How's your GWII doing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 415 Old 01-09-2004, 04:40 AM - Thread Starter
NightHawk's Avatar
How are the GWII LCD sets out there holding up? I have the 50 inch GWII XBR set with 3021 hours now and no problems. No bulb failures, dead pixels or LCD browning yet. Exception or rule?
NightHawk is offline
post #2 of 415 Old 01-09-2004, 07:15 AM
Rop
Rop's Avatar
Mine is still going strong as well, about 10 months old now. I've done most of the UMR tweaks and am still in awe at the picture quality. No dead pixels (other than the ones it had when it arrived, which I can't see from more than a foot away anyway), color looks good to me (white looks about as white as my 6500K backlight). Still using the original bulb as well. I'm very happy with it and consider it one of my best purchases.
B.t.w. where do you get the hours on the bulb? Somewhere in the SM? Couldn't find it in mine.
-Rob-
Lies, damn lies, and interconnects...
Rop is offline
post #3 of 415 Old 01-09-2004, 07:32 AM
motjes2's Avatar
Mine very strong and loving every minute of it! You have to enter the service menu to see the hours on the bulb. Dead pixels--Yes when it arrived but not seeing it at a viewing distance.
motjes2 is offline
post #4 of 415 Old 01-09-2004, 07:49 AM - Thread Starter
NightHawk's Avatar
In the service menu, cycle through the catagories and you will see a page with time and bulb temperature. I was suprised at how high the number was. It averaged out to 7.2 hours a day. I shoud get a life.
post #5 of 415 Old 01-09-2004, 09:12 AM
stephenC's Avatar
Glad you started this thread. I have a GWii 60". No pixel problems, turns on every time. Great picture. I wanted to post a reply in the GWIII buzz problem thread that I was glad to have bought the 2nd gen product, but I didn't want to piss off anyone. I know I'd be very upset if I had a GWIII with the power on problem and unable to get it fixed.
stephenC is offline
post #6 of 415 Old 01-09-2004, 09:49 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Or sue your cable company http://www.wisinfo.com/thereporter/n...14044768.shtml
Foxbat121 is offline
post #7 of 415 Old 01-09-2004, 10:23 AM
kkelley's Avatar
My GWII 60" will be a year old next week. It is performing perfectly!!
I have done all the UMR tweaks except the color correction filter. How many of you have done this tweak and were you happy witht the results?
kkelley is offline
post #8 of 415 Old 01-09-2004, 10:51 AM
exLabDriver's Avatar
I've had the 50"GW for about 9 months with about 1500 hours on it.
Once the picture tilt was fixed by shimming the optical block 6 months ago, it has been excellent. No visible pixel problems and the screen colour is uniform.
Most of UMR's tweaks done except for gray scale using AVIA. Looks just fine.
Very happy with my purchase.
exLabDriver is offline
post #9 of 415 Old 01-09-2004, 11:38 AM - Thread Starter
NightHawk's Avatar
That's too funny. At least I can blame the high time partly on the kid. Also the girlfrield keeps leaving it on just so music channel titles scroll past.
I was thinking of stocking up on a spare bulb. Anyone know where to order one from and how much they cost?
post #10 of 415 Old 01-09-2004, 11:43 AM
stephenC's Avatar
Nighthawk - Be aware that Sony warranty begins on date of purchase. If you buy a replacement bulb and it sits on your shelf until you need it, the warranty period has been running. If you have a problem with the new bulb, it may be out of warranty when you install it. Just FYI and YMMV.
stephenC is offline
post #11 of 415 Old 01-09-2004, 02:30 PM
Mazdaspeedguy's Avatar
Well my GWII is doing just fine! When I first got it I had a bad LCD panel (Green patch) upper left corner of screen. Sony replaced the Optical block at a cost of $4,897.67CDN. I lucked out with the new Optical block installed have 0 stuck or bad pixels even looking up close at the set!
I have done all of UMR tweaks minus color correction filter. With great success.
Total hours 2789 and counting.
I think the main reason Sony is having problems with the GWIII is that some of the parts used in the new sets are not as high quality as the GWII, they had to do this to bring down the price point of the t.v
Mazdaspeedguy is offline
post #12 of 415 Old 01-09-2004, 03:13 PM
Marc D Carra's Avatar
Quoted: 38 Post(s)
Liked: 44
Mazdaspeedguy,
Was your green patch visible on on bright scenes or just black? I have a small green patch in my lower right corner, but it's only visible on completely dark scenes. Should I call Sony? I have a GWIII.
Marc.
MDC
Marc D Carra is offline
post #13 of 415 Old 01-09-2004, 08:40 PM
bdoyledimou's Avatar
6 months, no issues. Not one.
No tilt, no green splotches.no dead picles. On for about 8 hours per day (mixed viewing of dvd ,video games and SDTV.)
PSN: Wrassle
360: Burnt of Wrassl
bdoyledimou is offline
post #14 of 415 Old 01-09-2004, 08:52 PM
tmhcars's Avatar
Mine is 6 months old and the bulb went out three weeks ago & I am still waiting for Sony Service to put in a new bulb. I am quite upset with the warranty service since it has been since Dec. 24th when they came to my house.
tmhcars is offline
post #15 of 415 Old 01-09-2004, 08:56 PM
Originally posted by Marc D Carra
Mazdaspeedguy,
Marc.
Yes mine was only visible on a black screen or on dark movies.
I would either request a new set or just get the new Optical block from Sony.
