Set-up and Use of the Panasonic PT-50LC13 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 495 Old 06-06-2004, 02:49 PM
gregftlaud's Avatar
the manual says video nr should be turned off when a "high quality" source is used. by high quality i thought they meant hd receiver with dvi input. i have it off there.
but what i'm referring to is a directivo via s-video input. do they also consider that a high quality source? i think it looks better with video nr turned on...personally
greg
gregftlaud is offline
post #272 of 495 Old 06-09-2004, 05:55 PM
Todd76's Avatar
My manual says, "It is important to note that Video NR should remain OFF for maximum picture detail when receiving a strong signal or viewing high-quality video."
In other words, it's only needed if you have a weak signal, such as that from an OTA analog antenna (even then, if the signal is strong, turn it off). The NR stands for Noise Reduction. If there's no noise (e.g., snow) in the picture, then it's not needed.
Todd76 is offline
post #273 of 495 Old 06-16-2004, 12:14 PM
gregftlaud's Avatar
was wondering if there are any burn in problems with the pt50lc13?
greg
post #274 of 495 Old 06-16-2004, 12:47 PM
AcuraCL's Avatar
greg
Absolutely not. LCD does not burn in.
http://www.keohi.com/keohihdtv/exper...urnin_lcd.html
http://www.sharpusa.com/products/lcd...,2340,,00.html
AcuraCL is offline
post #275 of 495 Old 06-16-2004, 06:42 PM
SixIron's Avatar
FYI, for any prospective buyers of this set in FL, a south florida electronics/appliance retailer with stores in Dade, Broward and Palm Beach counties has a VERY attractive sale price on this today thru 6/22. Free stand too!
SixIron is offline
post #276 of 495 Old 06-20-2004, 09:16 AM
gregftlaud's Avatar
is the pt50lc13 hdcp/compliant?
thanks
post #277 of 495 Old 06-20-2004, 10:04 AM
Danabw's Avatar
Quoted: 845 Post(s)
Liked: 414
It has an DVI-HDCP interface. Details here:
http://catalog2.panasonic.com/webapp...noreRedirect=1
2015 Sony X850C FAQ: Recommended Picture settings, 3D FAQ, HDR FAQ, DirecTV 4K Ready FAQ, Troubleshooting & common problems; Dropbox Link || Alternate Google Drive FAQ Link. FAQ is frequently (often daily!) updated, check back often! || My gear: TV - Sony XBR75X850C, BD - Sony BDP S350, AVR - Pioneer VSX-1020, Speakers - RBH MC-616C MKII Center Channel, RBH MC-6C MKII Bookshelf (fronts), RBH MC-615 In-ceiling surrounds, RBH TS-10AP 200W self-powered sub.
Danabw is offline
post #278 of 495 Old 06-26-2004, 10:55 AM
gregftlaud's Avatar
anyone have the new HD DIRECTIVO hooked up to the pt50lc13 using dvi? how's it look?
greg
post #279 of 495 Old 07-06-2004, 07:43 PM
cabrams's Avatar
I have the PT-50LC13 and the picture is fuzzy even with component video to a DVD player. Am I doing something wrong? The Cable signal is fuzzy and I expect that but the DVD I expected to be crystal clear.
Also, the power light blinks red when it is turned off and then can't be turned back on for a while. Seems to randomly occur. Wonder if anyone else has seen this. Thanks for the help.
cabrams is offline
post #280 of 495 Old 07-06-2004, 08:59 PM
BradSontag's Avatar
Hello all, I see that Best Buy is having a close out sale on the Panny 50...Are they discontinuing? Is there a new model coming out soon?
Thanks for all responses.
Cheers,
Brad
BradSontag is offline
post #281 of 495 Old 07-06-2004, 09:06 PM
NVboy's Avatar
Cheers,
Brad
The PT-50LC13 is being replaced with the PT-50LC14.
http://catalog2.panasonic.com/webapp...tGroupId=11254
Suburbia: where trees are cut down and streets are named after them.
