7 of 12 Old 07-11-2013, 05:18 PM
taichi4's Avatar
Quoted: 330 Post(s)
Liked: 156
That's great info for the OP. I suggested calling Mits as the first option, but it's invaluable to know that an unofficial replacement program exists.
taichi4 is offline
post #8 of 12 Old 07-17-2013, 12:25 PM - Thread Starter
DemonGT's Avatar
My TV is to old and i would have to pay more to have there Tech install a new chip then what a new chip alone
would cost me. I looked up how to change the chip and it looks pretty easy and straight forward.
I plan to upgrade to a LED tv anyway, i think ill order the new chip and do the install my self and then sell the tv.
I have grown to dislike the amount of heat this DLP puts off and the amount of energy it uses. I would actually
DemonGT is offline
post #9 of 12 Old 07-29-2013, 07:22 PM - Thread Starter
DemonGT's Avatar
TV shut off and getting red blinking light?
Dose anyone know if the DMD/DLP chip can go completely bad?
DemonGT is offline
post #10 of 12 Old 07-30-2013, 07:49 AM
Augerhandle's Avatar
Quoted: 847 Post(s)
Liked: 774
Your lamp is out. Replace your lamp.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #11 of 12 Old 08-29-2013, 12:26 PM - Thread Starter
DemonGT's Avatar
Lamp replaced, TV working again.
i bought a new DMD chip, going to install today. going to sell this DLP, going to make the switch to LED.
DemonGT is offline
post #12 of 12 Old 05-26-2014, 08:32 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
LCD TVs are a downgrade in picture quality from DLP. How did the switch work out for you?
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
Soulburner is offline
Reply Rear Projection Units
