Build You Own (BYO) TV Stand - Page 47 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #1381 of 1481 Old 09-02-2013, 06:52 PM
33coupe's Avatar
I thought I would save money and do it myself. However, wood is really expensive, and I could not bare to look at my shoddy workmanship every night!
I found someone that has made these, and have asked for a price for something similar but adding a shelf to hold the centre speaker (I apologise for the sketches, I done them at work while no one was looking)
P1070011.jpg 103k .jpg file
P1050054.jpg 129k .jpg file
DSC_0586.jpg 935k .jpg file
Ive asked for sides and a back panel to try and keep the cables tidy. The concern is that it will get hot. I asked if the back panel could have many small drilled holes to allow ventilation but he wasn't sure on the idea.
DSC_0590.jpg 912k .jpg file
Does anyone have any examples of this? And do you think it would allow for adequate ventilation?
ID:	71785   Click image for larger version
ID:	71786   Click image for larger version
ID:	71787   Click image for larger version
33coupe is offline
post #1382 of 1481 Old 09-03-2013, 08:19 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
If you are putting your center speaker over the receiver on a shelf I would say no the holes in the back won't be sufficient. What I did was install 2 cooling fans directly above my receiver and behind the center speaker through a cutout in the shelf.
colour is offline
post #1383 of 1481 Old 09-03-2013, 09:04 PM
33coupe's Avatar
Thanks for the reply, really appreciated.
Yep, I think the receiver below the speaker would look the best.
I am aware that my receiver can get pretty warm (onkyo nr515), so I have made sure with my dimensions that there is enough room around it, but I am still concerned.
I did consider that if the back panel didn't work, I could cut a bigger hole out and attach a usb powered fan (or two!).
I am now wondering if there is an alternative product / material that I could use for the back, i.e metal mesh???
33coupe is offline
post #1384 of 1481 Old 09-03-2013, 09:28 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I also have an Onkyo that runs hot, been in use everyday for 4 plus years with only 1 inch of space above. But I have the cooling fans and the back at the receiver only is open, too many wires out the rear to have it closed anyway. My fans are plugged into a smart strip controlled by my TV, TV on, fan on my TV has a fan that runs for a few minutes after shut down so it continues to cool my AVR after it's been shut down.
colour is offline
post #1385 of 1481 Old 09-16-2013, 01:03 PM
yomike007's Avatar
Anyone have any clue how to go about doing the middle floating glass shelf in the cabinet below? I just feel like even .5" tempered glass would shatter if only supported on one of its edges.
yomike007 is offline
post #1386 of 1481 Old 09-16-2013, 04:25 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
The tempered glass isn't the issue, it's the system supporting it. If it's not strong,rigid and holds the glass like a vise it will sag depending on the weight of the item placed on it and the weight of the glass.
colour is offline
post #1387 of 1481 Old 09-17-2013, 05:30 AM
billybobg's Avatar
Quoted: 38 Post(s)
Liked: 45
H
There has to be support at the rear. Not sure why you're interpreting photo without support. A floating shelf, if incorporated would be in front, not the back.
Home Theater Man Cave: Onkyo 7.1 Klipsch LaScala Mains, Shortened LaScala Klone Center, Klipsch Academy Surrounds and Rears; Panasonic AE8000, Panasonic BDP 460, 117" DIY Screen.
Garage Man Cave: LaScala Industrial Splits; Second hand Denon Amp
billybobg is offline
post #1388 of 1481 Old 09-17-2013, 06:54 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
Originally Posted by billybobg View Post
H
You have no clue what you're saying, where did I say it didn't have a support? I said just the opposite. Looking at the pic provided the end shelves are supported on the sides and the middle shelf you can't see how it's supported.
colour is offline
post #1389 of 1481 Old 09-17-2013, 07:10 AM
billybobg's Avatar
Quoted: 38 Post(s)
Liked: 45
Cool down I really didn't mean to cause an issue. Sorry I misread your post. The TV in the pic is near an edge and tempered glass is strong. They could have either made a dado or used shelf brackets. I've stacked a lot of dishes on tempered glass with no issues, though the span in the pic is larger than moat cabinets . Newer tvs do not weigh very much and I suspect glass would hold many units.