Flickr photos: http://www.flickr.com/photos/nvsteve/sets/
NVboy is offline
post #282 of 495 Old 07-06-2004, 10:44 PM
Danabw's Avatar
Quoted: 845 Post(s)
Liked: 414
The picture should definitely not be fuzzy - mine is very sharp w/HD signal and DVD, and surprisingly sharp w/SD as well - the clarity of SD on this set is one of the things I like best about it. How far away from the set are you sitting?
Check out page 26 of your manual for info on the power light...the blinking is normal, and indicates a cooling phase. What do you mean by "a while?"
Dana
Danabw is offline
post #283 of 495 Old 07-06-2004, 10:51 PM
Danabw's Avatar
Quoted: 845 Post(s)
Liked: 414
Originally posted by Foxbat121
You can save Jpegs back to the card, just make sure it's the same folder your camera saves them. Panny only reads JPegs from standard folder structure that most digi cameras use.
The Panny's memory card display is more flexible than their manual would lead you to believe. I've found the Panny will read just about anything on the SD card no matter where I put it...I stuck the SD card into my printer's SD card slot and I copied images into the root of the card, and into each subfolder in the card, and I believe (if I remember correctly) that I even created a new folder and put some images into it. All of them came up just fine on the screen. Following strict folder structures was not required.
Dana
Danabw is offline
post #284 of 495 Old 07-07-2004, 03:20 AM
BradSontag's Avatar
"The PT-50LC13 is being replaced with the PT-50LC14."
When is this new model due to arrive?
Cheers,
Brad
post #285 of 495 Old 07-07-2004, 03:22 AM
Gr8reb8's Avatar
greg
I do. I have it connected to the DVI port on the pt50lc13. It looks great.
Gr8reb8 is offline
post #286 of 495 Old 07-07-2004, 04:28 AM
occammd's Avatar
Has anyone used an Iscan HD w/their pt50lc13? I was wondering if the DVI input could handle the frame rate conversion to 48 or 72 Hz @ 720p?
occammd is offline
post #287 of 495 Old 07-07-2004, 08:20 AM
ceccacci's Avatar
Can't help much with "fuzzy," have you tried different cables? My aunt recently bought a DLP set which I set up for her, and I was having a terrible time with the DVD picture for a while. Most of the problem turned out to be the cables, which really surprised me. Didn't think they'd make so much difference. Also, try putting the DVD player in progressive mode if it isn't (or try turning it off if it already is), make sure other settings in the DVD player setup menu are correct (TV aspect ratio, etc.).
As for the power light, that's normal. The bulb has a cool-down cycle. When you turn it off, the screen goes blank but the bulb stays on for a few seconds. During that time you can instantly turn the set back on. After those few seconds, the bulb goes off and the fan stays running until it cools down. Once you reach that point, you can't turn the set back on until it's completed the cooling cycle.
ceccacci is offline
post #288 of 495 Old 07-07-2004, 11:13 AM
NVboy's Avatar
Cheers,
Brad
Last I heard, it was supposed to be the end of July. But, it is hard to tell for sure, especially after visiting all the online etailers. Seems like every company has a new set coming up that is marked as "coming soon" or "TBA."
NVboy is offline
post #289 of 495 Old 07-07-2004, 01:43 PM
BradSontag's Avatar
Does anybody know if its supposed to have a major upgrade kinda like the new sammy's? Or is it all cosmetic for the most part..
post #290 of 495 Old 07-07-2004, 01:48 PM
NVboy's Avatar
What, like 1080p? From what everyone has pooled together, there are no major changes.
