GWIV owner thread - Page 137 - AVS Forum | Home Theater Discussions And Reviews
post #4081 of 4091 Old 03-25-2013, 12:55 PM
Ebucel's Avatar
Originally Posted by DaverJ View Post
The Wii U's UI isn't designed well for rear projection TVs. There's a sizing option in the TV menu where you can set the display at -1, but the Wii U's text on the edges will still hang off because they are typed right at the edge of the screen.
As for the blue line, it's a known flaw with the optical block. The solution is to have it rebuilt, but there no guarantee it won't return. I agree with Steve, if it bothers you, the best fix is a new TV.
Yeah, I tried the -1 but its just not enough %reduction to fix it.
And the Game option must only work when using some other connection type.
Sigh.
Ebucel is offline
post #4082 of 4091 Old 07-15-2014, 11:59 AM
desmoface's Avatar
Quoted: 13 Post(s)
Hey gang, my old 50" gwiv's lamp is on it's last leg. I'm at a cross roads; the tv works fine, do I spend money on a new lamp, or do I just put that money towards a new tv? I've always wanted a 60", maybe this is the time to buy. Thanks for any advice.
Steve
desmoface is offline
post #4083 of 4091 Old 07-15-2014, 12:06 PM
DaverJ's Avatar
Quoted: 1315 Post(s)
Liked: 3704
Hey Steve...
It might be time. I finally ditched my 60XS955 for the curved Sony 65" LCD, and have been pretty happy with it overall.
How long do you want to keep watching your rear-projection? If it's serving you well and money is tight, stick with it to the end. But at some point you are going to replace it, so the question is sooner or later?
DaverJ is offline
post #4084 of 4091 Old 07-15-2014, 12:15 PM
desmoface's Avatar
Quoted: 13 Post(s)
Hi daverj, it's getting up there in age, it works fine, but it's got to be close to 10 years old. I'm thinking it's time to start looking. Now the research begins, LOL. Thanks for the reply.
Steve
Hey Steve...
post #4085 of 4091 Old 07-15-2014, 08:47 PM
steve ans's Avatar
Steve
It's time! Prices are amazing on 1080p TVs and are dropping on 4K. Your 768p TV gave you a decade's worth of pleasure but I think you deserve something better now!
Sony XBR-55X930D, Sony KDL-55HX729, Sony HT-NT5 Sound bar, Sony UBP-X800 BD Player, Sony 3D Glasses: TDG-BT500A, BR-750 & TDG-BR250, Apple TVs, Gen 3 & 4 APC Back Up UPS XS1500.
steve ans is offline
post #4086 of 4091 Old 07-16-2014, 04:07 AM
desmoface's Avatar
Quoted: 13 Post(s)
Hi Steve ans,
I'm going to start looking - any advice on a good replacement? Not looking to go crazy, I'd like to stay under $2,000 if possible. Thanks again for the advice.
Steve
post #4087 of 4091 Old 07-16-2014, 10:35 AM
vando45's Avatar
Liked: 26
Plasma, before they are all gone.
If your optical block is showing signs of going out you may still qualify for a slight (15%?) discount from Sony.
vando45 is offline
post #4088 of 4091 Old 07-16-2014, 04:18 PM
desmoface's Avatar
Quoted: 13 Post(s)
Hmm.. I've read that Panasonic is the plasma to get, the only problem is that my living has a big window and bright sunlight, the plasma in our bedroom turns into a mirror in sunlight, LOL. Also, I can't find anyplace that sells panny's in the Cleveland, Ohio area. I'll have to do a bit of research. Thanks for the advice.
Steve
post #4089 of 4091 Old 07-16-2014, 09:04 PM
DaverJ's Avatar
Liked: 3704
You tried Cleveland Plasma?
DaverJ is offline
post #4090 of 4091 Old 07-16-2014, 10:43 PM
Schwa's Avatar
Quoted: 1117 Post(s)
Liked: 1169
Good luck finding a new Panasonic plasma anywhere, much less at a reasonable price. Your best bet right now is to get a Samsung F8500 while you still can, but those are going fast.
Schwa is offline
post #4091 of 4091 Old 07-16-2014, 11:47 PM
desmoface's Avatar
Quoted: 13 Post(s)
Hey everyone, thanks for the advice. I am currently speaking with Cleveland av. Have any of you ever purchased through him? If so, how did it go?
Steve
Reply Rear Projection Units
