My Unofficial Guide to Samsung HLN Series DLP Sets - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 2633 Old 07-29-2003, 09:31 PM
Zathrus's Avatar
Arun, is there any chance of getting the file in the ZIP in a different format? The current .doc does not display well with OpenOffice.org 1.1 -- multiple sections are misformatted. A PDF (shudder) would be better, or HTML, or some kind of open standard.
Also, I didn't see the discrete codes listed in there anywhere... you might want to add them.
HLN467 being delivered tomorrow morning! Woohoo.
Zathrus is offline
post #362 of 2633 Old 07-30-2003, 02:04 AM
t0lik's Avatar
Zathrus, let us know how do you like it (or not). I'm still on the fence between getting HLN567 now or GWIII 60" later this year
t0lik is offline
post #363 of 2633 Old 07-30-2003, 04:50 AM - Thread Starter
arungupta's Avatar
Zathrus, in the first post in the thread, I have included a link to MS Word viewer, a free program from Microsoft for viewing word documents.
I will add the discrete codes in the guide.
Good luck with your new set!
Arun Gupta  My guides at www.digiupdate.com + threads at AVS Forum:
Selecting a High Def Display: Guide Thread
DLP All Vendors: Guide Thread
Samsung HLN & HLN-W1 DLP: Guide Thread Interview on HLN-W1
LCoS RPTV: GuideNew
DVD Players with DVI or HDMI: GuideNew Thread
HDTV Poll: GuideNew Sat/Cable TV...
arungupta is offline
post #364 of 2633 Old 07-30-2003, 08:11 AM
Kyle1617's Avatar
I am on the verge of purchasing an HLN617W and was wondering if anyone has tried using 2 xbox's on it. My roommate and I would like to be able to play games at the same time using the split screen mode.
Kyle1617 is offline
post #365 of 2633 Old 07-30-2003, 09:04 AM
lmychajluk's Avatar
I just answered this question in the HT Gaming Forum, but here's the link to the intitial discussion about this:
http://www.avsforum.com/avs-vb/showt...hreadid=273722
-Lee
XBL GT: S4Lee
(Former) MS MVP - Xbox
lmychajluk is offline
post #366 of 2633 Old 07-30-2003, 09:10 AM
rludym's Avatar
Everything I read says that the HLN507W is the latest DLP from Samsung but when I go to their web site it shows the HLM507W as the 2nd generation set.......please advise...!! thank you.
rludym is offline
post #367 of 2633 Old 07-30-2003, 09:16 AM
rludym's Avatar
i figured it out....samsung.com is not correct site....samsungusa.com is correct and shows HLN507W as new set...whew!
rludym is offline
post #368 of 2633 Old 07-30-2003, 10:40 AM
ride525's Avatar
Quoted: 33 Post(s)
From the guide
If you must use a DVD player with component out, use a non-progressive player instead of a progressive one - this is because the TV has superior de-interlacing/scaling circuitry compared to the DVD player. Connect it to Component 1 Input -- It is the only component input that accepts 480i/480p signals.
The guide suggests using a non-progressive DVD player if DVI not available, since the TV has superior de-interlacing/scaling circuitry. I think my several year-old Pioneer 525 qualifies.
Question: Is this circuitry always enabled, ie there is no menu selection to turn it off and on?
Thanks for your help,
Jeff
ride525 is offline
post #369 of 2633 Old 07-30-2003, 11:07 AM - Thread Starter
arungupta's Avatar
This would have to be an option on the DVD player -- either a switch or a set up option. If you don't see it, that means that the player doesn't give you a choice.
LCoS RPTV: GuideNew
post #370 of 2633 Old 07-30-2003, 11:17 AM
ride525's Avatar
Quoted: 33 Post(s)
I figured my DVD player didn't have it...
Just wondered how the Samsung DLP worked. Is the circuitry always enabled, or is there a menu option somewhere?
Thanks for your fast response...
