Mitsu WD73740 Strange Streaks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 06-08-2014, 10:02 PM - Thread Starter
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
Mitsu WD73740 DLP.
Just today, I notice these strange streaks on my screen. I'm fairly certain they weren't there yesterday. Any idea what this might be?
I cleaned the mirror and the back of the screen. I also tried a different lamp but these streaks did not change.
Upper left:
Lower right, which also shows a small smudge that just showed up as well:
And full screen:
Alan P is offline
post #2 of 11 Old 06-09-2014, 12:31 PM - Thread Starter
Alan P's Avatar
Liked: 3324
BTW, pay no attention to the vignetting (dark corners and edges), that must be introduced by my camera because it doesn't look that way in person.
Alan P is offline
post #3 of 11 Old 06-09-2014, 01:36 PM - Thread Starter
Alan P's Avatar
Liked: 3324
OK, my buddy at work just made me feel stupid....I didn't try a different input on the TV, nor did I try bypassing my AVR or a different HDMI cable. redface.gif
Will try all that tonight and report back! Hopefully it's just the input or cable....hope it's NOT my AVR. eek.gif
Alan P is offline
post #4 of 11 Old 06-10-2014, 08:21 AM - Thread Starter
Alan P's Avatar
Liked: 3324
So....last night, after trying bypassing my AVR and trying different inputs on the TV...and trying a different HDMI cable, I was about to declare defeat.
When I say in the OP that I "cleaned the mirror" I should have said "dusted"....last night I actually cleaned the mirror (removed the screen and really cleaned it) and the streaks have gone away. My mirror was really dirty....like unbelievably dirty. It's strange how that pattern of streaks formed though....must have to do with the airflow inside the TV.
Anyways, I'm now a happy camper! TV looks brand new again!
Not sure why I thought the streaks popped up overnight when obviously it was a progressive thing. Just took awhile for me to notice it I guess....then once you see it, you can't un-see it kinda thing. smile.gif
Alan P is offline
post #5 of 11 Old 06-10-2014, 08:33 AM
smokozuna's Avatar
Quoted: 174 Post(s)
Liked: 85
wow congrats on fixing the streaks, i just picked up a 73734 and was wondering if you could link me to a tutorial of how you performed your cleaning. because i just acquired my tv i dont know how old the lamp is, i am considering replacing it and was also thinking of pulling out the light engine for an inspection and cleaning if it needs it.
smokozuna is offline
post #6 of 11 Old 06-10-2014, 10:21 AM - Thread Starter
Alan P's Avatar
Liked: 3324
I couldn't find any tutorials on how to remove the screen so I just started pulling screws 'til it came loose. eek.gif
It was easy, really. There are a bunch of screws on the back of the frame marked with arrows, then 2 screws hidden under caps in the front bottom of the frame. I recommend having a helper for removal and reinstall of the screen though. wink.gif
Once you have all the screws out, there aren't any wires or anything to worry about. The screen (and frame) just come straight off.
Oh, and make sure you have someone to hold the screen in place before you remove the final two screws on top.
Alan P is offline
post #7 of 11 Old 06-10-2014, 10:42 AM
smokozuna's Avatar
Quoted: 174 Post(s)
Liked: 85
i understand now you went through the front. i am debating whether or not to pull the optical engine from the rear to have a look at how clean everything is. i have no problems with my set at all i just wanted to do it out of curiosity and while there clean what can be cleaned and install a new Philips lamp. maybe i should just leave it alone seeing as i have no problems.
post #8 of 11 Old 06-10-2014, 11:12 AM
lujan's Avatar
Quoted: 1917 Post(s)
Liked: 753
Thanks, can you post any pictures of the screws, position, etc. so that it will be easier when we have to do this?
lujan
132 Ultra HD
824 HD
19 HD DVD
5 SD
lujan is offline
post #9 of 11 Old 06-10-2014, 12:29 PM - Thread Starter
Alan P's Avatar
Liked: 3324
Here's a quick and dirty pic I pulled off of Google.
These locations are only approximate. The red dots are where the screws are in the back of the frame, the two green dots are the screws in the front that are covered.
Alan P is offline
post #10 of 11 Old 06-10-2014, 12:29 PM - Thread Starter
Alan P's Avatar
Liked: 3324
I don't know if I would pull the light engine....just take the screen off and clean the lens and mirror and you should be good to go.
Alan P is offline
post #11 of 11 Old 06-16-2014, 07:09 AM
smokozuna's Avatar
Quoted: 174 Post(s)
Liked: 85
thank you for making this thread. yesterday my son and i pulled the light engine and cleaned all the mirrors and optics and pulled the screen and cleaned the mirror and chassis internals. the set is noticeably brighter and looks great.
Reply Rear Projection Units
