My Unofficial Guide to Samsung HLN Series DLP Sets - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2633 Old 05-05-2003, 08:49 PM - Thread Starter
arungupta's Avatar
This is Version 2.9 of my unofficial guide to Samsung HLN series DLP sets. I have owned a Samsung 61 inch set since December 2002, and another 43" inch set since April 2003. This guide includes information that helped me decide for these sets and then to use them effectively. The information is gathered from myriad threads and posts in this forum, I have just tried to put it in one document.
I shall try to keep this guide up-to-date. If you have information that will benefit others in deciding or using these sets, please post it in the thread and I shall include it in the guide.
http://www.digiupdate.com/P001_Samsu..._DLP_2003.html
Previous versions downloaded ~30,000 times
Version History
Version 2.0 - Major revision
Version 2.01 - corrections, additions to firmware
Version 2.1 - corrections, additions to firmware, connection resolution, Xbox
Version 2.9 - HTML hosted version
Note: For 2004 DLP Models, see http://www.digiupdate.com/105_DLP_RPTV.html
Arun Gupta  My guides at www.digiupdate.com + threads at AVS Forum:
Selecting a High Def Display: Guide Thread
DLP All Vendors: Guide Thread
Samsung HLN & HLN-W1 DLP: Guide Thread Interview on HLN-W1
LCoS RPTV: GuideNew
DVD Players with DVI or HDMI: GuideNew Thread
HDTV Poll: GuideNew Sat/Cable TV...
arungupta is offline
post #2 of 2633 Old 05-05-2003, 09:36 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
What a great idea.
I hope you don't get too much flack for a few of your enthusiastic impressions. I plan to spend some time with your guide as I am just now getting started on a HTPC.
My understanding is that some of the HLN characteristics may be different than those you show in your table.
It might help to show the both models for the 43" and 50" sets. I believe that the HLN437, HLN507, and HLN617 have the Charcoal bezel( about 2"). The HLN4365 and HLN5065 models have the silver bezel as you indicate.
From what I have read, the HLN467 and HLN567 will have a brushed aluminum thin silver bezel. I think someone posted the measurements for these two thin bezel models. I'll try to find them. They seem to be about to arrive in small numbers as early as the first week of June.
Is there a way for you to easily update your document at AVS Forums?
Thanks for providing us with a place, especially new members, to find this information.
htwaits is online now
post #3 of 2633 Old 05-05-2003, 09:42 PM - Thread Starter
arungupta's Avatar
Thanks, Les. I'll make the corrections.
I believe posts (and attached documents) can be updated by using the edit button at the top right of a post.
Arun
LCoS RPTV: GuideNew
post #4 of 2633 Old 05-05-2003, 09:47 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Here is the size information for the HLN567 form this thread.
http://www.avsforum.com/avs-vb/showt...&highlight=567
Thanks to celeron450:
The dimensions listed in the Korean manual (page 41) for the HLN567W are:
1268 mm x 461 mm x 924 mm (WxDxH)
41.5 kg
In the English system this is approximately:
49.9" x 18.1" x 36.4" (WxDxH)
91.5 lbs
__________________
celeron450
post #5 of 2633 Old 05-05-2003, 09:48 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Arun
I've never tried to use edit to update an attached document. Sounds good.
post #6 of 2633 Old 05-05-2003, 09:56 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Here I am again.
Do you have the weights reversed? The HLN567 according to the Korean manual is 91.5 lbs.
post #7 of 2633 Old 05-05-2003, 10:16 PM - Thread Starter
arungupta's Avatar
Yes, I did have the weights reversed. Correcting right now, then I shall test if I can update the doc.
LCoS RPTV: GuideNew
post #8 of 2633 Old 05-05-2003, 10:28 PM - Thread Starter
arungupta's Avatar
htwaits - thanks for all your input.
Document successfully updated.
I shall keep updating with other corrections and missing info on at least a daily basis until the document reaches a satisfactory level.
LCoS RPTV: GuideNew
post #9 of 2633 Old 05-05-2003, 11:02 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Those bezels are still causing trouble.
"I believe that the HLN437, HLN507, and HLN617 have the Charcoal bezel( about 2") not the 2/3" thin bezel.
From what I have read, the HLN467 and HLN567 will have a brushed aluminum "thin silver" bezel not charcoal."
Samsung has created "model" hell!
post #10 of 2633 Old 05-05-2003, 11:34 PM
doug_k's Avatar
Good doc, arungupta. I have just some comments about htpc stuff - it might be more useful for people to have estimates on what they can get with particular levels of hardware, rather than making recommendations about very specific configurations (ie, exact speed, mobo, brand of memory, etc). HTPC's are huge subjects unto themselves, obviously.
doug_k is offline
post #11 of 2633 Old 05-06-2003, 10:30 AM
lmychajluk's Avatar
Thanks! You may want to send it over here:
http://www.avsforum.com/avs-vb/showt...14#post2184314
-Lee
XBL GT: S4Lee
(Former) MS MVP - Xbox
lmychajluk is offline
post #12 of 2633 Old 05-06-2003, 12:02 PM
Maurice2's Avatar
"After 3-5 years, pay for a cleaning of the lenses on the light engine to clear any residue that may collect on the surface"
How much will this cost? An estimate of the labor involved (how many minutes) and cost should be included in your Guide, so people don't get a bad surprise.
