>>The Official Mitsubishi 1080p DLP Owners Thread<< - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #5221 of 5443 Old 02-23-2011, 12:53 PM - Thread Starter
Hyabusha's Avatar
Quoted: 79 Post(s)
Liked: 58
Originally Posted by Hollywood165561 View Post
I have the 60738 model, and a PS3. I have not bought anything for it 3D related yet as I was saving up a few weeks for the kit. I just saw the update (12.07) now and it looks like I might not need everything in the kit anymore. So if I use my PS3 for 3D gaming and blu-ray movies, the only thing I need to buy now is just the dlp glasses? No adapter or emitter?
These are some that I saw another poster mention.....
Xpand 3D Shutter Glasses
Xpand X102 DLP-Link 3D Revolution Glasses - Blue
NXG Technology NX-3DG Active Shutter Type 3D Glasses
thanks for any help.
Hollywood, when you update your firmware to 12.07 you will only need DLP link 3D glasses to enjoy 3D content from your PS3. If you want to use the glasses you described above, you'll need to buy a 3D emitter separately.
Go with,
Optoma ZD-101s
XpanD x103s
Viewsonics
These are DLP Link glasses which require no emitter.
Video Games, and Home Theater Forever! ^_^
My Theater Video-https://youtu.be/GdpdQgCSdW0
Hyabusha is offline
post #5222 of 5443 Old 02-24-2011, 08:42 AM
Hollywood165561's Avatar
^ Thank you so much!
Hollywood165561 is offline
post #5223 of 5443 Old 02-26-2011, 12:28 PM
BrownThunder's Avatar
Was watching TV the other day and I noticed a black spot on my screen, a tiny spec. After wiping down the screen, not only was that spot still there, but there were 3 more I noticed.
The TV is a Mitsubishi 65737 DLP. Bought it last year.
I've already taken the bulb cage out and blew canned air all around it and inside, thinking it was dust on there.
Spots still there.
Any ideas?
BrownThunder is offline
post #5224 of 5443 Old 02-26-2011, 02:07 PM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
1. A screen shot would help. Hoe large is this "spot"
2. It wouldn't be the lamp housing, but something in the optical path after the DLP.
3. Depending on how sharply focused they are, they might be on the outer lens assembly or on the inside surface of the screen itself.
Hopefully, lastly, they are not between the screens.
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #5225 of 5443 Old 02-26-2011, 02:09 PM
Thanks. I tried to post a link but it says I have to make three posts first...I guess I should be able to now?
post #5226 of 5443 Old 02-26-2011, 02:09 PM
post #5227 of 5443 Old 02-27-2011, 08:40 AM
Teapot's Avatar
I hope this question is not out of line for this thread, but has anyone put together the significant differences between the 4 current DLP series (638, 738, 838, 837) 3DTVs from Mitsubishi ? I've been searching for over an hour without success.
Teapot is offline
post #5228 of 5443 Old 02-27-2011, 09:40 AM
trapperjohnMD's Avatar
838 = shiny cosmetics, dynamic black, integrated 16 speakers surround sound, internet
738 = interent
638 = low cost option
837 = 2009 model, shiny cosmetics, dynamic black
trapperjohnMD is offline
post #5229 of 5443 Old 02-27-2011, 11:14 AM
TatorTot's Avatar
Is it hard to change the bulbs on the 60c10 ?
Im never good at these things
I tried to add more ram to my pc & i messed that up
TatorTot is offline
post #5230 of 5443 Old 02-27-2011, 05:17 PM
its about as simple as loading the dishwasher.
post #5231 of 5443 Old 02-27-2011, 05:39 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
It's as simple as putting ram in a pc. No really it's quite simple especially if it's already in the housing which is how Mits sells them.
colour is offline
post #5232 of 5443 Old 02-27-2011, 06:32 PM
TatorTot's Avatar
if is like this
than i can definitely do it
http://www.youtube.com/watch?v=HwpUigC1K-c
TatorTot is offline
post #5233 of 5443 Old 02-27-2011, 07:56 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
if is like this
Yes, but I would vacuum what you can before putting the new lamp in. And don't look dumb doing it like the guy in the video.
colour is offline
post #5234 of 5443 Old 02-28-2011, 12:44 AM
ElAguila's Avatar
I just set up my Samsung HW-C770BS AVR. I have 2 hdmi inputs on it. One comes from the blu-ray and one from my directtv hdr. I have have an hdmi cable going from the monitor out on the AVR to the HDMI 1 input on my tv.It is the only thing connected to the tv. It works fine until I turn off my tv. After turning on the tv, I have to go to the input settings and enable hdmi 2 and set it to satellite. Then I have to unplug the hdmi cable from hdmi 1 on the tv to hdmi 2. Then it works again. It is almost like it is not remembering or that it is seeing the hdmi connection as an audio only. Any ideas how to fix this? Before I got the samsung AVR I was using a switcher and I had component connected to the tv and it worked fine with the switcher. Am I going to have to use the component on the AVR as well?
