CC Mount for Mits - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By InstantEulogy
Old 08-26-2014, 08:58 PM - Thread Starter
sac130e's Avatar
CC Mount for Mits
Have a Mits 82840 with a Polk CC below the tv.
Would like to mount above, but need some way to do this.
With the thickness of the TV, it sits about 2 feet from the wall.
Are there mounts that rest on the tv to accomplish this?
Thx
sac130e is offline
Old 08-27-2014, 03:36 AM
InstantEulogy's Avatar
Quoted: 20 Post(s)
Liked: 25
Is there really no way for you to mount a center on a stand below it? It will be probably be more structurally solid than some type of mount extending 2 feet plus the length of your center above. Also, it will probably sound better under the TV, unless your trying to add a center "height" channel for an Atmos system...
old corps likes this.
InstantEulogy is offline
Old 08-28-2014, 07:36 PM - Thread Starter
sac130e's Avatar
Its already mounted below the tv, want to move above and see hoe it sounds.
Most posts state the center sounds better from top of tv instead of below.
sac130e is offline
Old 08-30-2014, 07:14 PM
Augerhandle's Avatar
Quoted: 749 Post(s)
Liked: 651
There used to be a mount just for that. It had two telescoping legs in the back with double stick tape to attach to the slope of the TV. I have one, but don't think they sell them anymore. http://www.amazon.com/OmniMount-CCH1...dp/B00067AIEU/
Augerhandle is offline