Maurice2 is offline
post #13 of 2633 Old 05-06-2003, 12:32 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Why not wait three to five years and check it out then?
post #14 of 2633 Old 05-06-2003, 12:55 PM
doug_k's Avatar
why don't these things come with hepa filters or something to keep the screen, guns, etc free of debris?
doug_k is offline
post #15 of 2633 Old 05-06-2003, 02:50 PM - Thread Starter
arungupta's Avatar
Posted version 1.2
Thanks for all your inputs.
I am looking for input on specific recommendations on User mode and Service mode adjustments.
LCoS RPTV: GuideNew
post #16 of 2633 Old 05-06-2003, 02:52 PM
lmychajluk's Avatar
I'm still waiting on a pre-ordered HLN567w, so I could be wrong about this...
You mention in your FAQ that the HLM/HLNs are monitors, not TV's, because they don't have built in tuners. I'm not sure if it counts or not, but aren't there built in SDTV tuners (hence, the buttons on the TV to change channels)? You only need an external tuner if you wish to display HDTV signals, right?
I guess the FAQ is going to be a continous work in progress, but thanks for taking the time to put it together!
-Lee
XBL GT: S4Lee
post #17 of 2633 Old 05-06-2003, 02:59 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Guns? What guns?
post #18 of 2633 Old 05-06-2003, 03:13 PM
Maurice2's Avatar
That's a ridiculous answer. You missed the point entirely.
Maurice2 is offline
post #19 of 2633 Old 05-06-2003, 03:15 PM
doug_k's Avatar
Guns? What guns?
Well, it sounded like the thread was tangenting into CRT pj's. But... my question wasn't rhetorical; do any of the pj sets have air filters to prevent stuff from getting in?
doug_k is offline
post #20 of 2633 Old 05-06-2003, 03:17 PM
doug_k's Avatar
Totally. I can see a joke now and then, but these irrelevant quips aren't adding anything to the discussion.
doug_k is offline
post #21 of 2633 Old 05-06-2003, 03:42 PM - Thread Starter
arungupta's Avatar
Lee - you are right - It does have built-in SD tuners. I forgot about them because I haven't used them. I shall upgrade the guide accordingly.
-- Arun
LCoS RPTV: GuideNew
post #22 of 2633 Old 05-06-2003, 03:58 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
"My Unofficial Guide to Samsung HLN Series DLP Sets" by arungupta. See the first message for his attached document.
post #23 of 2633 Old 05-06-2003, 10:03 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
arungupta,
Here are the measurements for the HLN467. They were provided by Celeron450 in another thread.
The dimensions and weight as listed in the Korean manual (page 41) for the HLN467W are:
1047 mm x 399 mm x 779 mm (WxDxH)
33.5 kg
41.2" x 15.7" x 30.7" (WxDxH)
73.9 lbs
post #24 of 2633 Old 05-07-2003, 08:29 AM - Thread Starter
arungupta's Avatar
Document updated -- version 1.3.
In this version I have added many links to threads in this forum and to other relevant sites.
Still looking for concrete info on service menu adjustments.
LCoS RPTV: GuideNew
post #25 of 2633 Old 05-07-2003, 09:15 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
We may have to wait awhile or buy someone like KenLand a HLN upgrade.
If Samsung comes through with an upgrade option for the early HLMs then one of the Houston gang may do a new calibration.
Thanks again for your efforts.
post #26 of 2633 Old 05-07-2003, 10:28 AM
Maurice2's Avatar
73.9 lbs
41.2 makes a lot more sense than 40.6" previously stated on another post. I would trust that. Likewise for the weight and the height. On the other hand, 15.7" for the depth (which I would be very happy with due to my space limitations) sounds suspicious because it is the same as for the HLM 43". I would expect it to be a little deeper. On that other post, it said 16.1".
Maurice2 is offline
post #27 of 2633 Old 05-07-2003, 12:43 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Maurice2,
You are right. The source is from the Korean manual. It could be a typo there are in the original message form celeron450. I just ask him to double check.
arungupta,
I just looked at the table of dimensions again and I think the measurements for the HLN437 and HLN617 might be reversed in version 1.3.
post #28 of 2633 Old 05-07-2003, 01:06 PM - Thread Starter
arungupta's Avatar
Maurice2 and htwaits - I have fixed both problems and uploaded the document. (The version number was not changed.). Thanks.
Arun
LCoS RPTV: GuideNew
post #29 of 2633 Old 05-07-2003, 01:10 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Thanks Arun. I hope you still have time for your day job!!!
post #30 of 2633 Old 05-07-2003, 01:12 PM
kmil's Avatar
I just wanted to publicly thank Arungupta for his publication. It is FULL of useful information, the type that is generally only available on an internet site. IMHO, this is what the internet is and should be about, namely individuals helping the masses. If your interested in the possible purchase of a Samsung HLN you owe it to yourself to download this!
Once again, sir, thanks for and EXCELLENT publication. I just wanted you to personally know that I/we appreciate yours and the many others who contribute to this site. Enough said!
kmil is offline
Reply Rear Projection Units
