Samsung HLRxx67W Owners Thread --- 720p DLP HDTV - Page 135 - AVS Forum | Home Theater Discussions And Reviews
post #4021 of 4028 Old 09-14-2015, 03:54 AM
AzDragonLord's Avatar
Quoted: 51 Post(s)
Moved my trusty old 46" Samsung to my living room yesterday after my 73" Mitsubishi DLP went belly-up for the 2nd time in it's 3-year life. Now that it's out of warranty I'm not sure I can repair it.
My Samsung has been repaired twice...once under warranty and once by me, but even after 9 years it still has a clear and bright picture with eye-popping color! This is why I love DLP technology! The image on the Mitsubishi was never this good though. Too large a screen I suppose for a single bulb to illuminate.
Media Computer Specs
ASUS H87M-E LGA 1150....Intel Core i7-4770 Haswell....Intel Network Adapter....8GB DDR3 SDRAM....Windows 7 x64.....Plex....Drobo 5N....Drobo Gen2
AzDragonLord is offline
post #4022 of 4028 Old 09-15-2015, 05:34 PM
Stoney Jackson's Avatar
Quoted: 78 Post(s)
Liked: 83
My HLR4266W started making a huge buzzing sound, and the picture won't come on. I'm guessing this is the color wheel failing?
Sent from my SD4930UR using Tapatalk
Stoney Jackson is offline
post #4023 of 4028 Old 09-26-2015, 05:22 AM
Quoted: 51 Post(s)
Quite possible, or it could be one of the cooling fans. There are three if I remember right. You would need to open it up and check closer to be certain.
post #4024 of 4028 Old 09-26-2015, 01:39 PM
Quoted: 78 Post(s)
Liked: 83
I took it apart yesterday, the color wheel is shattered. I'm leary about replacing it though, unless someone who has done so can answer a question. If the color wheel is broken, will the lamp still light? Since my color wheel has broke, the lamp won't light, and the 3 lights on the power button flash. I don't want to replace it for it then to need a lamp replacement.
post #4025 of 4028 Old 09-26-2015, 02:45 PM
Quoted: 51 Post(s)
I believe there is a sensor on the color wheel, and without that signal the lamp cannot light. Lamp replacement is no big deal, and if you can get a replacement color wheel at a decent price it may still be better than buying a totally new TV.
post #4026 of 4028 Old 09-28-2015, 03:57 AM
Quoted: 78 Post(s)
Liked: 83
Thanks for the help, and It was just the added expense of the lamp I was worried about. I'll keep my eye on eBay for the color wheel. If I can get one around $60 I'll do it.
post #4027 of 4028 Old 08-18-2016, 03:19 PM
Quoted: 51 Post(s)
::ding::
post #4028 of 4028 Old 08-18-2017, 04:52 AM
Quoted: 51 Post(s)
Nothing to see here.....move along.
Reply Rear Projection Units
Samsung , Lcd Hdtv
