>>>The Official JVC Pro-Dila HD-P61R1U & HD-P70R1U Owners Thread<<< - Page 134 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #3991 of 4019 Old 11-21-2011, 08:33 AM
joeyd1's Avatar
Originally Posted by CrosshairDF2 View Post
My display looked dim to me, so I went ahead and replaced the lamp that I originally installed on 5/14/2009. The lamp, which will now be my emergemcy spare, had 9,678 (2600 Hex) hours on it. The new one that I just installed just made my display look like new again.
Just checked on the prices for a new spare lamp and it looks like they are now selling for around $60.00.
Just got the "lamp needs replacing" memo across my screen. Original lamp has 6511 hours (196F HEX) so need to look for 1st replacement. Can you please advise where you found a lamp for that price? Also, did you replace the lamp yourself and was it difficult to do? Thanks for response.
joeyd1 is offline
post #3992 of 4019 Old 11-21-2011, 10:09 PM
CrosshairDF2's Avatar
I ignored the lamp warning and my lamp lasted another 3000+ hours. I replaced it only because setting the brightness level as high as it could go didn't help and the display was now too dim for me.
Google this part number, TS-CL110UAA, to check for the lamp prices. Make sure the lamp price includes the lamp housing. Some stores just sells the bulb without the lamp housing.
The lamp housing assembly is user replaceable ... one screw for the lamp compartment cover and two screws for the lamp housing assembly. The illustrated instructions are on page 100 of the Owner's manual.
CrosshairDF2 is offline
post #3993 of 4019 Old 11-22-2011, 04:19 PM
joeyd1's Avatar
CrosshairDS2... Thanks for your quick response on where to find a good price on the lamp. And also thanks for giving the link for the manual w/ page number for the installation of the lamp. Much appreciated !!! Joeyd1
joeyd1 is offline
post #3994 of 4019 Old 12-27-2011, 08:22 AM
DieselAddict's Avatar
I have a 61R1U and it looks like the light engine is failing. I love this TV so much that I would like to find a source for the replacement parts.
Does anyone know a good source for parts?
DieselAddict is offline
post #3995 of 4019 Old 12-28-2011, 01:06 AM
vtnorseman's Avatar
I would start with a call here: http://www.jvcservice.com/store/restart.asp They might still have stock or know who might. Good luck I still love my set and hope it keeps going for a long time.
vtnorseman is offline
post #3996 of 4019 Old 01-20-2012, 03:27 PM
misstrishp's Avatar
Amazon has the lamps for about $55. Probably too late, but maybe helpful info for next time.
misstrishp is offline
post #3997 of 4019 Old 03-21-2012, 01:06 PM
timbolu's Avatar
It is actually quite easy to replace the lamp in the 61" model. The one thing I would beware of is using a discount/cheaper lamp. I replaced my lamp with one of these and it is only 9 months old and I am replacing it again because the picture is so dark already. This time I am spending extra and getting the Phillips unit.
timbolu is offline
post #3998 of 4019 Old 03-28-2012, 05:42 AM
BT&annie's Avatar
Been subscribed to this thread since Jan 2007 when I got my 70", couple months ago bought my 2nd replacement bulb as a backup since it was such a great price (thanks CrosshairDF2!)
Two nights ago I turned the system on and got no picture on the TV. Shutdown, restart, same deal. Red light was blinking. It's been over three years on the first replacement bulb so I thought it was time so swapped in the new bulb. However, forgot to unplug the TV before I did the replace (TV was powered off).
Powered the system back on and TV goes through the whole startup, theater pro flashes up on the screen and it tells me what input its on, but still no picture. When I switch source to DVD, same thing, "theater pro" flashes on the screen, as does the input, but no picture.
I unplugged the set, let it sit, plugged it back in, no difference. I then unplugged, removed and replaced the bulb, plugged back in, no difference.
I don't think it's the bulb because the TV menu shows on the screen as do the inputs and theater pro toggle.
Upstream I've got a Harman Kardon receiver switching HDMI from a blu-ray and Dish box.
Any thoughts on what's going on? I thought I recalled something about resetting HDMI inputs being necessary in some cases but couldn't find anything in searching this thread.
thanks!
BT&annie is offline
post #3999 of 4019 Old 03-28-2012, 06:01 AM
jedclampit's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=715594
search this thread, its in there somewhere
jedclampit is offline
post #4000 of 4019 Old 03-28-2012, 07:21 AM
jgyenese's Avatar
That sounds like your HDMI input needs to be reset. They are designed to disable themselves if the back of the TV is removed to prevent attempts to byass HDCP. They detect that the back cover is off with a light sensor that can be triggered by bright light entering through the ports on the back. I used to have a lot of trouble with this happening from sunlight reflections off the wall behind the TV, but I stopped it by taping a layer of plastic cut from a thick trash bag over that section of the TV.
