Samsung HLRxx67W Owners Thread --- 720p DLP HDTV - Page 134 - AVS Forum
post #3991 of 4019 Old 10-20-2012, 06:27 AM
jlk_250's Avatar
I have had to replace the bulb once, color wheel once, and bulb cooling fan once, in that order. Bulb went out at 12,xxx hours so not too bad at all since it's probably at 17,xxx now. However, the analog board has nrn going out for a long time and now the TV is retired due to digital board issues. Replacement LG LED TV is fantastic.
jlk_250 is offline
post #3992 of 4019 Old 10-20-2012, 06:54 AM
videobruce's Avatar
Quoted: 374 Post(s)
Liked: 178
12k for the lamp is a excellent count.
Anyone else with issues with just the color wheel and fans? The reason for the specific question is a friend has a HLR4266 (the cheapo) and it sounds as it's the color wheel that is going. It's not the lamp fan for sure. I don't know how many other fans are on that chassis; one or two as i might be that, but I doubt it.
Abundant OTA television is what makes this country different from all others. Lets keep it this way. If you like Wi-Fi so much, OTA fits right in. After all, it is wireless.
videobruce is offline
post #3993 of 4019 Old 11-24-2012, 08:29 PM
fmoraes's Avatar
Hi,
I've had my HLR4267W for several years, have replaced the color wheel before and the lamp. Now, recently, the screen seems to go from normal brightness to slightly darker and back to normal darkness every few minutes. I have not timed the interval between but I have a feeling it is becoming a little more frequent.
Is this my light bulb going bad again or something else? Last time, I remember the screen was getting darker over time, but nothing like this. I just want to have an idea what could be wrong. If it is anything more than a light bulb, it may be time for a new TV.
Francisco
fmoraes is offline
post #3994 of 4019 Old 11-30-2012, 07:05 AM
AzDragonLord's Avatar
Originally Posted by fmoraes View Post
Hi,
Francisco
Could be the ballast giving you trouble ...it powers the bulb.
AzDragonLord is offline
post #3995 of 4019 Old 11-30-2012, 07:53 AM
fmoraes's Avatar
Is there a way to know or tweak it to be sure? I am trying to decide if I fix the TV or get a new one. Ballast + new lamp and we maybe talking about near half the price of a new TV.
Francisco
fmoraes is offline
post #3996 of 4019 Old 12-02-2012, 07:31 AM
Francisco
Only way I know is to replace one component first (bulb or ballast), then if you still have trouble replace the other.
I got lucky a few years ago and bought an identical TV online and I used it for my XBox. I've since replaced my main TV and both Samsungs are now in my XBox room. I'm saving one for parts. The ballast is going out on mine (already has a new bulb), but I haven't swapped it yet.
post #3997 of 4019 Old 12-12-2012, 08:15 PM
mikewpg1ca's Avatar
Hi, I just posted a new thread in this forum describing a display problem relative to a Samsung HLR4667W, perhaps some fellow HLRxx67W owners in this thread could have a look and see if it's a problem they've encountered or know of. Thanks a lot.
http://www.avsforum.com/t/1445011/samsung-dlp-tv-hl-r4667w-grey-screen-until-warmed-up
mikewpg1ca is offline
post #3998 of 4019 Old 12-28-2012, 07:05 PM
Just checking in...nothing new to see here.
post #3999 of 4019 Old 12-29-2012, 01:58 AM
videobruce's Avatar
Quoted: 374 Post(s)
Liked: 178
For a $500 (or so) LCD set? I'd stay with this even though it's only a 720p. wink.gif
post #4000 of 4019 Old 02-08-2013, 06:15 AM
Just keep moving.
post #4001 of 4019 Old 04-13-2013, 06:26 AM
Nothing to see here.....move along.
post #4002 of 4019 Old 04-13-2013, 10:31 AM
scheibler's Avatar
My 61" has dark transparent horizontal lines for the first 2-3minutes it is powered on then the picture goes to normal. Any ideas?
scheibler is offline
post #4003 of 4019 Old 05-15-2013, 10:35 AM
No... Sorry.
post #4004 of 4019 Old 07-07-2013, 10:29 AM
iowahawkeye's Avatar
After 7 years & 10 months and no repairs done, my HL-R6167W died yesterday. It started making a squealing noise and then noticed every thing/channel was B&W, so I assumed the color wheel died. There also has been a slight flickering of the brightness the past several months. It still has all the original parts, but decided that spending $275-$300 replacing the wheel, lamp & ballast on it was not worth it. Replaced it with a Samsung UN60F6350A, 60" LED Smart TV.