Mitsubishi WD-Y577
ElAguila is offline
post #5235 of 5443 Old 02-28-2011, 07:24 AM
rickself3's Avatar
Anybody have a clue why my 60737 will no longer boot past the blue Welcome screen? The green light blinks rapidly but everythng is just froze. I have to hold the power button in for 10 seconds for it to shut down. TV will not react to any key combinations I've seen in the downloaded manual, doesn't recogbize the remote. Service guy is supposed to be here this afternoon, but I'm not sure if I'd rather just have them replace the TV. Manu date is Feb 2010. Buying through Aaron's so it is still under warranty.
rickself3 is offline
post #5236 of 5443 Old 02-28-2011, 08:22 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
Download and install the latest firmware from Mits site, if that doesn't work you need a new main board.
colour is offline
post #5237 of 5443 Old 02-28-2011, 08:27 AM
rickself3's Avatar
Thanks, colour. Hopefully the service guy coming by this afternoon has the software to install the firmware upgrade. I found the Aaron's policy states if there is any 'work' involved, they have to take the TV. Bites.
post #5238 of 5443 Old 02-28-2011, 09:42 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I wouldn't trust a TV tech to even turn it on much less install an update which is fairly simple. I replaced my main board myself one week after the warranty expired and one week before the update was released which supposedly fixes the "stuck on welcome screen" issue.
Even if it was under warranty I would have repaired it myself, had the part the next day and repaired in 15 minutes.
If it were me I would get ready to install the update myself, if they say the main board needs to be replaced don't let them take the set until the part comes in, meanwhile install the update if it's fixed cancel the service repair.
colour is offline
post #5239 of 5443 Old 02-28-2011, 10:01 AM
rickself3's Avatar
I'll see if that approach works. After all, I did find the update on the Mits website. But how this guy is going to know if the board needs to be replaced, it sounds like if they can't figure out the problem they'll take the set with 'em. I should mention that this is a rent to own. One year into the contract, I really don't want to bow out or frick it up now.
I'll suggest the update, which I already have downloaded and have ready to go.
post #5240 of 5443 Old 02-28-2011, 11:05 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
That's just it I think these guys just guess or call Mits for suggestions to repair. My guess is the update will fix it. If it's rent to own shouldn't they just replace the set?
colour is offline
post #5241 of 5443 Old 02-28-2011, 11:31 AM
rickself3's Avatar
That was my thought also. But the policy of Aaron's is to first try to fix and then replace. Oh, and while they have it out for repair, they supply a used 32" if they have one around.
Hoping I can talk this repair guy into trying the update first.
post #5242 of 5443 Old 02-28-2011, 02:45 PM
rickself3's Avatar
Well, the repair guy only knows how to drive the truck. His orders were to pick the set up. Aaron's schedule for sending out for repairs is Wednesday. We're out for 10 days. 10 days of 32" standard def.
post #5243 of 5443 Old 02-28-2011, 03:08 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
Should have done the update yourself.
colour is offline
post #5244 of 5443 Old 02-28-2011, 03:14 PM
rickself3's Avatar
Ya, regretting not doing so. I figured they'd void the warranty, but then they would not have been called. Good old hindsight.
Thanks for you input, colour.
post #5245 of 5443 Old 02-28-2011, 11:18 PM
any ideas on these spots?
http://i51.tinypic.com/2aih9uw.jpg
http://i52.tinypic.com/abqd6o.jpg
They're the same distance apart and the same size, so I'm really starting to doubt it's dust. I opened it up via the access holes and there was nothing on the actual screen, blew canned air all around and no reduction/motion of the spots.
Is this thing just dying?
post #5246 of 5443 Old 03-02-2011, 08:20 AM
jaseman's Avatar
Quoted: 34 Post(s)
The pictures are not very clear. But on a couple of the spots they look very pixel shaped. Maybe you have a few micro-mirrors that have died???
Vizio M80-C3 - Denon AVR-X4200w - Samsung UBD-K8500 - Roku 4 - Charter Spectrum - Logitech Harmony 700 Remote
Axiom VP150-v2 Center - M60-v2 Front Left & Right - 4>QS8-v2 Quad Polar Surrounds - EP500 Front Sub - DIY 12" Rear Sub
jaseman is offline
post #5247 of 5443 Old 03-02-2011, 08:58 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I think his problem has been answered in another thread he posted.....his LE needs replacement.
colour is offline
post #5248 of 5443 Old 03-02-2011, 07:15 PM
CptUnreal's Avatar
I have a WD-65831 Mits DLP and the lamp light goes red after 20 mins. But it will come back on. I have replaced the lamp about a year ago, so I suspect it is NOT the lamp (thou high usage load may effect this). Instead I think it could be the thermal sensor issue as noted by Mits. However, I have not seen anyone post on how to fix this and would like NOT to have to pay a technician to fix it. Especially when I read some reports that the sensor simple needed to be reseated. Does anyone have an idea how to do this?
CptUnreal is offline
post #5249 of 5443 Old 03-17-2011, 07:21 PM
Fourf's Avatar
From the looks of your pix you have persistent black dots. Soon you will see more and maybe even white dots on dark screens. In my case I ended up with about a couple hundred of each and made viewing impossible. Diagnosed as bad light engine. Replaced for $500 to new model 738.
Hope that helps Brownthunder...
Fourf is offline
post #5250 of 5443 Old 03-17-2011, 08:20 PM
videobruce's Avatar
Quoted: 663 Post(s)
Liked: 254
BrownThunder; From the closeup of the 2nd attachment, it surely doesn't look like a pixel problem since the specs are oblong, not square or round.
Reply Rear Projection Units