Turn reset the HDMI inputs:
1. With the TV on, use the original remote and enter the service menu (press the sleep timer and while it shows "0", press the display and the video status at the same time).
2. Select 2 for self check then turn the TV off.
3. After the fan turns off, turn the TV back on. The HDMI ports should work now.
jgyenese is offline
post #4001 of 4019 Old 04-18-2013, 05:12 AM
HDTV Ready's Avatar
I have purchased a new set to replace my P70R1U in my main viewing area and will be relocating the JVC to another room in the house. I recall a card that had specific instructions on how to lift and carry the TV to avoid damaging anything, but cannot put my hands on it now that I need it. Attempts to google and search for this online have not been effective for me. Any guidance or other relevant feedback that might be of help to me would be very much appreciated. Thanks!
- Dan
HDTV Ready is offline
post #4002 of 4019 Old 04-22-2013, 01:35 PM
HDTV Ready's Avatar
- Dan
http://resources.jvc.com/Resources/00/00/94/LCT1711-001A-A.pdf
post #4003 of 4019 Old 10-17-2013, 12:08 AM
Clandestineone's Avatar
I feel like I've followed this procedure to the letter, but no dice. After pressing "2" to enter the self-check mode, a bunch of information is displayed and nothing seems to happen. Is there anything additional that should be pressed/entered at this point? Cuz turning it off, then back on has not fixed the problem...
Are the ports just shot? :-/
Clandestineone is offline
post #4004 of 4019 Old 10-17-2013, 07:40 AM
jedclampit's Avatar
Make sure you have both witches to the left on the remote.Do the procedure to enter service menu.Shut it off, wait till fan stops, unplug for 2-3 min and plug back in.See what you got. Hope that does it for you!cool.gif
post #4005 of 4019 Old 01-16-2014, 12:22 PM
kiddocious's Avatar
Still got my JVC....going strong...
kiddocious is offline
post #4006 of 4019 Old 03-21-2014, 02:05 PM
jgyenese's Avatar
In case anybody is interested, I have created and shared an iRule device and feedback for use with this TV using the rs232 connection (I'm using a GlobalCache GC-100 to connect to the network but other options are available). To find these items, search the device and feedback sections under the Community tab with Type = TV and Vendor = JVC, find "JVC HD-ILA Pro" in the list.
jgyenese is offline
post #4007 of 4019 Old 04-06-2014, 05:03 PM
ArtistLA's Avatar
My HDMI ports have not been working for years, but I stopped trying, since my Blu-ray Disc player had component analog out.  However, that player has gotten to the point that we really can't use it any longer and we just purchased a new Sony player that ONLY has HDMI.  I've gotten to the service menu, pressed 2 (a series of text items comes up, such as "ANALOG=0, DIGITAL=9".  I turned the set off, waited until the fan stopped, and even disconnected the AC plug for 5 minutes.  Didn't work.
Any other suggestions?
ArtistLA is offline
post #4008 of 4019 Old 04-07-2014, 03:32 PM
jgyenese's Avatar
Do you have any light at all behind the TV? It is amazing how sensitive these sets are to light back there - they really should have been recalled and fixed. It doesn't even have to be directly hitting the TV; my HDMI ports would trip on a sunny day simply because the wall behind the TV is painted a bright color. I'd reset them and by the time the TV would get through the warm-up cycle the ports would be tripped again. I ended up taping a black plastic flap over the back inputs panel and never had a problem since. It is taped only on the top so the fan can still exhaust by blowing it out of the way.
Try resetting the HDMI ports at night when it is the dark (no lights near the TV - not even reflected), if that works try taping a flap on the back like I did.
It could also be HDMI handshake issues, try another HDMI device if you have one available.
Then again, maybe the ports are truly bad and it isn't a light issue after all - I really hope this is not the case.
Good luck!
jgyenese is offline
post #4009 of 4019 Old 04-07-2014, 03:38 PM
ArtistLA's Avatar
Yes, we have LOTS of light behind the JVC:  the back is directly against a sliding glass door that faces north light!  Couldn't possible be more light than that!
So you're saying that the HDMI ports themselves on the back panel, where all the rest of the inputs come in, is the place that needs to be dark?  So I think you're suggesting that once I get it working at night (hopefully), I should then tape something very dark over ALL of the inputs to keep the light off of them?  And leave the bottom untaped to allow for the fan to exhaust the heat?
Sounds bizarre, i.e. darkness at the HDMI port to make it work.....
And thanks for the help!
ArtistLA is offline
post #4010 of 4019 Old 04-07-2014, 03:44 PM
jgyenese's Avatar
Yes. You need to cover up any opening that can let light hit the circuit board inside. That include the fan exhaust and any unused ports. If you can shine a flashlight through it and hit the right circuit board you need to cover it up.