HD since Sept 2005
iowahawkeye is offline
post #4005 of 4019 Old 07-07-2013, 11:16 AM
ThreeSoFar's Avatar
RIP
When ours ever goes we're going to need a new piece of furniture for the new one. That'll be an expensive hit.
But for now, ours looks great.
ThreeSoFar is offline
post #4006 of 4019 Old 07-08-2013, 01:37 PM
Mine still growing strong doing Xbox duties on the weekends. I also have a second identical model to use for parts when needed.
post #4007 of 4019 Old 07-08-2013, 08:38 PM
fburgerod's Avatar
I replaced my color wheel myself and put a new lamp in at the same time. All for less than $200 and the TV looks fabulous! Pretty easy DIY fix.
fburgerod is offline
post #4008 of 4019 Old 07-12-2013, 10:41 AM
For the first time ever, I looked into the service menu to see what the lamp hours was at before it goes to the dump next week. 8993 hours. It's always been in the lower level family room, where it 3-5 degrees cooler, and with the central A/C on in the hot/humid weather.
HD since Sept 2005
post #4009 of 4019 Old 07-15-2013, 02:12 PM
Update: I have a relative who is having his w/o basement finished off, and he's willing to pay for the color wheel if I put it in. So I guess it's not going to the dump after all.
AzDragonLord likes this.
HD since Sept 2005
post #4010 of 4019 Old 08-05-2013, 04:20 PM
After about 2 hours, I successfully replaced the color wheel. Wheel was 90% shattered. Still running the original lamp.
Thanks the OP that posted this: http://www.avsforum.com/t/1050735/detailed-guide-to-replacing-the-color-wheel-in-a-samsung-hl-r6168w-w-photos
HD since Sept 2005
post #4011 of 4019 Old 08-05-2013, 05:37 PM
Good to hear you kept it running!
post #4012 of 4019 Old 08-05-2013, 09:24 PM
fburgerod's Avatar
Wonderful, dude (or dude-ette)! Enjoy the renewed Sammy.
post #4013 of 4019 Old 12-30-2013, 08:43 PM
ThreeSoFar's Avatar
I'll be retiring our 42" soon. $389 for an LED solution.
Anyone interested in this one?
I have my original lamp in a box still with only 3K hours I think, and the one I replaced it with is still good, too.
I assume the color wheel just went. Horrible loud humming sound now and the colors are off.
post #4014 of 4019 Old 01-01-2014, 05:09 AM
It'll be a good parts-machine, but Baltimore is a little out of my range.
post #4015 of 4019 Old 06-07-2014, 09:41 AM
light0070702's Avatar
My Sammy TV turns on but is in a boot loop any help to solve the issue plz help
light0070702 is offline
post #4016 of 4019 Old 10-15-2014, 08:35 PM
ryryap2's Avatar
Liked: 0
Bump for this thread!
in need of assistance for a HLR4667W TV. I have replaced both lamp and color wheel and the TV is making a strange high pitched noise and progresses to a low pitch. Much like an 8bit video game sound of a bomb dropping. Anyone here have that issue?
Hoping this thread returns from the Dead!
Thank you all for your help.
ryryap2 is offline
post #4017 of 4019 Old 10-15-2014, 08:37 PM
ryryap2's Avatar
Liked: 0
OH man I took a look at my profile, Joined in 2011 and 0 posts. LOL
I dont even know why i joined in the first place
ryryap2 is offline
post #4018 of 4019 Old 10-16-2014, 02:23 PM
Not sure, as mine still runs quiet. Is it coming from the back or from the speakers? If you run it with the back off and listen carefully you might be able to narrow down the source.
post #4019 of 4019 Old 10-16-2014, 02:59 PM
ryryap2's Avatar
Liked: 0
Thumbs up
Thank you for your reply,
I have run the TV with the back cover off and it sounds like its coming from the ColorWheel. Thats the reason why I replaced the colorwheel in the first place.
We bought a brand new colorwheel and a brand new lamp, both replaced and it still makes the noise. I'll try to get a recording up to give you guys an illustration.
Cheers!
ryryap2 is offline
Reply Rear Projection Units
Samsung , Lcd Hdtv
