Official 2005 Sony KDSR-50/60XBR1 SXRD Owner's Thread - Page 801 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #24001 of 24027 Old 12-01-2014, 07:47 AM
leoday's Avatar
Got my answer...time for a new tv.
leoday is offline
post #24002 of 24027 Old 12-06-2014, 06:18 PM
justerik's Avatar
Mine died.... Bad G board.
Sony says its NLA.
justerik is offline
post #24003 of 24027 Old 12-14-2014, 07:18 PM
bensons's Avatar
We have had the red light issue for about six months. I didn't realize how often it came up until tonight when my wife said the tv stopped working. She said that the red light kept coming on but she just kept trying to turn the tv on like she always does and it came on. After 20 minutes of use, it made a popping sound and stopped working. I'm thinking my plan to replace the fans has matured to something bigger. So much for being lazy and telling myself I would replace the fans "next weekend" for months.
Was hoping OLED would arrive before we needed to replace our beloved SXRD.
Steven Benson
Minnesota Home Theater User Group (MNHTUG)
Yahoogroups | Facebook
bensons is offline
post #24004 of 24027 Old 12-15-2014, 12:34 PM
ccrider2's Avatar
Quoted: 28 Post(s)
Twice when my lamp blew (replaced 4 or 5 since owning) it made a rather loud pop and after removing the lamp carrier, the bulb had visible signs of small 'ka-boom' inside the glass envelope, with bits of glass in the bottom ....rattling around. You might check to see if your lamp is blown. Of course, if you are having fan issues also, I suppose that could cause an overheat issue in the bulb area, since one of the many air cooling fans is in that area. .....BUT....I'm no tech wiz here, so, YMMV
Chris C
ccrider2 is offline
post #24005 of 24027 Old 12-21-2014, 06:49 PM
bensons's Avatar
Thanks ccrider2, it was the bulb that made the load noise. Just like you said, there were bits of glass inside the glass bulb housing, trapped inside. I also replaced one of the fans. My issue now is the image quality is now crap. Anywhere you would see a fade from white to black, it is not smooth. The gradient is not smooth as if the color changed to 256 from the original millions that it was prior to the problem. I went into the setting looking for setting that may address the issue but I cannot find anything that remedies the problem. Came back here hoping to find setting within "Pro" for advanced features. Tried turning everything off "DTE" etc and no joy. Ugggh. Was hoping $100 in parts would bring the set back.
Steven Benson
bensons is offline
post #24006 of 24027 Old 12-22-2014, 08:24 AM
ccrider2's Avatar
Quoted: 28 Post(s)
I've had my large fan out, while waiting on a new one to arrive, and lucky me, got it to free-up....working ever since.
I can't recall, and you've probably rehearsed this in your mind, what and if anything was disconnected while replacing the fan.
Just logical, if it wasn't doing this till....then perhaps something got bamboozled in the previous process. So if you haven't double-checked yet; might be worth the effort.
Other than that, I'm hoping a more experienced owner will chime-in here to offer advice on the new issue. There's some pretty smart 'cookies' here; although many have probably moved on to different hardware, thus no longer check-in.
I still love my paid-for SXRD, even though the picture is a bit .... ho-hum.
Best of Luck,
Chris C
ccrider2 is offline
post #24007 of 24027 Old 12-22-2014, 12:43 PM
bensons's Avatar
I love the picture quality of our SXRD. Rehashing the process, the TV worked great initially after going together. I watched 20 minutes of Avatar to confirm things were good. My wife also watched an episode of Arrow in HD. My kids watched some cartoons. When we turned on the TV later in the day, it had the issue described above and I am unable to get rid of it with settings. I'm going to pull everything back down and blow out contacts as I reassemble, but I'm setting my expectations low.
If the SXRD does not come back, I'm leaning towards a 65" Samsung 7150.
Steven Benson
bensons is offline
post #24008 of 24027 Old 12-22-2014, 01:09 PM
ccrider2's Avatar
Quoted: 28 Post(s)
Also looking at the 75" model this morning, some bad reviews on the Samsung site about the software being messed up, only a few (mostly having to do with the smart apps) but that has me worried. Haven't checked out AVSForum yet....more of a wait and make do for me right now. http://www.samsung.com/us/video/tvs/...0AFXZA-reviews
Chris C
ccrider2 is offline
post #24009 of 24027 Old 12-22-2014, 01:39 PM
ccrider2's Avatar
Quoted: 28 Post(s)
Try turning off then pulling the plug (as a hard reset) before the screwdriver comes out....Sony tech seems to likes that one.
