Sony KDF-55/60XS955 owners thread - Page 96 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #2851 of 2857 Old 12-01-2013, 08:46 PM
Wildcat445's Avatar
Originally Posted by ChuckF. View Post
You would have to remove the Panasonic polarizer and glass mount from the Panasonic mounting frame and mount it in the Sony frame, which is not difficult.
That does not sound too difficult--the glass must be the same size then?
The blue LCD panel is most likely OK in this TV, and I have two spares on hand. Not a single blue pixel to be found. smile.gif
The brown is most likely from the bulb--the display is dim, and takes awhile before the bulb warms up and illuminates. I ordered a genuine Osram bulb yesterday. (Even if it is not the bulb, at least I have a spare on hand.) The previous owner said they replaced the bulb, but it has two things against it: 1) generic Chinese, and 2) no ventilation until I cleaned it up. With the duct beyond the light engine's cooling fan having some of that brown crud in it, I would think the innards got some of it as well.
One thing I notice with burnt polarizers is that they tend to burn around their perimeter more so than in the middle. Even in my rebuilt light engine, there is very faint yellowing around the edges. It's something only I would notice, it's that faint. But it's there.
One thing I don't understand is how there was heat damage inside the set (the bulb area almost looks burnt), and yet the blue LCD has no problem. Upon disassembling it a few weeks ago, I can see that someone else had been inside the set and worked on it, as a couple of the wire ties were not closed, and one of them had one of its tabs busted off. I have a feeling it was worked on at some point...but how long ago? No clue. Just seems fishy it looked like it had a bulb blow out from overheating, yet I don't have the blue pixels or the bright yellowed image due to a roasted polarizer. No worries though--I have the patient well on the road to recover! And I'm learning a lot as I go.
Listen with your EARS, not your SPECS.
Wildcat445 is offline
post #2852 of 2857 Old 12-07-2013, 07:30 AM
Wildcat445's Avatar
The new Osram bulb arrived Thursday, and it was a cinch to remove the old bulb from its plastic "cage". Two screws along the top edge release a metal cover on the top. Another two screws loosen the two prong connector on the bottom. The bulb will literally fall out at that point. The leads are held onto the bare bulb with two small nuts. Simple job to replace the bulb! Comparing it to the bulb I replaced, I can see how much better the construction of the bulb is--I can post a picture later of the innards of both. The generic Chinese bulb has a single metal lead inside the glass going to the center. The Osram's metal lead is much more complex. IOW, the generic just looks cheap.
The UV cover over the bulb, however, is not faring so well. Due to the overheating, the top lip is warped, and I also discovered that it has become brittle. In a way I wish I could find a dead equivalent to these sets and use it for parts, but I don't have room to be storing another whole large TV. Might keep an eye open on FleaBay for one.
At any rate, the picture is vastly improved, and the brown tint is gone! And it is far brighter. The TV still takes a lot longer than the 50" to warm up, though. I still need to go in and reset the bulb counter. The picture is a bit warm on Normal, but a wee bit bluish set on Cool.
I still think the whole thing could use a cleaning inside (even the mirror that projects onto the screen), based on the crud I found that got caked onto the fan. There is still that odd iridescent tinge to the bottom of the picture whose pattern almost reminds me of smoke. Seeing from the UV cover that a prior bulb had a catastrophic meltdown (and I actually did find smoke residue in there from it), I may not be far off. Maybe during the holidays I'll strip 'er down and give it a thorough cleaning--light engine, mirror, screen, etc. Otherwise it is looking pretty darned good now!
post #2853 of 2857 Old 12-16-2013, 07:42 PM
adb3da's Avatar
My Sony SXRD recently developed what I would describe as a shadow. It's most obvious on dark objects on a light background (text on a white screen it the worst) but it seems that the display is generating a duplicate shifted image to the left of the main image. Is this a convergence issue? Any chance this could be adjusted easily? I think older CRT projectors had this issue as they age. Any chance I can fix this without spending any money?
adb3da is offline
post #2854 of 2857 Old 08-08-2015, 07:32 AM
dchantrill's Avatar
Liked: 2
After ten years of faithful service, I finally decided to retire my KDF-60XS955. It was my first HDTV, and I loved the picture and the features on this model. I stuck with it through three bulb replacements and two light engines. But the straw that broke the camel's back was when a spider got inside and spun a web across the Red LCD panel! I couldn't figure out why the red channel was so blotchy, so I took it apart to have a look. The attached picture shows what I found. The spider was still there; my daughter says I jumped a mile when I opened it. I cleaned the LCD panel and put everything back together, but I couldn't get it to work right, so I decided to retire it. I have replaced it with a Sony XBR65X800B 65" 4K model (my wife said "You have me hooked on the big picture now, it has to be at least 60" ) Farewell, my good friend.
DaverJ and mtbdudex like this.
dchantrill is offline
post #2855 of 2857 Old 08-08-2015, 08:04 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 781
Arachnids can freak anybody when not expecting to see them.
My 42" version of this still going strong after 10 years, it's now serving duty in our basement guest bedroom.
Sure, only 720p but it's paid for and works.
Via Mikes brain/thumb interface, LLAP
mtbdudex is offline
post #2856 of 2857 Old 01-21-2016, 09:29 AM
Originally Posted by jfvary View Post
Hi guys,
I own a KDF-60XS955 and I have the infamous blue line problem.  I'm looking forward to repair the OB either by replacing the LCD panel or the Blue polarizer or both.  Obviously, I do not want to buy a polarizer if it is not dysfunctional (plus tri-state module do not have them in stock so...).
So from your experience guys, would you say the polarizer or the LCD is faulty in this case?  Here are some pictures:
Hi guys, after more than two years having the TV in storage, I've successfully repaired it| I've bought a set of LCD on Tri-state module (#LCX043Axxx) and the TV works like new. There is a comprehensive walkthrough on youtube. Simply search for "Sony LCD TV Blue Dots Blue Fog Blue Stars Repair" video by norcal715.
Thanks for your input!
DaverJ likes this.
jfvary is offline
post #2857 of 2857 Old 01-26-2016, 01:04 PM
Wildcat445's Avatar
Turns out my 42" is rarely used, and the 50" really doesn't have as clean of a picture as I'd like. I may list them on CL locally. They're great for a basement or spare room, but I need something better for gaming, and at least 60", and wall mountable. I need at least four reliable HDMI inputs. The HDMI on the 50" does not connect well, and the switchers I buy only last about a year and they're toast.
I still do wonder about the 42" set's brownish picture, but not enough to tear it down just yet. I am also due to take them apart and clean the fans. They were great for the minimal cost while I've had them.
Reply Rear Projection Units
