Build You Own (BYO) TV Stand - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #91 of 1481 Old 11-22-2004, 11:24 AM
bruce24's Avatar
PS Not trying to brag, but I built the room along with the wainscoat and everything you see in the room.
Your picture did the bragging for you
bruce24 is offline
post #92 of 1481 Old 11-22-2004, 12:04 PM
BB_Mike's Avatar
My bad, I tried to use the most nuetral word I could in "kosher". I too am an Audio-bum. I just realised that Ironhorse is a beer. I even have a T-shirt with their logo, I think... Anywho, carry on.
BB_Mike is offline
post #93 of 1481 Old 11-22-2004, 12:11 PM
islandview's Avatar
Iron Horse
Thank you for providing such a detailed summary of your experience building the TV stand. The photos are a great help.
One quick question - how are you mounting the caster wheels to the bottom of the stand?
Cheers
Kevin
If all else fails ......... read the instructions.
islandview is offline
post #94 of 1481 Old 11-22-2004, 12:18 PM
Kid Red's Avatar
Originally posted by bruce24
How did you get the outside frame so thick? Did you trim it with 1"x2"s?
Used 6" x 3/4" clear pine boards and cut to a width of 1-1/2" for all but the bottom which is 3-3/4" We also use the clear pine to cover the front of each shelf.
What is clear pine? So are you saying you did frame it with 1 1/2" to make it look thicker? I like that thicker look. I built wall bookshelves with MDF and keep thinking it's a tad thin looking. Wife thinks the 1 1 1/2" facing would make it too think, I don't think it would. But I like your thickness.
Kid Red is offline
post #95 of 1481 Old 11-22-2004, 12:21 PM
mdjl4's Avatar
Great posts in this thread! Just stumbled across it and figured I'd post my own project also. Although its similar to the other designs here (basically the 3 cube box setup), I did a few design details that may interest others.
#1: I used some thin strips of wood on left and right sides to simulate a "faux panel" type construction so as to give the finished product a more "professionally built" look to it.
#2: I added 2 lengths of PVC pipe to connect the left and right sides so as to create seperated conduits for signal and power cables going from Tivo/DVD to the receiver.
#3: I built the doors by routing out some wood strips and using bathroom caulk to secure pieces of glass into the doors. The glass was really cheap (like $8 a piece), custom cut.
Also of note ... I didn't do any fancy "biscuit" stuff or dowels or anything ... I just used 90 degree metal brackets and straight screws and basically all of the strength of the unit is created by the backboard being nailed to the vertical supports. Also note, I used Home Depot "Behr" paint and I highly recommend AGAINST this product because it produces a very soft/markable finish, even after 6 weeks of cure time.
I'm gonna build out the rest of the "entertainment center" when I get some time (see inset picture on 1 of these posts ... guess I gotta post 3 times to get 3 pictures up ...)
mdjl4 is offline
post #96 of 1481 Old 11-22-2004, 12:23 PM
mdjl4's Avatar
pic 2 of 3
mdjl4 is offline
post #97 of 1481 Old 11-22-2004, 12:23 PM
mdjl4's Avatar
pic 3 of 3
mdjl4 is offline
post #98 of 1481 Old 11-22-2004, 01:29 PM
bruce24's Avatar
Clear pine is natural pine with few knots.
The reason for the frame was to hide the plywood edges, we made it 1-1/2" to give the cabinet -- what we thought -- was a better look.
bruce24 is offline
post #99 of 1481 Old 11-22-2004, 01:43 PM
Kid Red's Avatar
mdjl4- Very impressive. One question-the pvc pipe goes left to right and there's a hole cutout in the top left and right sections? Is there a cutout to the rear of the pipes for exiting wires?
bruce24- Ah, ok. Yea, that's a good way to cover the edges, and it makes the unit look heavier, more substantial.
Kid Red is offline
post #100 of 1481 Old 11-22-2004, 02:08 PM
mdjl4's Avatar
Kid Red, there is 1 cutout behind the receiver for power and the right side has 2 cutouts for the satellite-in cables and for Tivo power (which is not switched off with the reciever). No cutouts behind the PVC. My main reasoning for running that PVC setup was that I knew once the thing was in place, there was no way I could move the whole setup an inch to access cabling behind it without offloading the TV.
