The OFFICIAL Toshiba 56MX195/62MX195/72MX195 OWNER'S THREAD - Page 45 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1321 of 1339 Old 05-14-2012, 04:12 PM
KLoNe's Avatar
Hi guys; I've finally come to a roadblock with my TV. Hopefully someone can help or give me some ideas...
I have a 62CM9UA 62 Toshiba DLP rear projection television (Australian model) which has stopped working for a few months now.
The first lamp died at the end of last year after about 8000hrs and replaced with a genuine Toshiba lamp & housing which worked flawlessly for another 4-5months.
This is where we're at now. Without testing anything, I thought it was just another lamp gone; ordered another and tried it out - no dice. After reading up a little about the status LEDs, it looked like it was a (as the manual states) an ABNORMAL OPERATION OF BUS LINE'. Believing that this may be related to the televisions power supply, I found some info about the Toshiba's ballast unit dying. I ordered the part, installed tonight and still no joy.
What I have noticed is that, on normal operation, there are 2 fans starting up with a higher than normal rpm then settling down to a nominal rpm after start-up; during this troubleshooting process, you cannot hear the two fans (or at least the start-up faster rpm) running. The fan cooling the lamp is working, but tomorrow I will check if the ballast cooling fan is operating properly.
Is there anything else you think I should look for?
Many thanks.
KLoNe is offline
post #1322 of 1339 Old 06-01-2012, 11:36 AM
stanltod's Avatar
I have most of the parts and boards for a 56MX195 including light engine, digital board, power supply, etc. All of these parts came from two spare TVs that I picked up. I would be willing to trade some or all of it for a ballast for this TV. If interested contact me.
stanltod is offline
post #1323 of 1339 Old 07-05-2012, 11:45 AM
Dean Swit's Avatar
If anyone has the pdf version of the service manual for the 72MX195, I would be very grateful if you could e-mail it to me.
PM me for my e-mail address if your willing to share it.
TIA
Dean
Dean Swit is offline
post #1324 of 1339 Old 07-05-2012, 03:53 PM
pnuyens's Avatar
Do you still need it? I have it. Let me know.
pnuyens is offline
post #1325 of 1339 Old 07-07-2012, 09:25 PM
juancmjr's Avatar
Not sure whether it's a 72MX or 72HM but there's a unit for sale on CL about 2 hours away from me for $100. It needs a light engine according to the picture posted with the ad. Does anyone know what part or parts inside the light engine fail, and whether it's easy to refurbish them or is this information above top secret for consumers, and only authorized refurbish shops can perform the repair to the light engine? I figure I can at least acquire a similar line Toshiba TV for just the light engine and replace the faulty one. I've researched light engines for the 72" and have discovered that no one refurbishes them for this model any more.
Occupation: Millionaire Philanderer... I mean philanthropist
juancmjr is offline
post #1326 of 1339 Old 07-08-2012, 02:08 PM
Dean Swit's Avatar
Three of the failures I've seen reported most often are:
1. The Color Wheel needs to be replaced.
2. The DWD (sp?) chip failures.
3. The Ballast has failed.
I haven't read of anyone being able to simply replaced the decoder chip so far.
post #1327 of 1339 Old 07-14-2012, 04:41 PM
mx5ed's Avatar
I could use a copy of service manual if possible.
Thanks ,
Jack
mx5ed is offline
post #1328 of 1339 Old 08-28-2013, 03:30 PM
tpaparsons's Avatar
I'd sure love to have a .pdf of the 62MX195 Service Manual, if you still have it.
I have my 62MX195 partly disassembled, but am having a problem accessing a mounting screw on the lamp housing guide, which in turn is preventing me from unplugging some parts from the circuit board in front of the ballast board.
Many thanks,
Henry
Henry.Parsons@frontier.com
tpaparsons is offline
post #1329 of 1339 Old 08-28-2013, 03:31 PM
tpaparsons's Avatar
Not sure if this got through as a reply, rather than just a post. Sorry if its a duplicate ...
Many thanks,
Henry
post #1330 of 1339 Old 10-18-2013, 05:04 PM
JJ529's Avatar
Please help!!!  Having picture problems with my Toshiba MX195 DLP........
I turned on the tv last night and suddenly I've got this reddish tinted shadowy thing going on.  It appears to the right of the object(s) on screen and it is constant (see photos below).  There is also a very subtle but continuous flicker.  Changing inputs didn't fix it.  I also unhooked and reconnected the input for my cable box, no change.  Has anyone else experienced this issue??  My photos were taken while viewing a channel that we only get in standard definition, so it has the black side bars due to the resolution setting.  But the shadows spill over into that area, which I thought was strange.
JJ529 is offline
post #1331 of 1339 Old 11-07-2013, 09:37 AM
RobertVT's Avatar
Hey I was wondering. There is a guy next to me wanting to sell a 72mx195 for 150.00
He replaced the bulb and it comes on with picture but there a pronounced sag on the left hand side of the picture. Is that an easy fix ? Is it a geometry setting or something internal with the hardware?
He said the left hand side is sagging like 10" which is way out of alignment. Any thoughts?
