Mitsubishi DLP "edge bleeding"/uneven brightness - AVS Forum | Home Theater Discussions And Reviews
Old 09-03-2014, 10:24 PM - Thread Starter
rocko1290's Avatar
I'm not sure if that's the right term for what I'm seeing going on with my TV, but let me try to explain what it is. Basically, the blacks are completely "uneven" on dark scenes. Mostly around the edges, it is much brighter than in the middle. It's not even on all 4 sides. Just like a dull faded grey color rather than black like the rest of the screen. And even during bright scenes, I can sometimes notice uneven brightness.
Basically I just don't have the money to buy something new at this time, so I'm gonna go ahead and replace the DLP chip since I'm having the white dots issue, and didn't know if that could also solve the edge bleeding issue, or if there's something else I can do while I already have the TV opened up.
I'd go ahead and put up a pic of the edge bleeding, but I assume it's pretty easy to imagine what I'm talking about and/or it's probably a common issue, and I actually have to replace the lamp as well so I can't even boot the damn thing up at the moment.
Oh, it's a WD-65C9, 2009 model I believe, if it makes a difference.
I appreciate any responses or advice.
XBL: Rocko1290
PSN: Rocko1290
rocko1290 is offline
Old 09-04-2014, 09:30 AM
Jquarter06's Avatar
I'm having a very similar issue with my Mitsubishi WD-60735. It is only obvious during dark scenes but it seems to have progressively gotten worse, not better
Jquarter06 is offline
Old 09-09-2014, 02:46 AM - Thread Starter
rocko1290's Avatar
Can no one comment on this issue? I'm sure someone else has seen it and I'd really like to get my TV up and running optimally again! I'd appreciate any input. Replaced the lamp and the issue hasn't changed, so I know it wasn't the lamp causing it.
Old 09-09-2014, 02:47 AM - Thread Starter
rocko1290's Avatar
Really I'm trying to determine whether or not I need to start saving for a new TV. If I can get rid of this issue with the bright spots around the edges I think I can get a couple more years out of this thing.
Old 09-20-2014, 07:56 AM
pacofortacos's Avatar
Liked: 24
If yours has the ports on the side, open one and look in at the lens. Most likely it is dusty/dirty and needs cleaned.
pacofortacos is offline