Sorry you took my earlier post so hard.
Edit: I just looked at the photo on a desktop and it appears that there are supports going from front to back to hold the glass. At .5 inches the glass will support quite a bit. It is not solely supported by the front, IMO.
post #1390 of 1481 Old 09-17-2013, 08:06 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1059 Post(s)
Liked: 987
The picture is so small, that it's tough to draw too many conclusions from it... But it looks like there's at least a black panel in the back starting about 1/4 of the width from the left. It also looks like there are black vertical dividers (front to back) at 1/3 and 2/3 of the cabinet width. So they probably cut dado's in the front finished board, the vertical dividers, and the rear panel and slide the glass into them. It doesn't strike me as something I'd want to trust supporting expensive gear on (and the design isn't really to my taste anyway), though it would be interesting to see what sort of weight they rate the shelves for.
gsr is offline
post #1391 of 1481 Old 01-26-2014, 09:23 AM
ski2slow's Avatar
I am thinking of building my own Salamander Synergy clone.
Does anyone know what thread size is used by Salamander?
I am thinking of buying their Leveler Feet since they look nicer than anything else I found online.
Panasonic TC-P60ST60
Polk Audio RTiA7(x2) + CSiA4 + FX50i(x2) + PSW404
Panasonic BDP-BDT500
Anthem MRX-300 AVR
ski2slow is offline
post #1392 of 1481 Old 02-15-2014, 03:54 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
The 80/20 15 series aluminum framing they use has a 5/16-18 thread size. The top bolts are all 5/16-18 joint connector bolts. The feet, I assume, are the same thread size.
Here is the user's manual which details the part numbers. You can call or email Salamander Designs and order the parts.
http://www.salamanderdesigns.com/products/download_items_file/manual_sq_500935.pdf
http://www.salamanderdesigns.com/products/details/a5300392-0b36-5796-b0ba-5125e24f9434
Yes, I found out they are indeed 5/16"-18 threads.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #1393 of 1481 Old 03-24-2014, 01:01 AM
rimmi2002's Avatar
Quoted: 42 Post(s)
Hi I want to build a simple and cheap TV cart for my temporary residence. Here are my basic needs.
Length 84 inches
Width: 18 inches
Height 10 Inches.
The card in going to have 3 compartment. As pictured in my bad schematic below. I was wondering is it possible to get to ply wood board cut to specification and to make top and base and adding support panels in bettween?
The cart is going to hold a 60 lb TV and two 15lb bookshelf speakers. I have no carpenting experience but will this simple design work?
I'd like the cart to have a dark cherry wood finish any paint people recc'd? Also any plywood you recc;d? I'm looking for something to last me about a year only. Thanks!
! ..........Reciever ...........!.........Center Channel..........!.........HTPC..............!
rimmi2002 is offline
post #1394 of 1481 Old 03-24-2014, 06:55 AM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 278
I figured I will show mine. It's about 90% done. I searched for my needs all over the net and either it's was too expensive or not fitting everything I needed. This thread gave me the inspiration to build my own. I have woodworking skills but just did not feel like a project.
The stand is 85 wide X 26 tall X 21 3/4 deep. The tv on there now is my sons 42" just for fitting purposes. My 60" Sony will be going there instead. I have a 100" motorized projector screen that will come down in front of the Sony. That is not its spot where it's going just out of the way while working on it.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #1395 of 1481 Old 03-24-2014, 07:54 AM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
Very nice!!.... Oak?
______________________
__________
Dave
moonhawk is offline
post #1396 of 1481 Old 03-24-2014, 10:24 AM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 278
Yes.
bluer101 is offline
post #1397 of 1481 Old 04-10-2014, 10:37 AM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 278
All finished.
cr136124 and TeflonSoul like this.
bluer101 is offline
post #1398 of 1481 Old 04-13-2014, 08:08 PM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
All finished.
