Need help with projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-12-2017, 09:28 AM - Thread Starter
Liked: 0
Hello,
I am interested in getting a projector for a home theater for the first time and i need some help figuring out witch one, or if it is even possible in the room i have.
The room is relatively small at 10x10. The projector would have about 8' of throw from lens to screen. I would like to get at least 80-100 inches at that distance. The seating is about 6-6 1/2 feet from where the screen would go, so not very far back.. Also on a side note the projector would be roof mounted, Idk if that makes a difference?
The budget for this would be about 500-700 for the projector.
Any recommendations or advice would be greatly appreciated!
Jake
jake1421 is offline
post #2 of 2 Old 09-13-2017, 05:43 PM - Thread Starter
Liked: 0
Ended up going with a ViewSonic PJD7828HDL for the projector, and a STR-169100 Silver Ticket 100" Diagonal 16:9 for the screen.
Just in case anyone was frantically wondering what i ended up buying..
jake1421 is offline
Reply Rear Projection Units
