HLP5674W/HLP4674W Owners Thread/Problems/Tweaks/Service Menu/Discretes etc. - Page 77 - AVS Forum | Home Theater Discussions And Reviews
post #2281 of 2292 Old 03-11-2010, 10:44 AM
GSB
GSB's Avatar
Yes, heat may well be a factor. I'd imagine that a repair would cost a few hundred bucks (they'd probably start by replacing the light-engine). So it might be wiser to upgrade, especially considering the current prices on LCD's. I went for a Sony XBR 1080p LCDTV, and I'm SO glad that I did. It is so much nicer than the DLP. I passed the DLP on to my in-laws, and it's still working well for them on the original lamp.
Gary
GSB is offline
post #2282 of 2292 Old 03-11-2010, 08:04 PM
Hogs25's Avatar
Thanks Gary. That is what I am thinking. I will have it looked at to find out the possible cost. I have already started looking at the new LCDs. I have a Vizio 32 inch in the bedroom that has a better picture than my DLP had, so I may use this time to upgrade.
Hogs25 is offline
post #2283 of 2292 Old 03-31-2010, 08:29 PM
Hogs25's Avatar
Well Gary I found out the repair was more than I was willing to spend, so I upgraded to a Vizio VF552XVT and was amazed at how much better the picture is. I haven't really looked at TVs since I bought the DLP 4+ years ago. The repair guy is even going to buy my TV for parts .
Hogs25 is offline
post #2284 of 2292 Old 04-01-2010, 03:12 PM
GSB
GSB's Avatar
Very cool! Yes, it is truly amazing how good a 1080p fixed-pixel display looks, especially with a 1080p Blu-ray source!
Gary
GSB is offline
post #2285 of 2292 Old 08-12-2010, 12:51 PM
Schnauzer's Avatar
I just received my lamp from Fedex and followed the general video on the Samsung site, once I removed the little cover on the back of the TV expecting to see the lamp - there was a fan.
Can anyone tell me what I need to remove to get at the lamp.
I appreciate it!!
Schnauzer is offline
post #2286 of 2292 Old 11-27-2010, 06:54 AM
Chris Braun's Avatar
I just wanted to chime in on how reliable this set has been. I bought the new HLP5674 six years ago. I recently replaced the bulb even though the first bulb was still going strong.
My next TV will likely be a Samsung based on the experience I've had with this TV. Kudos Samsung engineers!
Chris Braun is offline
post #2287 of 2292 Old 01-03-2011, 06:43 PM
mavvam's Avatar
I lose my blue in my picture after watching for a while..
I thought color wheel, but it's just the blue.... Any help?
mavvam is offline
post #2288 of 2292 Old 01-25-2011, 08:19 AM
poorman's Avatar
I appreciate it!!
You probably figured this out already, but the lamp door is on the left side of the set, as viewed from the front.
-- Pete
poorman is offline
post #2289 of 2292 Old 09-19-2011, 08:32 AM - Thread Starter
Paul_PDX's Avatar
I Just put another $120 into my 5674 -- definitely the last time. I replaced the color wheel myself for the 2nd time after it shattered. Took me about 30 minutes total time this time a great improvement over three hours last time. I replaced the bulb last May.
This time the color wheel was my fault -- I was sanding new sheetrock seams in the room with the set while it was on -- the fine grit in the air got pulled into the set and it didn't have a chance.
Paul_PDX is offline
post #2290 of 2292 Old 09-03-2012, 10:31 PM
KGD_007's Avatar
So I replaced the bulb on my 4674 and now only have a picture in black and white. Any ideas what could be causing this or how to fix it?
Kris
KGD_007 is offline
post #2291 of 2292 Old 09-04-2012, 10:29 AM
EG3
EG3's Avatar
Sounds like a bad color wheel KGD_007.
EG3 is offline
post #2292 of 2292 Old 09-24-2015, 08:39 PM
acem77's Avatar
HLP5674 power off after a few minutes
1st odd thing i noticed is i have to hold the power button for a few sec to turn on.
after a few 2 seconds i get good clear image, and the fan at the back is running well.
then it does a cold shut down, fan and all turns off.
i get the lamp and standby/temp led on the front flashing on and off together every 8 seconds.
if i unplug the power cord and plug it back i can turn the tv back on.
then the issues repeats.
thanks in advance for any help
acem77 is offline
Reply Rear Projection Units
