Sony SXRD KDS 60A6000 - 5 blinks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-20-2014, 03:04 PM - Thread Starter
Liked: 0
Hello,
I have a friend who has a Sony SXRD KDS 60A6000 which is giving the 5 red blinks when powering it on.
I have tried the following:
1. Verified Fan is running
2. Replaced Ballast
3. Replaced Bulb/housing
4. Unplugged unit, held power for 30 seconds, left unplugged for 15 minutes
5. Disconnected / reconnected all connectors around Power block
6. Powered unit back on - still getting the 5 red blinks
7. I am getting 119V AC at the outlet, and where the cord connects at the G board
8. I am getting less the .1V on the output from the G board to the Ballast
9. I pulled the fuse next to the power cord on the G board and verified continuity with Ohmmeter showing 0.00Ohms
Would the lack of Voltage drop at the ballast connector indicate a bad G board, or is there a sensor that would indicate the Ballast is bad that would cause the board not to send power to the ballast?
Any suggestions on what to try next?
Name:	sony sxrd kds-60a2000 G board.jpg
pacmanb is offline
post #2 of 7 Old 08-20-2014, 05:23 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
Is the model number actually kds60a3000?
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #3 of 7 Old 08-20-2014, 06:10 PM - Thread Starter
Liked: 0
It is the KDS-60A2000
pacmanb is offline
post #4 of 7 Old 08-20-2014, 06:14 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
Ok. Where did you buy the lamp and how much did it cost?
post #5 of 7 Old 08-20-2014, 07:05 PM - Thread Starter
Liked: 0
pacmanb is offline
post #6 of 7 Old 08-20-2014, 07:42 PM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
Cheap lamps are the number one mistake that people make. They just don't work. If you are lucky enough to get it to fire then it might last a few hours, days, weeks. Strongly suggest that you buy an original lamp from Sony or http://www.dlplampsource.com/
Where did you get the ballast?
Are you sure about the voltage from the G board to the ballast? How are you measuring it? The meter needs to be set to DC volts. You should get 400V.
Can you measure the other voltages on the G board connector CN6902
post #7 of 7 Old 08-20-2014, 08:00 PM
Bluescale's Avatar
Quoted: 736 Post(s)
Liked: 298
Originally Posted by pacmanb View Post
Buy the proper Philips bulb:
http://www.amazon.com/Philips-Lighti.../ref=pd_cp_e_2
I gave the 60A3000 to my in-laws, and when the bulb went out, I got the generic. It worked for about a week, and then went out. Bought the $85 bulb, and it's doing great.
This guy had a similar experience as you:
http://www.justanswer.com/tv-repair/...00-friend.html
Bluescale is offline
Reply Rear Projection Units