Jeff
ride525 is offline
post #371 of 2633 Old 07-30-2003, 11:48 AM
lovebuzz#836's Avatar
Enabled. Just plug her into the components and let 'er rip.
lovebuzz#836 is online now
post #372 of 2633 Old 07-30-2003, 12:25 PM
Djayswain's Avatar
What about using the good panny progressive DVD player's (RP82 & 72's)? Should I plan on using my 72 in progressive mode on a Sammy DLP or do I leave it in interlaced?
Djayswain is offline
post #373 of 2633 Old 07-30-2003, 12:47 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
Try both to see which you like best. DVD through DVI is supposed to be better than either one.
htwaits is offline
post #374 of 2633 Old 07-30-2003, 02:08 PM
Kevin R. Anderson's Avatar
If you've spent $3,000 plus for the Sammy DLP, I don't know why you wouldn't spend another $200 to $300 for the Bravo or Sammy DVD player with DVI.
DVI is such a vast improvement over component that failure to take advantage of the Sammy DVI is a case of being penny wise and pound foolish.
ISF Certified
Kevin R. Anderson is offline
post #375 of 2633 Old 07-30-2003, 02:14 PM
Zathrus's Avatar
Well, because they all have rather serious deficiencies right now (the Samsung is useless for 4:3 material, the Bravo locks up on numerous disks, the Momitsu locks up and has nearly zero support in the US), none are changers (have a kid on the way... a changer is useful), none have discrete codes, and because there's only one DVI port which may be put to better use with a HDTV decoder or HTPC.
Zathrus is offline
post #376 of 2633 Old 07-30-2003, 02:54 PM
brick33308's Avatar
Zathrus,
I want to understand the comment about using the Samsung DVD player with 4:3 material. What exactly are you saying - that if you put in a older DVD with 4:3 material it just doesn't play?
I'm new at this and am trying to understand. Thanks.
brick33308 is offline
post #377 of 2633 Old 07-30-2003, 02:58 PM
Iceblade's Avatar
brick,
Nope, the 931 has a nasty "always stretches the sucker to wide mode" bug with regards to 4:3 content DVDs. It is not defeatable and is a highly agitating bug to most users who's DVD collections contain more than the latest anamorphic 16:9 a/r movies and such.
Let us know if you need more info.
Later,
Jeff
Iceblade is offline
post #378 of 2633 Old 07-30-2003, 03:02 PM
nash0r's Avatar
Note this 4:3 bug is only on the DVI Port. If you use component or even svideo you will be fine. Of course, the whole point of a DLP and a 931 combo is to use DVI, which is why it's so infuriating... If I had the combo, I'd personally have both DVI and component hooked up and switch to component for 4:3 discs. I am opting for a Bravo and hoping I don't get one that locks up incessantly.
nash0r is offline
post #379 of 2633 Old 07-30-2003, 03:02 PM
Those are all valid points, but you could certainly make the same argument as to why one should not buy the Sammy DLP in the first place -- it is far from a perfect TV (lack of discrete codes, one DVI input, poor QC on the lamps, etc.), but we all must have been willing to overlook its problems in exchange for the amazing picture. I'm just saying if you want the best DVD PQ today, why not spring for a DVI DVD player?
I have the Sammy 931 DVD player, and while it is certainly flawed in the areas you mention (it also has one of the longest response times of any player I've ever seen); nonetheless, I'm willing to overlook these deficiencies to be able to enjoy the amazing PQ today.
Besides, for $60, Ultimate Electronics offers a service whereby I can exchange the Sammy 931 for a better player in 2 years with full credit for the $299 purchase price. By then, Ultimate Electronics will hopefully still be in business and someone will have perfected a DVI DVD player.
