replaced bulb. not working Sony 55-E2000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-09-2014, 02:56 PM - Thread Starter
Jessika's Avatar
Hi there,
My Sony 55-E2000 gave me a warning the bulb was going out. when it finally took a nose dive we bought a new bulb for it and replaced.
When I turn TV on It sounds like its gonna turn on then gives me 3 red blinking lights (door not closed/bulb not in) but it is in.
I opened and closed the door and reset the bulb over n over again, still 3 blinking red lights and then nothing.
I noticed a SPRING inside the compartment where the bulb goes.. is this important? whats it go to? I lost the friggin spring.. kids played with it..and lost it
can someone help me out? dont want to buy a new one! Hubby is Very distraught.. NO BIG SCREEN! LOL
THANX A BUNCH.
Jessika is offline
post #2 of 2 Old 04-09-2014, 05:51 PM
ChuckF.'s Avatar
Originally Posted by Jessika View Post
Hi there,
THANX A BUNCH.
There are two safety devices involving the lamp. One is a tiny switch that senses when the lamp is fully inserted and locked in place. The second is another tiny switch that senses when the lamp outer door is in place. Both switches are in the main body of the tv, and are operated by a plastic or metal part that is part of the lamp assembly in the first case, and the outer door in the second case.
Remove the door and lamp. Find both switches. You will see them behind holes in the plastic. They are microswitches, very tiny pushbutton switches that make a distinct click when operated. If I remember correctly, the levers on the switches are bright blue. Find the holes, reach in with a piece of plastic and click the switches to confirm you have found them.
In the first case, a part of the lamp assembly presses the switch when the lamp is fully inserted and locked. Figure out what part that is and why it is or isn't doing its job.
In the second case, a part of the outer door presses the switch when the door is properly closed. Figure out what part that is and why it is or isn't doing its job.
Don't recall what the spring is for, it's possible that it is part of what operates the switch.
ChuckF. is offline
Reply Rear Projection Units
