Mitsubishi WD 52527 smudges - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-21-2014, 02:55 PM - Thread Starter
Liked: 0
Hello,
Last weekend i cleaned the mirror and lens on my TV and my picture improved greatly. My lamp is fading, but it's ok for now. What I'm left with is a picture that has what i describe as smudging in it. It's most notable with a white background or a green background (while watching golf it can drive you nuts) I've scoured this site and others, but can't seem to find a similar issue and how to resolve it. Any help is appreciated.
thanks,
Craig
cpollard is offline
post #2 of 4 Old 08-21-2014, 06:30 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Internal components deep inside Optical Engine are dirty or defective. Could be the LCD panels or optical filters. Tv repair shop would pull out and replace the Optical Engine with either a new one or send off for refurbish.
>> click here for optical engine refurb << $230
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #3 of 4 Old 08-22-2014, 12:10 PM - Thread Starter
Liked: 0
Is it not possible to clean those parts? Also, my lamp is deteriorating. The silver portion near the bulb looks like it has overheated in spots and is coming apart. Could this cause the smudges? The overall picture I am happy with.
cpollard is offline
post #4 of 4 Old 08-22-2014, 01:29 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Lamp cannot produce any picture problems except maybe the over-all brightness of the picture as the lamp nears the very end of life.
Tv repair shops do not perform optical engine cleaning/rebuilding because manufacturers do not provide engine parts or dis-assembly documents unless there is a service bulletin to repair a specific defect. Therefor rebuilds are done by special facilities, like the link I provided. If you want to attempt it then good luck to you... Check youtube, there are some videos for engine rebuilds like Sony lcd engines or various color wheel (for dlp).
Reply Rear Projection Units