ISF Certified
post #380 of 2633 Old 07-30-2003, 03:02 PM
brick33308's Avatar
Glad to know that. Are there any other DVD players on the market with DVI that don't have the problems of the Bravo or Sammy - either out now or suppposed to be coming out soon? I've got time because I'm not ordering my new HD set until HD Tivo comes out (probably January).
post #381 of 2633 Old 07-30-2003, 03:11 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
The problem is that the Samsung 931 defaults to some form of "wide" for any DVI output. What ever it's doing causes the "normal" setting on the Samsung DLP sets to be deactivated. With wide a 1.33:1 movie like Singin' In The Rain will be stretched to fill the 16x9 screen instead of displaying in 4X3 (1.33:1) which is it's "normal" aspect ratio. In the case of this particular movie it causes Debbie Reynolds to put about 40lbs extra on her tiny frame.
It's what some would call a "dudder head" default.
The same people at Samsung were probably responsible for the original HLM sets defaulting to "wide" whenever input sources were changes.
Samsung seems to revert to catering to the group that gets upset anytime the full screen is not flashing images regardless of the distortion involved. Some how black bars cheat this group out of some portion of what they feel they have paid good money for.
htwaits is offline
post #382 of 2633 Old 07-30-2003, 03:15 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
There "should" be several by then.
htwaits is offline
post #383 of 2633 Old 07-30-2003, 04:52 PM
chahm's Avatar
Can anyone tell me what is the difference between HNL437 and 4365, or HNL507 and 5065?
chahm is offline
post #384 of 2633 Old 07-30-2003, 05:19 PM
P_Stevens's Avatar
The DVI output from the Samsung DVD HD931 is only 16x9. If you wish to watch a 4x3 DVD simply switch to the component output. Why anyone would want to watch 4x3 component after seeing the 16x9 DVI is beyond me.
Pete
P_Stevens is offline
post #385 of 2633 Old 07-30-2003, 05:32 PM
ender21's Avatar
Umm.. because it stretches the picture and makes people short and fat?
That would be a deal breaker for me, to not be able to control my own aspect ratios when watching X-Files, Stargate SG-1, or old movies that are 4x3.
Some people might like it or be able to live with it, but having *less* choice instead of *more* choice limits their market for those of us that want to see things as they were intended. If they gave the option of stretching to 16x9 *or* keeping it 4x3, then it would satisfy *both* types of people. Perhaps it was an oversight on their part. I would expect it not to be the case for long.
Perfect Video
ISF Calibration
Southern California & Elsewhere
Xbox Live: EnderWiggin21
ender21 is offline
post #386 of 2633 Old 07-30-2003, 06:08 PM
DvST8's Avatar
Just a lillte more info, nothing important it looks like they updated the remote on the new 46 and 56 models also.
Not that many still use the one it comes with
pics here, and there in stock?
http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
DvST8 is offline
post #387 of 2633 Old 07-30-2003, 08:11 PM
Egan's Avatar
Quoted: 214 Post(s)
Liked: 208
Stargate SG-1 DVD's are 16x9 enhanced for widescreen fyi.
Egan is offline
post #388 of 2633 Old 07-30-2003, 08:15 PM
ender21's Avatar
Yeah you're right. My mistake!
Perfect Video
ISF Calibration
ender21 is offline
post #389 of 2633 Old 07-30-2003, 08:30 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
The HLN4365/5065 have a silver bezel. The HLN437/507 have a charcoal bezel. That it. No other differences.
htwaits is offline
post #390 of 2633 Old 07-31-2003, 04:54 AM
dwk
dwk's Avatar
FWIW Got the new 214 board installed last night. HLN617W. The tech obviously knew what he was doing.
Arun,
For possible inclusion in your fab guide, the tech asked how long we keep it on at a time, I said 3 hours. He said that should be OK, but if we keep it on 4-5 hours or more at a time, we should place a small fan blowing toward the lower rear vent to help airflow. The heat that builds up is incredible and could cause lamp failure.
I also asked about reliability of RPTV in general. He said they are experiencing most problems with Sony, Toshiba, and RCA, none with Samsung.
As for extended warranties he said they have the least claim denials with a company called NEW(?). Anyone heard of that one?
I'm just glad I've got discretes now!
dwk is offline
Reply Rear Projection Units
