Anyone Have Picture Problems after Mitsubishi DMD Chip Replacement? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 03-21-2014, 03:54 PM - Thread Starter
Augerhandle's Avatar
Quoted: 857 Post(s)
Liked: 775
I recently had my DMD chip replaced by Mitsubishi and immediately noticed a "color and sharpness bug" similar to the one found in the 2011 sets when new (see http://www.avsforum.com/t/1397654/mi...1-dlp-sets-fix).
My TV is Model WD-65835
Has anyone with a new DMD noticed the jaggedness of lines and improper pixel colors shown in these pics?  I'm trying to figure out if it's something the installer did, or if (as in the 2011 models) the chip algorithms are different for the new chip.  It's really obvious with red objects and text. These are closeup details of course, the picture looks blurry and low resolution from a distance.
 EDIT: MGM logo on Blu-ray disc
  OTA/ Cable
 EDIT: TV Menu
ID:	374554 (click to enlarge)
 EDIT: PS3 Youtube logo
ID:	374562 (click to enlarge)
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #2 of 23 Old 04-18-2014, 03:12 AM
jbzngowest's Avatar
I had two replacements and didn't have this issue with mine. I hope you get this resolved soon.
jbzngowest is offline
post #3 of 23 Old 10-28-2014, 07:39 AM
wootanga's Avatar
Were you able to get this fixed? I'm about to replace my DLP chip and I was wondering what model TV was being referred to.
Woo
wootanga is offline
post #4 of 23 Old 10-29-2014, 12:16 AM - Thread Starter
Quoted: 857 Post(s)
Liked: 775
Woo
No, unfortunately.
Since I posted, they replaced my light engine and updated the TV to the latest firmware, but it didn't fix the problem. I appreciated all they did, but they just couldn't fix it. They finally claimed the set should be viewed from 12 feet away, so there was no problem and refused to go any further! Whatever. If there was no problem, why did I call them? Why did they replace the light engine and update the firmware? Hmmmm.
My TV is Model WD-65835. Even at 12 ft away, one can tell that the picture is not right. My other set is a WD-73837, and the difference in clarity is obvious. I guess they just gave up. All they have left at Mitsubishi are a bunch of "parts changers".
With all the chip replacements being done I was hoping to build some support to get Mitsubishi to fix the problem just as they finally did for the 2011 models in that thread that I posted. Nobody seemed to notice a difference, so no luck there.
It's almost as if my TV is now 720P, with diagonals very jagged, and pixels along sharp edges being painted the wrong color, as in the photos I attached. Turning OFF SmoothPicture helps slightly, but it's still really bad. I still think the SmoothPicture algorithms in the TV's firmware are incorrect for the newer chips, but the Warranty guy claimed that there were no engineers left working there that could write new firmware.
post #5 of 23 Old 10-29-2014, 07:09 AM
garciab's Avatar
Quoted: 149 Post(s)
Liked: 69
This is unfortunate and alarming to me. I have a 65735 that needs a new dmd chip, and now I'm afraid of ending up with the same problem. I will let you know if I notice a change in picture quality after I do the repair. So far, only two stuck white pixels so it's not too distracting.
bg
garciab is online now
post #6 of 23 Old 11-03-2014, 09:25 PM
Quoted: 16 Post(s)
Liked: 6
I'm replacing my xx735's dmd soon, now you have me worried
yuri53122 is offline
post #7 of 23 Old 11-04-2014, 07:01 AM
Daniel Murray's Avatar
When mine was replaced I was more than happy. My pitcher was much more colorful and crisp. Plus they gave me a one year warranty.
So I say take a deep breath and see what happens. If you do get a bad chip they will replace it for you. Do not let them leave if you are not happy. The can always a just the the setting to make it right.
When the service people came out for me the even cleaned my mirror
Daniel Murray is offline
post #8 of 23 Old 11-06-2014, 03:22 PM - Thread Starter
Quoted: 857 Post(s)
Liked: 775
Well, they replaced the whole light engine (which had its own chip) trying to solve the problem, so it wasn't a defect in the new chip.
post #9 of 23 Old 11-17-2014, 01:00 AM
jevans64's Avatar
Quoted: 194 Post(s)
Liked: 149
Have you tried adjusting Sharpness while on one of the internal patterns instead of using broadcast images? The patterns can be accessed by pressing MENU and entering 2 4 5 7. I believe that same service menu will have better sharpness adjustment options than the regular menu.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #10 of 23 Old 11-17-2014, 01:51 PM - Thread Starter
Quoted: 857 Post(s)
Liked: 775
I have calibrated many Mitsubishi DLPs and I am very familiar with the Service Menus. The internal menus and patterns are just as jagged as the other sources, and no adjustment fixes it.
Thanks for your advice, though.
post #11 of 23 Old 11-17-2014, 03:58 PM
jevans64's Avatar
Quoted: 194 Post(s)
Liked: 149
If the entire light engine was replaced, then it could only be the mirror ( which they cleaned ), the screen, or your source. I replaced the DMD in my 2007 xx833 65" set ( which I no longer have ) 18 months ago and everything was fine except for going back in and adjusting the geometry. My new DLP is a 2011 73840 which I ordered a spare DMD and bare lamp and lamp + housing for.
It looks like something in your signal path is pushing sharpness hard. I assume you checked different sources and tried different firmware.
jevans64 is offline
post #12 of 23 Old 11-17-2014, 08:06 PM - Thread Starter
Quoted: 857 Post(s)
Liked: 775
[snip] ...It looks like something in your signal path is pushing sharpness hard. I assume you checked different sources and tried different firmware.
