(This is a compilation of my previous posts in other threads. I will now try and only post here on the new offical thread)
MY TV arrived about 3 hours ago. As this is my first DLP, HDTV or even larger than 27inch TV, I will not try and make too many comments
As requested here is a picture
HLR5067w on coffee table
My setup for now:
Digital cable via Tivo via coax on antenna input
Direct cable via coax via tuner input
Progressive scan cheap DVD via component inputs
I don't own a PS2 or any other console, so I can't test for you
HD Cable DVR arrives this week. TR46x3 stand arrives this week. Getting new composite cables for DVD this week. However, see below for HD comments
1) TV Guide setup comes on as soon as you turn the TV on. For me it makes little sense to use as I watch everything through a standalone Tivo, which controls my cable box changing. However I did set it up. You can setup the guide via a direct connection without a box as per the instructions. The directions say it D/L data when the TV is off...which it hasn't been yet. (Update; nothing came down last night, I have to see what I did wrong)
2) The 50 sits flush...no pedastal or extra feet
3) I currently have it on my Coffee table. Samsung TR46x3 is due to arrive Tuesday. Note: As I said in a previous post, that stand is only 17.8 inches deep and works with the 46,50 & 56.
Review:
The Good:
I have not seen any rainbow effect at all. However, I didn't see them on the HLN model either at a friends house
I now have the PC display working perfectly at 1280x720. I played a few games OK, although Act Of War did not want to play. i will try additional setting for AOW tomorrow
I do not hear the fan at all
When pressing the source button on the remote, only connected sources are selected. Any source that is not used, is skipped
The Bad:
You can not turn DNIe off. There is a DNIe demo setting, that just splits the picture in half to show you what DNIe does for you. Half the screen has it off and half on with labels on each side. however, this setting is more of a setting to sell the box and has no use at home. They even have a DNIe demo button on the remote, again of no use for home use. These type of things really bug me. Some have asked if DNIe only works on certain inputs. As, there is nowhere to change it in setup, I will never know which setup it works on. Please note: DNR can be turned on and off.
The side inputs do not have a cover on them and are exposed at all times. I think for those who use the side inputs, this is a good thing. For those that don't, a cover would be nice.
The picture size button is not on the main part of the remote, it is behind the little slide cover. I am not sure if I like it here
Yu can not swap PIP directly from the remote, nor can you change the pip size,placement or layout. All these settings have to be done from the menus. You can turn PIP on/off and change chanels of PIP from the remote (channels are changed via the secondary channel buttons under the remote slider)
The Ugly:
Nothing, especially not the picture.
The picture is great, even the SD stuff. I don't have access to HD content yet (Comcast arrives Friday), so I can only expect it to get better. I did have an early problem with my TIVO picture, but that was due to crumby cables. I now have Tivo comming in via the coax antenna in, and even that is great. As for DVDs, even without component cables, the picture is great. I can't wait to get the new cables tomorrow.
Update: Due to the built in tuner, when you connect cable directly to the TV you can see the unscrambled HD channels on the digital channels (110-2, etc). The HD picture is great. I have only watched some PBS HD stuff as the networks didn't have any HD stuff last night when I finally got it setup.