Chris C
ccrider2 is offline
post #24010 of 24027 Old 12-22-2014, 06:04 PM
bensons's Avatar
Found the issue. There is a high density ribbon cable coming out of the optical block and going into a circuit board next to the large rear fan. I pulled the ribbon cable, blew air into the slot, whipped down the ribbon cable and reinserted it. Works like a charm now. Woot!
Looks like a tore off one of the tabs when removing the ribbon cable. Not sure how to keep that secure, or how to get the small metal plate (that goes around the female connector on the board) to snap back together around the connector. I am my own worst enemy.
ccrider2 likes this.
Steven Benson
bensons is offline
post #24011 of 24027 Old 12-22-2014, 07:11 PM
Liked: 0
I needed any speak program before nowadays along with e-support from Sony that they needless to say was without adequate knowledge because of this issue and they gave me a link to that same page you posted.
bearir is offline
post #24012 of 24027 Old 12-28-2014, 02:28 PM
Liked: 0
Hello all
I just bought a house that came with this tv 2005 Sony KDSR-60XBR1
The previous owner of the house said it has nice picture and all and all we have to do is replace the bulb which cost 75 dollars
Now whenever I turn it on, the red light comes on.
I checked the lower back of the tv and found the lamp which is supposedly blown and put it back in and tv still not turning on only red light
So do you think it does worth to spend $75 for a real lamp or 30$ for chinese to get this guy running?
Or buy a new one?
Antone bought the made in china lamps? are they bad? how long do they go?
misterno is offline
post #24013 of 24027 Old 04-29-2015, 11:24 PM
mrl859's Avatar
Since I replaced the light engine, the entire picture is off center left. Is there an adjustment in the service menu to compensate for this and adjust picture center?
mrl859 is offline
post #24014 of 24027 Old 04-29-2015, 11:25 PM
mrl859's Avatar
Also, it's got a blue tint. Can I adjust blue down in the service manual? My black screen is actually slightly blue.
mrl859 is offline
post #24015 of 24027 Old 06-20-2015, 12:26 AM
Location: Rural Carroll County Maryland, near the small town of Manchester.
Liked: 0
The cheap ones don't last. If they have expected life, you'll see that it can be only 1000 to 2000 hours. If you get a Philips lamp thru Newegg (Ness electronics) it's expectancy is 6,000 to 10,000 hours, plus they warranty it for a full year. I just bought one for $89.99.
Note: it's Philips, made in China. It is of highest quality, matches made in America bulbs.
Koren55 is offline
post #24016 of 24027 Old 10-05-2015, 01:32 PM
gforaker's Avatar
Just checking back in. Original owner of the XBR60 still looks fantastic and works perfectly. I had the light engine replaced at just under 3 years and it has kept going. I've replace the bulb one other time and it may be due soon, but still has great output. It is our main TV and gets around 4 hrs. of use per day.
audiomixer likes this.
gforaker is offline
post #24017 of 24027 Old 10-09-2015, 11:01 PM
Electric T-Bird's Avatar
Basically the same story with my XBR50, except I am still running on the original bulb.
Electric T-Bird is offline
post #24018 of 24027 Old 10-12-2015, 04:44 AM
tbAVS's Avatar
Wow, and I thought I was about the only one still watching a slightly dim 10 year old XBR60 while everyone else has upgraded to one of those super bright flat ones! Tempted, but it would probably cascade another flurry of updates; AV receiver, newer BR player, etc.. Sort of waiting for the original dim bulb to blow so I have an excuse to not spend money on old technology.
Meantime, the following has happened; Full 1080P, 3D, 120/240mhz, 4k, etc.. and probably more I've not kept up with.
tbAVS is offline
post #24019 of 24027 Old 10-12-2015, 08:16 AM
CCsoftball7's Avatar
Quoted: 1230 Post(s)
Liked: 950
I still have some bulbs sitting around for the 60" and 70" versions of these sets. My son uses the 60", but the 70" is long gone if anyone is looking for a bulb.