Don't assume, read the whole thread. It's only 10 posts long.
post #13 of 23 Old 11-18-2014, 08:44 PM
jevans64's Avatar
Quoted: 194 Post(s)
Liked: 149
I DID go through the thread before my last post. Nowhere do you mention whether you tried difference sources or whether it persists while watching a Blu-Ray, etc. I only have the broadcast pictures you posted to go by. Why don't you turn on Checkerboard like that other thread suggests before the 2011 sets ( the year I have ) got the firmware update to fix it?
I do agree that Mitsubishi skimped somewhere because the picture looked better on my 2007 set.
jevans64 is offline
post #14 of 23 Old 11-19-2014, 12:31 PM - Thread Starter
Quoted: 857 Post(s)
Liked: 775
Sorry, it was this post
...The internal menus and patterns are just as jagged as the other sources...
and I guess I should have labeled the photos. The first one is Blu-ray, and I have edited the first post, adding captions and two more photos.
I have tried checkerboard. My DLP Link can't be switched off, so it isn't a viable solution. I suspect people haven't noticed the problem with the new chip, just as people in that 2011 model thread took a lot of convincing before they would even look for the issue.
My WD-65835 picture has always been noticeably better (before the chip replacement) than a later model WD-73837 I watch in another room, but not any more.
I like your model. I calibrated a friend's WD-73840, and was very impressed with the picture quality. Much better I thought, than either of mine.
post #15 of 23 Old 11-20-2014, 06:33 AM - Thread Starter
Quoted: 857 Post(s)
Liked: 775
Take a look at your Menu Screen, especially diagonal lines
Attachment 374554 (click to view)
post #16 of 23 Old 01-10-2015, 01:15 PM
garciab's Avatar
Quoted: 149 Post(s)
Liked: 69
Did you notice this from normal viewing distance? Just replaced the chip in my wd-65735, and pic looks great and normal from my sitting position. I won't bother getting up close and personal with it because I will be replacing it in a month or two. Unless I am blown away by the 3D kit that I just bought for it, just to play with for a while. From my 12ft seating distance, everything looks nice and sharp. Happy camper here!
bg
post #17 of 23 Old 01-10-2015, 02:05 PM
Good to hear.
post #18 of 23 Old 01-10-2015, 07:42 PM - Thread Starter
Quoted: 857 Post(s)
Liked: 775
Yes, I noticed something was off from normal viewing distance. I had to get up close to find out why it was off.
post #19 of 23 Old 01-10-2015, 09:18 PM
barrelbelly's Avatar
Quoted: 337 Post(s)
Liked: 432
IMO the PQ looks blurry and low resolution because it is. those images looks like the video processor itself is blown. Does it look the same in HDMI, component and composite? If so...that may be your problem. The display may be putting out 480i or lower on all settings.
barrelbelly is offline
post #20 of 23 Old 01-11-2015, 10:12 AM
garciab's Avatar
Quoted: 149 Post(s)
Liked: 69
Well curiosity got the best of me so I took a closer look. I compared my display of the menu to your pics of the same. I don't have all the fuzziness around every letter in 'video'. Letter 'I' is perfectly sharp. Only diagonals have stairstepping, but they too are sharp edged, so I am guessing it's a low-rez graphic.
post #21 of 23 Old 10-04-2016, 05:18 AM
jebbj's Avatar
Mitsubishi WD82837 Repaired DMD
This television which was purchased in September 2009 began to show "bright stars" on the screen in May of this year. The condition began to worsen with "bright stars" forming a small constellation whenever the television was played. We contacted the store where is was purchased "The Big Screen Store" and the salesman was very informative sharing with me that the problem was endemic with the dlp lighting processing chip from Texas Instruments. Not only with Mitsubishi but Samsung, Toshiba and other rear projection sets with this chip installed. He gave me a customer service number for Mitsubishi and informed me they might be able to help with the problem. After contacting Mitsubishi they asked for my receipt to verify my purchase date which I faxed immediately. Two days later I received a call from a local repair shop offering to repair the chip with a new chip from Mitsubishi the same day! The repair took all of about twenty minutes and a labor fee of $200.00 (which was fairly HIGH) but worth the price for the speedy repair. This was absolutely wonderful considering the fact that this television was over seven years of age and with 3300 hours of time on the bulb (which is still BRIGHT) because of the standard setting lamp mode, space for air movement and frequent vacuuming. If you have a similar problem call Mitsubishi Consumer Service they might be able to help. The newer 4K sets are just not ready for PRIME TIME until the content is on local channels and not just movie streaming.
jebbj is offline
post #22 of 23 Old 10-14-2016, 11:15 AM
Jetmeck's Avatar
Quoted: 26 Post(s)
Replaced DMD chip on neighbors Mits.....no issues with sharpness after that. Something in the settings is off or the installer screwed up.
Jetmeck is offline
post #23 of 23 Old 11-18-2016, 10:13 AM
Jetmeck's Avatar
Quoted: 26 Post(s)
Cool
I agree with you on 4K not ready for prime time. I have looked at them side by side and there is no discernable difference until about 2 foot.
As far as your repair yes MITS buys the part because they know their DMD chips were defective but then you have to pay up for the labor.
Mits should pay the labor for a defective part, I tried. In the end the neighbor bought the part and I put it in for free.
Jetmeck is offline
Reply Rear Projection Units
