The Official HP Pavilion 1080P DLP Owner's Thread - Page 365 - AVS | Home Theater Discussions And Reviews
post #10921 of 10950 Old 10-19-2014, 08:39 PM
dlozy's Avatar
Does anyone know of a good bulb supplier for the 5820? I bought one from projector quest, paid extra for OEM, which was not OEM. The bulb caused the TV to overheat and eventually dimmed so bad you could hardly see the picture after 5 hours of viewing. I sent the bulb back for a full refund.
dlozy is offline
post #10922 of 10950 Old 10-22-2014, 10:56 PM
critter111's Avatar
Unhappy Trying To Keep it going
Hey,
Anyone Know the purpose and/or functions of the Flash and Normal switches on the MD6580n /MD5880n mainboard?
My TV will not accept a Firmware download. I'm getting the 2 left 2 right red flashes which indicates a firmware upgrade error I believe but now I cannot get it to restart the Firmware upgrade.
All my fans come on none are blocked color wheel starts.
I have replaced bulb with three different correct new ones disconnected all the cables and removed the Card reader. but when I reconnect the powerplug it does nothing. the green light is on the Power supply comes on and the light is on steady on the USB drive but the Red-Blue-Red dance never starts. When I give up waiting(20min) with no lights just the bay light(which indicates the lamp door is shut) and turn ON the TV, it gives me the 2 left 2 right flashing reds. or 1010-0-1010
How do I recover from a failed FW upgrade
If I hold down the settings button and power it up it trys to arc cycle then front panel lights display RED on-BLUE on - RED 3 Flash. or 1-1-10101000101010 repeat......
anyone got any info on an expanded explanation of the Lights and their different Modes????
The service manual I have is Quite spars and partly written in Singlish.
Oh and another thing. Anyone know what the correct Reading for the Lamp temp sensor should be(mine reads .5 ohms) at what temp should it open and then what does it read?? infinity??? Can I just jumper it and hope it doesn't burst into flames???
Some People Say I'm the Most Uninteresting Man in the World......
critter111 is offline
post #10923 of 10950 Old 10-27-2014, 12:33 AM
Quoted: 14 Post(s)
Liked: 2
Originally Posted by critter111 View Post
Hey,
I ran across a pretty detailed service manual during my trials with the md6850n
a quick google should bring it up, if you cant find it PM me and ill link it for you
stpk4 is offline
post #10924 of 10950 Old 10-27-2014, 04:04 PM
critter111's Avatar
Yes if you mean the one at cykf yes that's the one I have if their is/or someone has something more detailed out their please PM me. Thanks
post #10925 of 10950 Old 11-03-2014, 06:33 PM
critter111's Avatar
Originally Posted by DPlettner View Post
I replaced the mainboard a few years ago when I lost an HDMI port. One of the early owners that lived in Hawaii sold it to me. The mainboard handles signal-level processing. Based on what you observed, it sounds like the power regulation that feeds the lamp has failed.
Since you did not have any posterization issues, if you found a set from an owner that had posterization, I think there is a good chance you could fix it by swapping parts. I suspect that your light engine is fine.
However, I agree it is time to move on, and I would not spend too much time on it. Let us know what you decide to do. If you do decide to retire it, I bet that there is an owner that has posterization that would love to try your light engine.
-Dave
That's funny I never had any Posterization until I replaced my main board then it did it. I never touched my light engine but replaced both my mainboard and Power supply.
post #10926 of 10950 Old 11-03-2014, 08:33 PM
critter111's Avatar
Originally Posted by lexx View Post
Quote:Originally Posted by swampster
Helps. thanks.
I understand what the first fan is pointed at, but what about the other?
What is your second fan it pointed at? The two heatsinks in the middle or something else. and did you peel back that cardboard.
The second fan is situated half way across the back of the TV. This is the location of two heatsinks, and where the cardboard shroud ends. My guess is that air was intended to be funneled to this spot to cool these two heatsinks. All I'm doing is increasing air movement in this area.
I did not remove the cardboard shroud, but only because I have 2 years left on my extended warranty.
The design of the shroud certainly implies the intent of the designers was to have air move from right to left (as seen from a viewing position). I wonder if putting a fan on the left side of the TV and blowing air from left to right might not defeat this, and cause more problems by blowing hot air back into the TV. Just a thought.