CCsoftball7 is offline
post #24020 of 24027 Old 03-10-2016, 01:00 AM
Liked: 0
sorry to be responding to such an old post - but this is the first time i have found anyone specifically referring to screen gradually turning green or BLUE (emphasis on "blue"). all others refer only to green/yellow tinting. my screen has become very cool BLUE wo the green/yellow blob. do you think this is the same underlying sxrd blue lcd panel fail as the green/yellow blob? i'm game for trying to DYI blue lcd panel replacement. what have i got to lose? already replace the crappy circuit board w the contact switch for the lamp door lock-out "safety" feature (the actual switch mechanism broke off). thx, - kyle the hoarder
merelyk is offline
post #24021 of 24027 Old 03-10-2016, 01:11 AM
Liked: 0
referencing "Splinke" post #23952. sorry - i can't figure out how to respond directly to "Splinke". not enough posts to send PM
merelyk is offline
post #24022 of 24027 Old 04-05-2016, 06:19 AM
splatee's Avatar
Quoted: 30 Post(s)
Just replaced the blue lcd panel on my KDF-70xbr950. It was not very difficult just need to have some patience. The hardest part was lining up the panel. This is the most time consuming part. I replaced my panel with a green panel off the big auction site. There is a real good youtube video showing the adjusting process. You basically have to have the optical block out of the tv and you adjust to adjust the panel.
splatee is offline
post #24023 of 24027 Old 04-22-2016, 05:29 AM
kucharsk's Avatar
Quoted: 1261 Post(s)
Liked: 685
Just wanted to pop in to mention I recently saw my Dad's 60XBR1 and it still looks better than most anything on the floor at Best Buy after its one and only optical block swap about six years ago now.
The colors and picture are absolutely stunning and the blacks are better than LCD but not as good as OLED.
Pity these turned out to be such finicky testy beasts.
kucharsk is offline
post #24024 of 24027 Old 05-05-2016, 11:11 PM
eternalthree's Avatar
hello,
i just picked up a r50xbr1 and it's such a beauty. unfortunately, the screen isnt coming on, although the audio is. i just replaced the lamp. where should i start if i want to keep this unit (which i do)? i believe i should start by replacing either the ballast or the qm board? unfortunately, i havent found any videos on replacing the qm board, but i did see the video on how to replace one of the optical blocks if necessary. the ballast looks fairly easy to replace, but the part looks a bit expensive at around 90$ off ebay. anyone have any suggestions? i'd really hate to have to throw this beautiful machine out. also, can anyone suggest a dlp repairer in the san francisco bay area?
thank you!
eternalthree is offline
post #24025 of 24027 Old 05-08-2016, 09:13 AM
splatee's Avatar
Quoted: 30 Post(s)
Originally Posted by eternalthree View Post
hello,
thank you!
I will try to help.
First you say you replaced the lamp? Is it a original Philips bulb or a generic one? Is the lamp firing? Can you see it turning on? Does the screen light up? If so i would believe that the ballast is working.
When the tv is on are you able to get the menu to display? Have you tried all the inputs or is it just the HDMI input?
splatee is offline
post #24026 of 24027 Old 05-09-2016, 10:11 PM
Originally Posted by splatee View Post
I will try to help.
hello, thank you for the reply. it is not an original philips one, it's generic. i should have done my research and paid for a real one. i'm sorry for my lack of common sense, but i believe that the lamp is firing, but the screen is not lighting up (so i cannot get to the menu at all). the set turns on and i get audio. the red 'replace lamp' indicator is not on unless i remove the lamp and turn on the tv. i'm returning the lamp, and considering buying a new oem/philips lamp to test it again. i'm not sure that replacing the qm board would do anything for my situation. your thoughts?
post #24027 of 24027 Old 07-19-2016, 06:28 PM
mantar's Avatar
Quoted: 43 Post(s)
Rarely used the set ever since I got my Panasonic 65VT50 3 years ago.
But a power surge fried the Panasonic and now I need to watch my SONY again. The bulb I have is near its end as the pic is very dim. I see newegg has a new Phillips one for 94 bucks. The other sites such as Lamps Pros have 35 dollar ones , but not OEM.
The reviews for the Phillips are all positive except for one guy who complained that his bulb went out in 10 months despite light usage. Any better places or should i just get it from here?
If Geek Squad can't fix my Panasonic PLasma (which blows the black levels of the SXRD away), I might go for the SONY 65930C or the Samsung 8000 series. But alas, those are LEDs with poor off axis viewing. I miss Plasmas already.
mantar is offline
Reply Rear Projection Units
Sony , Sony Kds R5oxbr1 Kdsr5oxbr1 Lamp With Housing Xl5100
