Mitsubishi wd-65833 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-02-2013, 01:55 PM - Thread Starter
Frank5151's Avatar
This site has helped me before and I'm hoping it will again.  I have a 6 yr old wd-65833 that I've replaced two bulbs in, a ballast, and a power supply board.  It has started doing something really odd.  When I go to turn it on it doesn't recognize any remotes (directv or OEM),  I turn it on from the front panel and the on screen volume indicator shows 00 and the remotes do nothing.  If I hit the reset button or unplug it, and turn it back on from the front panel it then sees the remotes and the volume can be adjusted.  Could that be a logic board problem?
Frank5151 is offline
Reply Rear Projection Units