I would like some info to clear up fan flow on these sets So, Just to be clear the 2 main fans,
The one to the right of the mainboard blows into or sucks air from the mainboard?
And the lamp fan sucks air from the lamp(front to back)? or blows to the lamp (back to front)? across the PS.
Anyone?????
post #10927 of 10950 Old 11-04-2014, 04:55 PM
Quoted: 14 Post(s)
Liked: 2
Anyone?????
the one right of the mainboard blows over the heatsinks on the formatter board, one of the heatsinks are attached to the DLP chip the other is attached to another IC on the formatter board
stpk4 is offline
post #10928 of 10950 Old 11-04-2014, 07:11 PM
critter111's Avatar
It Lives!!!!
Well here is an update. I was not able reload my firmware. and ended up swapping out my mainboard.
I was told the MB I had was new and it looked it so I just did a FW-update After the swap before turning on the TV.
Well it Updated did the Led Fancy dace for 20 or so minutes. clicked stopped and started like 3 or so times then Finnally went 0-1-0 steady blinking Blue I was very happy and excited to see if the big black beast was really alive(and half way snockerd at this point)
I turned the set on it cycled Arced and came to life.
Howerer all was not normal It came up with the update confirmation screen and Fuzz in the background(I take it that was the tuner input) but this was displayed fit to scale only using the upper left 1/3 of the screen the rest was dark blue.
I thought to myself well that sucks but turned the set off and hooked The DITV HD DVR up to HDMI 1 and turned the set back on.
After selecting the source the image (some infomercial) displayed as before positioned in the upper left Third of the screen.
I scrolled through setup and did a factory reset and Poof whole picture appeared.
But HP TV info bar (Not DTV info bar) is still shifted to the left half of the bottom of the screen, and even more strange is when I shut the tv off it goes dark blue background with again the upper left Third black except for the HP logo in its center(on shutoff normally in center of whole black screen) then it shuts down.
I watched some shows before shutting this off the first night and noticed for the first time a bunch of Posteurization (smearing in the shadows and weird rainbow effects) I had the heat on that night pretty high.
The next day I turned the set on no Posteurization Beautiful picture cooler house?
I cleaned out the DVR(it got down to 17% in 2 wks of gathering parts) I probably had the set on for 14hrs and had no issues(other than weird positioned screen as stated above)
Does reseting to factory defaults on the setup menu Reset Firmware also???
any thoughts
The Set is Fuctional but not Quite normal.
Oh and still would like to know anything known about the functionality of the Little "Flash" and "Normal" switches on the main PCB its self.
I would sure like some help from someone A lot more familiar with the setups than I. thanks for your time.
post #10929 of 10950 Old 11-10-2014, 04:03 PM
Coucher's Avatar
Since this is no longer a primary tv, I only go back to fooling with it when the mood strikes.
Still battling the issue described here - The Official HP Pavilion 1080P DLP Owner's Thread
Before I go blowing money on another new bulb that may or may not work, even though it's a long shot, is there anyone out there in the Atlanta or north GA area with a known good, full brightness, working bulb that I could use to test if my issue is really just bad generic bulbs that are pulling too much current tripping the ballast or power supply causing the reboot?
If not, if there's anyone else out there with a known good bulb that they're either willing to let me use to test (I'll pay insured shipping both ways), or sell at a reasonable price, let me know.
Such a great tv, hate to throw in the towel on her. Thanks in advance.
Coucher is offline
post #10930 of 10950 Old 11-23-2014, 02:21 PM
Coucher's Avatar
Received a couple PM's about the above...
Coucher is offline
post #10931 of 10950 Old 11-23-2014, 02:22 PM
Coucher's Avatar
And apparently I need a couple more posts to be able to respond to PM's
Coucher is offline
post #10932 of 10950 Old 12-05-2014, 02:03 PM
Liked: 0
hp pavilion help md5880n
Guys please help. Love this tv. Went clay face couple months ago. lasted in this resolution about two weeks then lost picture. Sound ok, no picture in any mode and no OSD. Bulb was on but replaced it anyway with new one. No help. Everything is functional with all signal inputs just black screen. Where to start. I'm technical enough to do board level and component repairs but not familiar with DLP theory. Have worked on CRT's for 30 years rejuving/repair/etc. All fans work, new bulb is bright. Front lights give steady blue and not indicating problem.
powerupgames is offline
post #10933 of 10950 Old 12-11-2014, 12:24 AM
cosmicvoid's Avatar
Quoted: 43 Post(s)
^^ Offhand guess: DMD formatter board or power to that board.
cosmicvoid is offline
post #10934 of 10950 Old 12-11-2014, 02:52 PM
Coucher's Avatar
As a further update to my issue previously posted about.