I forgot to mention: The Tivo absolutely needed fans ... it overheated sitting in the cabinet even without the doors mounted. That means that this cabinet required input and exhaust fans for the Tivo unit and an exhaust fan for the receiver. I used Silenx low decibel fans (3 X $16 = $48 - ouch) and a radio shack dc converter ($15). The fans are not as quiet as I would like them to be but what can you do?
mdjl4 is offline
post #101 of 1481 Old 11-22-2004, 02:19 PM
Kid Red's Avatar
mdjl4- So the pvc is removable or something? The Tivo overheated but teh A/V receiver didn't? That would be a concern as far as ventilation. I might opt to leave the back open. Yours is very professional btw/
Kid Red is offline
post #102 of 1481 Old 11-22-2004, 02:47 PM - Thread Starter
IronHorse's Avatar
Hey Red...
Who you calling a beer? That nickname is in deference to Lou Gehrig, a Yankee's Yankee! Man I been called plenty of things, but a beer. I think I like it! And don't worry about me, I don't mind being told there's a right way a wrong way, and the way I did it . Hey, I'm having fun.
MDjl4... Beautiful cabinet! Elegant design.
Island View... Simple plate mount casters, four #10 X 5/8" screws. But I might stick 1/2" plywood "pads" in there to give the unit an extra 1/2" of height off the carpet, and if I do, I'll go to a 1" screw. BTW, I'm going to use eight (8) casters total.
Iron Horse
• If God had intended man to watch TV 24/7, he would have given him Rabbit Ears •
Mitsubishi WD-65737 DLP • Yamaha HTR-5063 • Panasonic BDT210 BDPlayer • DirecTVDVR • Chromecast • AppleTV/XMBC • Comcast HD
Speakers • Towers Polk Audio Monitor60B II • CC Polk Audio CS1B II • Rear Surround Klipsch S10s • Sub Velodyne EQ Max 8"
IronHorse is offline
post #103 of 1481 Old 11-22-2004, 02:52 PM
Kid Red's Avatar
LOL, I ain't calling no body nuthin'! BB_Mike called you a beer, I think IronHorse is the name of a beer or something. Unless your just famous and have your shirts. Any more photos or updates?
Kid Red is offline
post #104 of 1481 Old 11-22-2004, 06:25 PM
Pablopsd's Avatar
Hey MD, nice cabinet. I can't believe you had overheating problems even without the doors. I have a Tivo, and haven't had any issues with overheating. I have yet to make the doors, going on many years without. We have a toddler now and it is becoming an issue! I have a good 2 to 3 " of airflow around the top and sides of everything.
Ironhorse, go BoSox! Who's your Daddy!!!
Pablo
Pablopsd is offline
post #105 of 1481 Old 11-22-2004, 09:15 PM
Spiff69's Avatar
Got a few new pics after the first layer of finish:
http://gallery.avsforum.com/showphot...ze=big&cat=500
http://gallery.avsforum.com/showphot...sort=1&cat=500
There are a few blemishes but they shouldn't be seen after I get the equipment in there. Still frustrating, though. You really gotta watch that oak plywood cause the first layer is very thin and it really affects your finish. I haven't had that problem with birch ply when I've used that.
Overall, I'm still pretty happy with it and am anxious to get to the clearcoat.
IronHorse and MDJL4 - Both look very niiiiiiice.
Spiff69 is offline
post #106 of 1481 Old 11-23-2004, 12:19 AM
gschrock's Avatar
Hmm, man, what I wouldn't give for the proper tools to pull this off. What I'm seeing here is so much better than what I'm seeing in the store, and priced better no less.
gschrock is offline
post #107 of 1481 Old 11-23-2004, 09:29 AM
islandview's Avatar
Iron Horse & Spiff69
I hope your stands are progressing well and that you'll soon be able to use them!!
In the hope of receiving some constructive criticism and helpful suggestions I've attached a copy of a plan that I've been kicking around for a few months. We're expecting our first child in January so my den is evolving into the baby room. Accordingly the home theatre equipment is moving into the living room and a new TV is required given the larger environment!
I've elected to keep the amplifiers near the base (as they're also the heaviest) and the more active components at eye level. On either side of the unit we intend to use pre-existing 84" x 32" shelves resulting in an overall 12' x 7' "built-in" wall that will hopefully appear tasteful but also practical.
Fabrication will likely commence in a few weeks. The finish will be a high gloss white so I'm planning on using a good grade of plywood that can accept the water-based paint. 8 heavy-duty caster wheels should hopefully support this cabinet to enable easy access to the wires behind.
I look forward to any comments and look forward to providing a picture of the finished product early next year.
Cheers,
Kevin
post #108 of 1481 Old 11-23-2004, 09:31 AM
islandview's Avatar
Sorry. Here it is.
av cabinet dimensions.pdf 38.8896484375k . file
post #109 of 1481 Old 11-23-2004, 12:14 PM - Thread Starter
IronHorse's Avatar
Pablopsd...
