Sony KDS-55A2000 tunes OTA digital channel audio, but not video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-23-2013, 04:43 PM - Thread Starter
jottorice's Avatar
I'm trying to tune OTA digital channels on my KDS-55A2000 for the first time, but I'm finding that only the audio of the channels is coming through. On all digital channels, the video is either completely black, or is a mess of shifting blocks (see attached image). I don't *think* the signal strength is the issue, because the channel info is claiming 95% signal strength, and I've tried three different antennas with exactly the same result (admittedly, indoor ones - one amplified). So I'm tending to think that my tuner might be broken. Analog (NTSC) channels *do* tune fine, with audio and video. The stations I'm trying to tune are less than 6 miles away, but I probably don't have a very clear line of sight to them. Unfortunately, I don't have another TV that I could compare reception with.
I think the tuner boards for these TV's are <$25 on ShopJimmy, so if it does turn out to that at fault, it might be a simple fix. But does that sound like the issue to you knowledgeable folks?
jottorice is offline
post #2 of 2 Old 08-10-2014, 11:46 AM - Thread Starter
jottorice's Avatar
Originally Posted by jottorice View Post
I'm trying to tune OTA digital channels on my KDS-55A2000 for the first time, but I'm finding that only the audio of the channels is coming through. On all digital channels, the video is either completely black, or is a mess of shifting blocks (see attached image). I don't *think* the signal strength is the issue, because the channel info is claiming 95% signal strength, and I've tried three different antennas with exactly the same result (admittedly, indoor ones - one amplified). So I'm tending to think that my tuner might be broken. Analog (NTSC) channels *do* tune fine, with audio and video. The stations I'm trying to tune are less than 6 miles away, but I probably don't have a very clear line of sight to them. Unfortunately, I don't have another TV that I could compare reception with.<br><br>
I think the tuner boards for these TV's are &lt;$25 on ShopJimmy, so if it does turn out to that at fault, it might be a simple fix. But does that sound like the issue to you knowledgeable folks?<br><br>
Thanks!<br><br><a class="H-lightbox-open" href="http://www.avsforum.com/content/type/61/id/316531/"><img alt="" class="lightbox-enabled" data-id="316531" data-type="61" src="http://www.avsforum.com/content/type/61/id/316531/width/500/height/1000/flags/LL" style="; width: 500px; height: 375px"></a>
This is probably too late a reply for you, but I had a very similar-looking problem recently, and it turned out to be the QM board.
Reply Rear Projection Units
Sony Kds 55a2000 Kds55a2000 Lamp With Housing Xl5200