Purchased a used, known good/working HP bulb from "cosmicvoid" here (thanks again man!).
Got the bulb today, installed, and the set is back to working perfect with a bright and vibrant picture. SO, even though I've used generic replacement bulbs in this set before without issue years ago, it seems at least the last two new generic bulbs just aren't up to the OEM HP quality level. At least in my set, the generic bulbs had some kind of power irregularity which kept causing the power supply to trip and reset the tv every 30-45 seconds.
Coucher is offline
post #10935 of 10950 Old 12-15-2014, 07:34 AM
DPlettner's Avatar
Originally Posted by AbleArch View Post
I will be getting a Panasonic TC-P65VT60 65-Inch plasma set.
I have the same set and I love it.
Where did you find one?
DPlettner is offline
post #10936 of 10950 Old 01-01-2015, 02:06 PM
Liked: 0
I have been follows this forum for years fixing little problems and answering my own questions with just reading through the posts. It really has been great!
I have had the MS6580N since it came out.
It has been the perfect TV for so long!
Yesterday morning I started to get these red lines through my picture no matter what I did (I attached some pics). I have looked through many many pages here and didn't realy come up with an answer so for my first time I am posting for some input in this matter.
I love this TV and really do not want to let it go just yet lol
Thanks in advance for any information
Rob
ID:	454066   Click image for larger version
ID:	454074   Click image for larger version
Trahkcol is offline
post #10937 of 10950 Old 01-01-2015, 02:48 PM
cosmicvoid's Avatar
Quoted: 43 Post(s)
Originally Posted by Trahkcol View Post
... Yesterday morning I started to get these red lines through my picture no matter what I did (I attached some pics). I have looked through many many pages here and didn't realy come up with an answer so for my first time I am posting for some input in this matter...
Try this:
post #10938 of 10950 Old 01-03-2015, 05:22 PM
Liked: 0
Thanks for that tip
I tried lowering it by 2 each time and checking the picture but nothing worked.
Any other tips i can try?
Not the most handy person when it comes to taking TVs apart snd digging around in them.
Trahkcol is offline
post #10939 of 10950 Old 01-03-2015, 07:07 PM
cosmicvoid's Avatar
Quoted: 43 Post(s)
... I tried lowering it by 2 each time...
Did you try raising it?
I have no other suggestions.
post #10940 of 10950 Old 01-15-2015, 08:21 PM
dewseto's Avatar
Any OEM bulbs available?
Hi all,
Have had my MD6580 for over 8 years and the original bulb just went dim! Anyone have a HP OEM bulb available for sale?
Thanks in advance.
dewseto is offline
post #10941 of 10950 Old 01-16-2015, 01:17 PM
Hoser25's Avatar
Originally Posted by dewseto View Post
Hi all,
Thanks in advance.
I wish us all the best of luck finding OEM bulbs, even used ones....to the highest bidder!
Hoser25 is offline
post #10942 of 10950 Old 01-17-2015, 12:58 AM
jmprader's Avatar
Before rigor sets in
I had multiple Pavilion returns when I was an early adopter.
Then, I went to a 1080p projector and sent my love/hate 58" Pavilion off to a rough College life (with my son) 5 years ago. I put an extra bulb in his rucksack and wished him good luck with it.
Fast forward. The kid is out of school and foregoing a paying career in order to train at the World Athletic Center in AZ, where he is pursuing his dream of >19' in the pole vault, and all of the world/olympic dream stuff (we are hoping dreams become reality).
So the last HP 5880 the company sent as a replacement is still kicking out great picture and entertaining 5 world class athletes in a little townhouse in Phoenix. I am glad it still has a pulse (and good color!). That may just be somewhat of a respite for the guys that designed this otherwise ill-fated product beset by QC problems and an upper management that focused on sizzle and no steak, despite their engineering capabilities...