Lets just say the better team won _this_ year, and it's only proper that you let that cape cod minor league team win once every hundred years or so. LoL. But wait'll next year. Now that I have my 62" DLP... baseball will be very interesting. BTW, all NESN home games are HD so I can't wait for those Bosox-Yanks games.
Kid Red... I think the stand is going on hold until after the holiday. I have some other more demanding (can you spell SWMBO?) honey-do items that go part in parcel with getting this tv. Leaves, outside windows, fix daughter's muffler. Hehehehehe, what a life.
IslandView... man, you got way too many toys. How do you decide what to do? Watch a game, play a game, sing along with a game, be the game... man, it's all a blur. But that's gonna be a nice cabinet. With regard to the finish... are you expecting a really sweet gloss with a water based paint? I used to be heavy into boating, and there are some awesome white urethanes you can find at west marine. Do you have any spray equipment or a compressor? Make sure you seal the wood so that you don't get grain checking, and you're probably better off staying away from ordinary fir plywood or even oak. Birch is about $40/sheet at HD IIRC, and the grain is fairly tight.
Iron Horse
post #110 of 1481 Old 11-23-2004, 01:01 PM
Spiff69's Avatar
IslandView - I think the design looks great. I like the way you've staggered the depth of some of the shelving. It gives it a cool profile and a lot more dynamic look than just a big box.
Are you concerned at all about the heigth on this? I can see that you've got all your really heavy amps down at the bottom to help with the weight. You'll just have to make sure it's bottom heavy and not the other way around.
You've got to be happy, huh? The bigger room requires a bigger TV?
Spiff69 is offline
post #111 of 1481 Old 11-23-2004, 06:57 PM
Pablopsd's Avatar
Hey Ironhorse,
Once you finish the stand, are you still going to hang around, or will we never hear from you again? You started this thing, you better stay in touch!
BTW the World Series looked awesome in HD. Of course you probably weren't watching! LOL
Pablo
Pablopsd is offline
post #112 of 1481 Old 11-23-2004, 07:06 PM
tucson_bill's Avatar
Originally posted by IronHorse
I'm attaching Pix #2 to this note which shows the rear 3/4 view which is sort of unremarkable except that I did allow for the wire pass-thru and also recessed the center so that I could mount a low-profile clean power strip.
IronHorse, good design and a great thread. I particularly liked your idea for the cable chase. I think I'll steal it!
tucson_bill is offline
post #113 of 1481 Old 11-23-2004, 08:43 PM
JasonColeman's Avatar
Quoted: 23 Post(s)
IslandView-
Is there a way that you could increase the width and decrease the height of your cabinet? What about putting a half-height add-on on one side to house some of the equipment instead of putting it all above the TV? I built a similar cabinet that I wished that I had staggered a bit more to decrease the height. If you can spare some width, I think it would be worth it. Also, birch plywood is perfect for painting. Give it a good coat of primer followed by a 400-grit sanding and you should be all set for multiple layers of paint. Finally, make sure the whole affair is modular. I had to take out an entire bay window to move our entertainment center into our last house...needless to say, the wife still loves to bring that one up!
Jason
JasonColeman is offline
post #114 of 1481 Old 11-23-2004, 08:46 PM
dadetigl's Avatar
I am a newbie to this forum and a woodworker. I just bought a Samsung 5063 that I had to have NOW and was forced to buy a retail stand so I could use it. Pathetic. The shelf spacing wouldn't allow me to put my components where I wanted. Also it was particle board which my wife hates. Needless to say, I will be building my own out of cherry. Love the color. Love how it ages.
There has been a lot of discusion about treating edges of plywood. I would like to give you my input.
I realize that everyone does not have a zillion dollars worth of woodworking tools, but here are a few tips that I have found to make edging easier and look better.
1. Whatever wood you use for the case, use the same wood for the edging.. Unless you are going to paint the case, I wouldn't recomend mixing say, birch and poplar because it will be tough to get stain to match. Gel stain, maybe, but it takes some experimenting.
2. If you are going to use solid edging, don't face nail it because it is rare when the filler for the nail holes matches after staining. You can use wax or shellac sticks after finishing but exact matches are rare. Use glue alone or biscuits. Use clamps or masking tape.
3. Iron on edge banding is great if you do it in the right order. Never have had it peel off. Your final finish will also hold it in place. Sorry Ironhorse. It has always been my experience that it is better to edge band all parts (front, side and dividers) before you assemble the case. The banding is wider than 3/4" plywood and doing it after the case is assembled is a nightmare because it is almost impossible to keep it straight when ironing it on (I know from experience) Keep the iron moving while pressing hard and leave an inch extra for each end. The safest way to trim the excess is with an orbital sander with 80-100 grit. It takes a little time but if you use a belt sander then you might sand through the veneer on the plywood and you are screwed if you want to stain.
