How to factory reset in KDS-R60XBR1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-30-2014, 08:12 PM - Thread Starter
phuc's Avatar
Hi guys, I owned a Sony KDS-R60XBR1 2005. Few weeks ago, I went to the service menu and trying to reset the color pattern to normal (the blue kinda bit far off). Somehow, whenever I try to turn the TV on, and it always show the pattern generator criss cross each other. Moreover, I know how to reset the default settings like the channel and stuff, but I need the factory reset to remove the pattern that it's always show up in the background. Plus, every others works fine like, volume, lamp, color, etc. However, all I need to know is how to remove the pattern when I turn my TV on (This pattern usually comes up when in Service Menu, but I think I messed it up somehow)? Is there any suggested? What should I do? Please help me with this, I'm really appreciate you guys reading this. If there is a link, please give it to me below here. Thank you.
-Phuc
phuc is offline
post #2 of 2 Old 05-05-2014, 09:00 PM - Thread Starter
phuc's Avatar
display+5+vol+power+8+enter = Display panel the pattern generator criss cross
phuc is offline
Reply Rear Projection Units