So, it's doing yeoman service for some young people who are sweating it out for peanuts in the hopes of a brief career on the world athletic stage.
When its screen finally fades to black sometime in the next few years, this one unit will have served its consumers well.
John Prader
Falling off the wagon...again, audioholic
jmprader is offline
post #10943 of 10950 Old 03-16-2015, 05:11 PM
TexRanger's Avatar
Thread bump trying to reach stpk4 as I don't have enough posts yet to PM...
Were you able to solve the problem by chance, or did you give up on the TV? After 9 years of great service, my TV started producing very similar problems, but only after it has been on for a period of time. I believe it is heat related, but the fans seem to be functioning properly.
Thanks...
TexRanger is offline
post #10944 of 10950 Old 03-17-2015, 12:56 AM
kwarner's Avatar
Wow. I can't believe you guys still have the TV running. Wish I could help those with problems but I shipped all my working parts to others, including my bulbs. All I have left is a busted light engine. Hope you get more years out of it.
kwarner is offline
post #10945 of 10950 Old 03-18-2015, 08:57 AM
DPlettner's Avatar
Me too. I retired my HP DLP about 18 month ago. It served me well for 8 years.
It would be interesting to know when the lights go out for the last HP DLP represented in this thread.
post #10946 of 10950 Old 03-18-2015, 02:46 PM
TexRanger's Avatar
Well, I have removed every component from my set looking for some leaky capacitors or other obvious signs of trauma... and found nothing. I suspect my light engine is failing since the picture gets scrambled after some period of time in operation, and the scrambled mess persists after shutdown for a short while. At startup it is still perfect.
I'm starting to wrap my mind around parting it out in case it might help someone else keep their set going. I have a very recent OEM bulb that I installed ~ 4 months ago. I believe the power supply section, main board and amplifier board are all still perfectly functional. Perhaps the color wheel is fine, but maybe that is the cause of my problem...dunno. I have the original bulb and housing as well.
So, if anyone needs parts/spares please PM me or reply here. My first really nice TV and am sad to see it break down.
post #10947 of 10950 Old 03-18-2015, 02:47 PM
TexRanger's Avatar
one more gratuitous post to get me to the 15 post requirement for PMs...
post #10948 of 10950 Old 03-18-2015, 03:22 PM
TexRanger's Avatar
Well, in a last-ditch effort, I just ordered two new fans and will see if that solves my problem. Perhaps 9 year old fans aren't reaching max RPM/airflow any longer...I'll report back.
post #10949 of 10950 Old 03-20-2015, 03:28 PM
TexRanger's Avatar
Well, I installed two brand-new fans this afternoon, and the TV booted right up into the scrambled picture this time instead of 45+ minutes later. I guess it is time to give up and move on to a modern TV.
So, if there is anyone else on here still running one, or trying to, I have spare parts! Let me know soon if you have any interest in any part of the carcass.
New-ish OEM bulb that I bought December 2014 and it is working flawlessly (with a generic housing from my first bulb purchase)
Well-used original OEM bulb in the factory housing (I saved for emergency spare in case one quit suddenly)
Two brand-new cooling fans with <5 minutes of run time. (I moved the OEM connectors over)
Two OEM cooling fans
Power supply assembly (3 boards in a chassis)
Main Board
Amp Board
Wiring harnesses
Light engine/DLP assembly (I'm pretty sure this is the problem child)
Speakers
screws, front door, screen, whatever else you might need!
I know there isn't a lot of value in these parts any longer, but hopefully they can help someone keep a set going. Make me a reasonable offer that will make it worth my time to box anything up and keep the bits from getting scrapped. If I don't get any traction here, I'll probably make an ebay listing for the bulbs and housings, and see if I can catch any interest there for the rest of the parts.
I'm sure sorry to see it go. It has been a great TV for 9 years.
post #10950 of 10950 Old 04-01-2015, 02:12 PM
TexRanger's Avatar
This afternoon I broke down my MD6580N to make room for the new one. I already sold the lamps and housings and the buyer said the new lamp really improved his set as he had no idea how dim his old one had gotten.
I now have a big pile of parts! I'll likely sit on them for a short while and perhaps try posting something on ebay, but I won't hang on to them forever. Please PM if you have any interest in something that might keep your set going.
Reply Rear Projection Units