__________
Dave
moonhawk is offline
post #1399 of 1481 Old 04-13-2014, 08:20 PM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
All finished.
It looks fantastic!
I really love your HDTV / PJ screen combo, but If I have to pick one.........I'll go with the badass pull down screen.
Congrats!!!
cr136124 is offline
post #1400 of 1481 Old 04-15-2014, 11:19 AM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 278
Thanks, here is build thread. http://www.avsforum.com/t/1526213/tv-projector-screen-console-build/0_60#post_24605631
This is all completed with screen valance.
TeflonSoul likes this.
bluer101 is offline
post #1401 of 1481 Old 07-01-2014, 01:02 PM
Shape of Grey's Avatar
Holy resurrection, Batman!
Ok guys, I need some help/advice. I've recently finished my DIY stand (first attempt at something like this) and it actually turned out better than I had expected for my first attempt. Now, one of the finishing touches I wanted to do was to add a drawer for storage. In there lies the problem, likely due to my inexperience...so that is why I turn to the experts. What would be my best/practical option (for my skill level) as far as building and mounting a drawer? Just want it to be flush with the front of the extrusions.
Some visual aidon't mind the dust :P
1.
2.
3.
Let me know if additional info is needed.
Shape of Grey is offline
post #1402 of 1481 Old 07-01-2014, 02:29 PM
billybobg's Avatar
Quoted: 38 Post(s)
Liked: 45
1.
2.
3.
Add a middle shelf. Get drawer slides that fit under drawers and build boxes for the drawers. Cut drawer fronts to match the openings and attach. This method relieves you from building cabinet sides.
post #1403 of 1481 Old 07-01-2014, 03:17 PM
Sorry I should have probably explained a little better. There already is a middle shelf (you can see the shelf brackets in the pix) I just took it out to open things up for diagrams. The biggest issue I'm having is how/where to mount drawer slides; and what time of slides to use.
post #1404 of 1481 Old 07-01-2014, 09:47 PM
billybobg's Avatar
Quoted: 38 Post(s)
Liked: 45
Undermount drawer slides.
post #1405 of 1481 Old 07-08-2014, 11:16 PM
chenw92's Avatar
Liked: 0
1.
2.
3.
I would add rollers under the bottom shelf and roll it out. There may be extrusion accessories that you can use as rails to attach to the extrusion itself.
I have a question on the shelf pegs. Where did you get them from? I have not been able to find these online at all. The ones from extrusion manufacturers does not look nice at all.
chenw92 is offline
post #1406 of 1481 Old 07-09-2014, 05:10 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 987
The shelf pegs can be ordered from Salamander.
gsr is offline
post #1407 of 1481 Old 07-09-2014, 09:14 AM
Yup, that's where i got them from. I bought a hardware kit which contained feet that screw into extrusions, shelf pegs (3 set), the top fastening bolts, as well as rear faceting bolts for the backer. All together was $42 shipped.
post #1408 of 1481 Old 07-09-2014, 10:17 AM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
1.
3.
You can always add one piece of the 80/20 1515 from front to back with a T-Connector and then mount some ball bearing soft close drawer slides (Home Depot or Lowes). Then the top shelf can be adjusted to sit just over the top of the drawer to hide it.
You can use these to make 90 degree angles with the 15 series extrusion.
post #1409 of 1481 Old 08-17-2014, 01:09 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Defibrillator, stat! Clear!
Time to resurrect this thread.
I have decided, after much deliberation and planning, to go all wood on my TV stand. I have purchased all of the tools needed and have also drawn up some 3D models in Google Sketchup.
post #1410 of 1481 Old 08-17-2014, 02:05 PM
bluer101's Avatar
Quoted: 345 Post(s)
Liked: 278
Nice, that is big and almost like mine I built. Mine is a few posts above yours with link to my build thread.
In your sketch you have your surge protectors in a recessed area. I did almost the same just to run my wires back and forth hidden out of view.
bluer101 is offline
Reply Rear Projection Units
