52hm95 has solid red light with 3 green blinks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-24-2013, 11:32 AM - Thread Starter
feb1003's Avatar
I was hoping some one could give some advise,, 52HM95 TOSHIBA , when I plug the power cord, I get red light come on then off, a fan by digital board is running but nothing else, when I hit the power button, red light comes on , but no other fans come on or the color wheel makes sound, then I get on the timer indicator green light flashes 3 times, does this about 4 times then stops blinking red light goes off, according to some web sites, suppose to be a temperature sensor above the lamp, I check it ,it good, I also check 2 fuses on power supply board ok, the lamp is brand new , any advise well be of greatly appreciate
feb1003 is offline
Reply Rear Projection Units