NVboy is offline
post #291 of 495 Old 07-07-2004, 01:57 PM
ceccacci's Avatar
Just looked at the specs on the website, and the only difference I could find was that they've replaced the DVI-HDCP interface with an HDMI-HDCP interface. Oh, and 2 extra speakers.
ceccacci is offline
post #292 of 495 Old 07-07-2004, 02:21 PM
Bookworm's Avatar
Here a comparison of the two from Panasonic's website: LC13vs.LC14
Bookworm is offline
post #293 of 495 Old 07-07-2004, 02:38 PM
doggiedog's Avatar
Wow!
The 50LC13 is tiny compared to the 50LC14
Denon X4100W | B&W CM6 S2 Front | B&W HTM2 Center | B&W 601 S3 Surround | Hsu VTF-3 Mk5 HP Sub
doggiedog is offline
post #294 of 495 Old 07-07-2004, 02:48 PM
AcuraCL's Avatar
Heheheh
Must be those extra 2 speakers ....
AcuraCL is offline
post #295 of 495 Old 07-07-2004, 03:53 PM
Bookworm's Avatar
Originally posted by doggiedog
Wow!
LOL, I didn't notice that when I posted the link.
Bookworm is offline
post #296 of 495 Old 07-07-2004, 04:07 PM
Dallas_Jose's Avatar
I got the Video essentials dvd lastnight. I tried to calibrate my tv but I use DVI through my pc for dvd and the pc color controls don't lend themselves to color corection with DVE. I connected through component but the overlay has it's own set of color controls so again no go. I thought the component is from the cable box so this really defeats the purpose since I should be calibrating with the video source used on the input.
I luckily got a hd channel signal lost late last night. It had the color pattern on it though, the color pattern off the air channels show. I then immediately n oticed the red, blue, green and yellow push. I then quickly while the pattern was on, set my tv to normal and warm set everything to default. I then got into the service menu to adjust the colors. I tried at first the red reduction on the last page 6/6 but noticed it threw off the other colors ie the picture would turn green bias or blue bias. I then with that pattern on decided to connect DVI and component out of my Motorola 5100 hd box and compare the results. What I found was that DVI was worse than component. In the color pattern the component looked sharper it was not an illusion as I moved to within 1 ft of the tv I could see that component had a cleaner line where the red and blue met and had less "dot crawl" than the DVI input. The component input has less I guess bleeding between contrasting colors on the color pattern. I then decided to experiment around with the service menu and stayed on component from my cable box. What I found worked best was not to mess with individual colors on page 6/6 but to reduce the hd color setting on page 5/6 I think. I took the setting from 24 to 14 and it iliminated those "hyper" colors you see. It made the red and blue look much better on the test pattern screen and I used the color filter from DVE to get close to having the colors match. I could not get them exact but they were very close. I use dvi through my pc and it looks ok so I suspect the cable boxes dvi setting are off.
Dallas_Jose is offline
post #297 of 495 Old 07-07-2004, 06:47 PM
Danabw's Avatar
Quoted: 845 Post(s)
Liked: 414
Thanks for the details, Dallas Joe.
If you mean the SUB COLOR HD setting, it's on page 3/6 of video, and my default value was 22.
Page 5/6 has nothing with "color" aside from SUB COLOR TNR OFFSET which has a default of FE. :-)
Dana
Danabw is offline
post #298 of 495 Old 07-08-2004, 01:22 AM
oops yeah that setting
post #299 of 495 Old 07-08-2004, 05:15 AM
occammd's Avatar
Does anyone know if the internals convert incoming 48Hz video to 60Hz for display, or will it follow the incoming framerate?
occammd is offline
post #300 of 495 Old 07-08-2004, 09:16 PM
rdr
rdr's Avatar
I have been browsing through this thread and the "Panasonic PT-50LC13 In Home Observations" thread after seeing this television in the store. I have seen people stating that regular cable and even digital cable can look pretty lousy. I am looking to buy this for use with a "regular" satellite TV provider (and use my Tivo), along with DVDs. Is it worth getting or will I be disappointed with the quality? Thanks for any input.
rdr is offline
Reply Rear Projection Units