You need to get the whole Optical block because you can not just replace the bad LCD panel in question.
post #16 of 415 Old 01-09-2004, 10:06 PM
umr
umr's Avatar
Quoted: 39 Post(s)
Liked: 77
umr is offline
post #17 of 415 Old 01-09-2004, 11:35 PM
Couch Patato's Avatar
About a month ago I noticed the image revision was off on my set. I know for a fact not long before I noticed it, it was perfect.. I've always had it on 3. Something happened to make the change. I did have a power outage not long before this happened though. hummm?
Auto, 2 & 3 all looked the same. I had to go into the service menu and readjust it.( thank you again UMR) It looks just fine now. Everything else has been great since I got it. The bulb is at 5200 hrs now.
I don't feel bad one bit for not waiting untill this years models came out.
" I say down with stretch-O-vision and any channel to use it! "
Couch Patato is offline
post #18 of 415 Old 01-11-2004, 01:34 AM
UMR!!!
Where can i get the LATEST copy of the GWII tweaks? the link in the old thread isn't working!
PSN: Wrassle
post #19 of 415 Old 01-11-2004, 08:30 AM
nyrjoe's Avatar
What's the rated bulb life on the GWII?
nyrjoe is offline
post #20 of 415 Old 01-11-2004, 09:01 AM
8000hrs
post #21 of 415 Old 01-11-2004, 09:08 AM
nyrjoe's Avatar
I've read here the GWIII bulb life is rated for 2000. It uses the XL2100U, is the same as the GWII?
nyrjoe is offline
post #22 of 415 Old 01-11-2004, 09:42 AM
Nope. The GWII uses the XL2000U.
post #23 of 415 Old 01-11-2004, 10:04 AM
XBRSteve's Avatar
Quoted: 12 Post(s)
Still going strong (knock on wood) they seem to be holding up better than GWIII's.
Sharp Elite Pro 60
Pioneer Elite VSX-52 Receiver
Pioneer Elite  BDP-62FD BluRay
XBRSteve is offline
post #24 of 415 Old 01-11-2004, 12:16 PM
Moderator
Moderator
Barrybud's Avatar
Quoted: 45 Post(s)
Liked: 26
Congrats guys! Its good to see a thread like this.
Was there a GW1 or first gen of this set? Are there any owners?
Quick Reference of Forum Rules
1) Do Not post pricing you found on-line or at a local dealer UNLESS IN A DEALS THREAD.
2) Do Not ask for, or offer, a receipt so people can price match.
3) Do Not say to "Call John Smith at ..." (you know what I mean)
4) Do Not put down someone else's choice in...
Barrybud is offline
post #25 of 415 Old 01-11-2004, 01:30 PM
MChilli's Avatar
Got my 60" unit when they first came out fall of 2002. For those of you who bought units with me, hope you are all doing well and the sets are holding up ok.
Haven't had any problems at all with the unit, probably not more than 1000 hours on it. Doesn't snap, crackle, or pop at all. Yes, some bad pixels, can't see them at a distance. So far I have been very happy and very satisfied, that is until I saw the new 70" model, and decided I really want one of those. Maybe next year.
Anyway, we seem to be having better luck with the GWII's than these new models. I do remember watching the board for problems last year when the people started buying the sets, and there really wasn't many problems, other than people upset over bad pixels, and splotches of color. Otherwise, it has been all quite on the GWII front.
Hopefully, these will last many, many years.....
MChilli is offline
post #26 of 415 Old 01-11-2004, 01:32 PM
MChilli's Avatar
Oh, yea, still on the first buld, unlike the unlucky Sammy owners. I am not stockpiling bulbs.
Anyone remember how long the factory warranty on these are?? Is it 2 or 3 years since they are Grand Wegas??
Anyone with a first generation GWI?? Remember, when they first came out they listed around $8999 then dropped down to $7999. Wow, times change.
MChilli is offline
post #27 of 415 Old 01-11-2004, 01:54 PM
QZ1
QZ1's Avatar
1 year warranty.
QZ1 is offline
post #28 of 415 Old 01-11-2004, 02:40 PM
jbaraga's Avatar
I've had it since Jan 2003, still has the "wow" factor. No problems. Have applied UMR tweaks, except white balance and filter. I bought an extended warranty with it from Audio King, now Ultimate Electronics.
Has anybody bought a backup bulb? If so, where, and how much?
jbaraga is offline
post #29 of 415 Old 01-12-2004, 12:53 PM
hawaii351's Avatar
I just purchased a 60XBR800 floor model in Dec 2003. Considering the mounting problems with the GWIII I concluded that the GWII models were a lot more stable. I also had a very good price and negotiated my way out of paying any tax in addition to the already huge discount. Bulb meter was just over 3000 hrs so the unit has been working solidly for about a year now. Only found one stuck blue pixel that is not noticable unless your nose is up to the screen. Applied the enhancement tweaks by UMR and adjusted the GAMM level between 7 to 10 with better contrast results and set the color temperature to warm to remove the blue hue on blacks with the other temperature settings. I am very happy with my set and have absolutely no regrets buying the XBR GWII!
hawaii351 is offline
post #30 of 415 Old 01-12-2004, 07:27 PM
Quoted: 21 Post(s)
Browsers of this thread may be interested to know that Crutchfield has the 60xbr800 for sale for $4300 & free shipping. Mine's on the way; for now the search for the elusive tweak file continues in earnest, though who knows I may be satisfied w/just new gamma and a filter...
Laserfan is offline
Reply Rear Projection Units
