How to find lamp time for Mits WD-92840 - AVS | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By garciab
post #1 of 3 Old Yesterday, 11:59 AM - Thread Starter
ktm125's Avatar
Hi:
Searched, but can't find the remote code to access the lamp time. thanks...
ktm125 is online now
post #2 of 3 Old Yesterday, 12:57 PM
garciab's Avatar
Quoted: 40 Post(s)
Liked: 36
I don't believe lamp hours are available, only total tv hours of operation. If it's original lamp, then they should be equal. The code that worked for my 65735 was pressing on the remote MENU, 2, 4, 7, 0. Pulls up a limited info screen. Press MENU again to clear it.
old corps likes this.
bg
garciab is online now
post #3 of 3 Unread Today, 08:39 AM - Thread Starter
ktm125's Avatar
thanks...original lamp and 2011 hours
any bench mark on when to replace?
Reply Rear Projection Units