Mitusbishi WD-82740
Samsung HL67A750
Onkyo TX-SR608
Definitive Technology ProTower 400 Towers
Definitive Mythos 3 Center
Definitive ProCinema 800 rears
Two polk psw110's
RobertVT is offline
post #1332 of 1339 Old 11-08-2013, 11:20 PM
RobertVT's Avatar
OK it doesn't come on :-)
I have read through these threads and I know it's and older set but can anyone tell me when you plug it in I hear a whine which is low but sounds like a fan but the fan for bulb isn't spinning nor the one near the ballast. Do these come upon power being plugged in? I also found it has the flashing blue LED. I took it apart and cleaned everything and looked for loose or bad connections. The light is blinking steady every 1 second I believe which the manual states the BUS line abnormal operation? What does that even mean?
? Is that truly the issue? The bulb doesn't look blown. I know it's an older TV but I was trying to fix it up and give to someone in the family but based on what I have read, maybe I should run from this thing like crazy?
Any troubleshooting tips or ideas would be most welcome.
Mitusbishi WD-82740
Samsung HL67A750
Onkyo TX-SR608
Two polk psw110's
RobertVT is offline
post #1333 of 1339 Old 11-18-2013, 02:33 PM
KLoNe's Avatar
I wouldn't bother with it, RobertVT - they were a great set in their time, but I spend many weeks trying to fix a 62" which COULD have turned out to be the ultimate bargain like you are hoping for in your instance.
KLoNe is offline
post #1334 of 1339 Old 11-19-2013, 05:26 PM
RobertVT's Avatar
Yeah thanks and you are probably right. I just thought I would give it a shot. Now I have this huge behemoth sitting in my garage.
Mitusbishi WD-82740
Samsung HL67A750
Onkyo TX-SR608
Two polk psw110's
RobertVT is offline
post #1335 of 1339 Old 08-25-2015, 07:27 PM
Voicewizard's Avatar
Liked: 0
[quote=JJ529;23852385]Please help!!!  Having picture problems with my Toshiba MX195 DLP........
Hi dude, I don't know if you're still using this forum, but I happen to have the EXACT same problem with my 62HM195 DLP Toshiba television. The photo you took is so similar to my issue, I almost would've guessed that you could've taken a picture of my television LOL. I'd say the main difference is that my lines go all the way across to the point where if there are Venetian blinds, the aberration will Basically mirror the light coming through the blinds. In darker scenes, I don't see the streaks. The brighter the scene, the worse the streaks. And it happened very suddenly and not too long after purchasing a ball, so I'm guessing it might be something different. Or it was a bad ball.
What was your solution?
Voicewizard is offline
post #1336 of 1339 Old 10-23-2015, 07:57 PM
Liked: 0
The end of my 72MX195
My 72MX195 served me well and sad to see it go. I thought it would have lasted longer.
It started getting red bleeding of the picture towards the right, then it would freeze up on the left side of the screen. At times it would take several attempts to start up. Anyways, had a repair company come in and BER (Beyond Economical Repair) $600 - $800 to fix and only maybe it would work. Color wheel actually looked ok and spun well, bulbs would last 1.5 years as our everyday TV so it got lots of hours.
Had been sitting for a year gathering dust so it had to go.
Anyways, here is the TV last time I saw it.
Now running two Sony 70" 850B and 550A, one upstairs one downstairs and very happy.
tdddurango is offline
post #1337 of 1339 Old 10-27-2015, 07:07 AM
Wryker's Avatar
Quoted: 135 Post(s)
Liked: 62
Our 62MX is still, knock on wood, going strong after @10 years!
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #1338 of 1339 Old 02-02-2016, 12:54 PM
Lsimon's Avatar
Thumbs up 56MX195 Dull Picture Fixed!
OK. Picked up this old DLP at a very low price off Craigslist.
Picture was dull and a bit blury.
1. Replaced bulb.
2. Opened back (lower plasric piece wrapping around sides and back) and cleaned out dust all over the area. Also cleaned light engine lens (but see step 3 of easier access).
Between the two steps above this improved the picture about 80% but it was still a little lacking. I searched the internet and found a site to download the service manual - which is actually for the 56/65/72HN195 as the MX models are the same and the service manual for those is just a 2 page addendum to the HN service manual listing some additional parts. The service manual contained a diagram which gives enough info for someone handy to figure out how to take the TV apart.
3. Removed screen and betel from front. The bottom part with the speakers mounted comes off with this. This involved all of the screws on the back of the unit around the top and sides of the bezel, the four screws (two each side) on the back panel which attach to the back of the speaker grill area, removing speaker grills (one has wires which allow it to dangle but not be completely removed, then four screws along the top of the grey speaker frame and five screws along the bottom. Whole front then pulls off but wires attached prevent complete removal. The input jacks on the right side pull out with this. Doing this allows the mirror and the light engine lens to be cleaned and and also dusted other areas.
Reassembled and the difference from when I first got this is significant. It still isn't nearly as bright as a plasma or LCD/LED but it at least acceptable to me.
Anyone with questions can feel free to message me.
ggmorton and Wryker like this.
Lsimon is offline
post #1339 of 1339 Old Yesterday, 10:51 AM
pauppaul's Avatar
I plugged my Android box into the hdmi port on my 62hm196 and it worked for a few days and now I cannot get any signal through hdmi. The bulb is work, as I can veiw the menu and tv guide but no signal on inputs, not even the static from antenna input.
I read in the manual after, not to connect a computer through the hdmi. Have I fried my electronics by putting android signal through hdmi?
pauppaul is offline
Reply Rear Projection Units
Toshiba