4. If you are using butt joints then go ahead and assemble the case. If you are using dado joints there are a few more steps. Once you have your parts cut out and edged, but not sanded flush. Cut a piece of scrap of wood to fit the dado or groove on the top and bottom pieces exactly to height and width of the groove or dado Set this piece in the dadoes and sand the edging flush. NOW, dry fit. The sides and dividers should be set slightly behind. Use a razor knife and score the edging on the sides and the dividers at the joint. Take it apart. Cut through the edging with the razor knife at the score. Use the iron to heat up edging and remove the cut piece. Reassemble case and glue. This should give nice perpendicular joints with edge banding.
5. Face frames are great for minimizing racking but they take away from component width and height available from the front but it does give a more traditional look to the furniture. Make it a your stand little wider and a little higher. You could also do one in back so there is no compromise with air circulation.
Sorry to be long winded on my first post.
Dadetigl
dadetigl is offline
post #115 of 1481 Old 11-23-2004, 10:08 PM
dadetigl's Avatar
Islandview,
Great design, But there are a few things you may wish to think about especially with that new baby coming home.
An 8' tall case with a 22" depth is very unstable. Either on hardwood or carpet. Children love to climb. Most components are 17" or less in depth so they will be set closer to the front which will make the cabinet even more unstable.
Cases that size are usually attached to the wall behind them at the top and bottom. If you need to move the case for viewing on castors, at least attach it to the wall a steel cable short enough at the top and bottom that will prevent the case from falling over and spilling it's contents on the person and also prevent it from kicking out.
I love my new samsung dlp,
Dadetigl
dadetigl is offline
post #116 of 1481 Old 11-24-2004, 12:17 AM
BB_Mike's Avatar
Islandview
I'm on the same bandwagon of your entire setup crashing to the floor. It' snot even the 22", it's less beause the wheels (and even the wheel centers) will be a bit further in.
Dadetigl brings up a goood point about the little ones climbing. It reminds me of the extra "tie down strap" that comes with Kitchen stoves. It goes behind the stove and holds it to the wall. So when the kids climb, they don't roll the stove forward! You could install something like this up on the top. Kind of a "Hook and hole" aparatust. Much like a screen door uses. Only yours will be MUCH stronger... maybe even one for each side. Something removable so you can still slide the whole thing out.
BB_Mike is offline
post #117 of 1481 Old 11-24-2004, 03:44 AM
Pablopsd's Avatar
Islandview,
Looks pretty cool. My 2 cents. The games above the tv might be a PIA when playing because of the cables, unless you have wireless controllers? They wires will hang in front of the tv.
Also, alot of people are addressing tipping over. Sub Zero refridergators are very top heavy and shallow. They address tipping by using 2 heavy L brackets, about 4" and tie them into studs, then they use a 2X4 across the brackets that the fridge slides under when you install. You might also be able to do something similar if you desire and hide it with the design. This would require being close to the wall.
Pablopsd is offline
post #118 of 1481 Old 11-24-2004, 06:18 AM - Thread Starter
IronHorse's Avatar
PabloPSD...
Nope, I'll be hanging around to stick my two cents in whenever I can. I've been around the forum since 2001, so I'm probably gonna be a lifer.
And BTW, IslandView, I like the amoire look, but these guys may have a point on the tip factor. You may want to reconsider your layout and weight distribution.
Iron Horse
Originally posted by Pablopsd
Hey Ironhorse,
Pablo
post #119 of 1481 Old 11-24-2004, 10:30 AM
islandview's Avatar
Thank you everyone for your thoughtful observations.
Regarding the potential for tipping I had planned for the existing book shelves that are going to be on either side of the AV unit to be fixed to the wall. The rolling unit will then "lock" into place between the two of them using a combination of four retractable 1" dowels (evenly spaced on either side of the vertical panels) and a 1' wide 3/4" painted plywood "cap" that will be secured to the top of each bookshelf spanning the gap. There will also be 2 1" retractable dowels inserted down from the "cap" into the top of the AV cabinet. Does this sound sufficient?
I appreciate all of your helpful comments and look forward to the results in the New Year!!
Cheers
K
post #120 of 1481 Old 11-24-2004, 10:46 AM
Kid Red's Avatar
The best way is a simple L bracket(s) mounted up top and anchored into the wall.
Kid Red is offline
Reply Rear Projection Units