Given the amount of light you have described, I think that it is your problem. (fingers crossed)
ETA: I've heard that JVC put light detectors inside to detect operation when the back cover is off and trip the digital inputs. Apparently this is to prevent accessing the pure digital signal after the HDMI security circuit. They neglected to seal up the ports and vents when they made this design decision. eek.gif
jgyenese is offline
post #4011 of 4019 Old 04-28-2014, 06:29 PM
rainstick's Avatar
Hey All,
Been a while since i visited this forum. I have a HD-P61R1U from the original power buy and i'm sorry to say that the set just died. The main board went bad and i decided not to fix it. If anyone is interested in picking the set up for parts, please let me know an we can make arrangements. I live in the Tampa Bay area. I'll hold on to the set for a week or so, and if i don't get any response of interest, i'll send it to the electronics bone yard. I must say that i truly enjoyed the set, bur i'm disappointed that it didn't last that long. BTW, JVC support is very poor. I had to go on Angie's List to find a TV guy in my area to take a look at it and verify that it was dead. Oh well..... Take care.
rainstick is offline
post #4012 of 4019 Old 01-05-2015, 08:03 PM
Liked: 0
HD-P70R at Consignment shop
Is this thread still monitored? ...So a month and half ago came across HD-P70R1U at a local high end consignment shop. Priced at $329.00. Store has beautiful furniture, but never had I seen electronics. Came back today, they had an OTA hook up and the picture looked great. When turning on the system it made a pop, which I thought to be an audio issue. Yet, sound was great, picture still looked awesome. The clerk was very helpful but really didn't know much about the set except that it came from a guy who they out sourced deliveries too. Customers buy a large couch or table and they refer him. Anyway, the price has been reduced to $199.00. Which I can buy on lay away....So experts...is it worth the 200 hundred? and what should I look for and test before buying?
JS Martin II is offline
post #4013 of 4019 Old 01-05-2015, 08:19 PM
chaz01's Avatar
Enjoyed mine when I had it. It's not latest and greatest but I paid $3k for mine. Know that when it goes, that's probably the end so of it lasts one day one month or years, who can day? One recommendation would be to surf net for replacement bulb prior to purchase. I replaced mine once and this one may be on it's third or more.
Good luck. Chaz
JS Martin II likes this.
chaz01 is offline
post #4014 of 4019 Old 01-05-2015, 09:17 PM
jgyenese's Avatar
The pop you hear on start up is normal. I'm not sure what it is, but mine does it every time.
Is it worth $200? No! As long as the light engine is good, it is worth a lot more than $200. The picture on mine is absolutely amazing.
Watch it for about 10 minutes, if you see any intermittent purplish smearing in the picture the light engine might be going bad in which case I would pass.
If the HDMI inputs don't work, it might because light came in through the back panel. Search this thread and you will find instructions on how to reset them.
I would also check the hours on the bulb. I don't remember how to do it, but I'm sure it is mentioned in this thread.
What a great find.
jgyenese is offline
post #4015 of 4019 Old 01-06-2015, 08:14 PM
ChuckF.'s Avatar
That's a good buy. First signs of the typical problem that affects the DILA's shows up best on a white screen as slight yellow clouding in one quadrant of the screen and magenta in another. Often first noticed during hockey games. The ION-TV network ID screen also will show it.
The other typical issue with these sets is as a result of using cheap $38 knockoff lamps, but that's not the fault of the TV.
ChuckF. is offline
post #4016 of 4019 Old 01-15-2015, 03:23 AM
Liked: 0
Hey I bought that TV!!!
I am always looking for a good deal on a used flat screen and while checking out the CL ads, saw this tv for sale. I went by and checked it out and bought it after I saw the picture was ok and not discolored anywhere. Later after trying to get it to my apartment I started to second guess myself because of the massive size and weight of this unit. After setting up the unit the HDMI inputs didn't work so I went to the internet and found you geniuses and reset them. BAM OMG this TV is so great, I use a MINIX android pc and watch XBMC, the picture on this thing is like unbelievable. Either the owner didn't use it much or it was so well taken care of I think it will last me for years to come. Lamps are very low cost now and I now have the best buy I ever had. I'm an old AV tech and didn't know what I had till I looked up this tv, I think it's electronics and capabilities are as good if not still better than a lot of newer consumer flat screens. I am in love with this tv and can see why you guys love it to. I have been reading all the posts from the beginning in 2005 to find out all I can about this unit and learning everything from you guys. How many of you that bought the originals back then still have them today? Thanks everyone who posts on here about this unit I have learned so much. And sorry to the guy that saw it first but didn't buy it.
nwmtc is offline
post #4017 of 4019 Old 10-04-2015, 07:43 PM
DougDingle's Avatar
Quoted: 51 Post(s)
Liked: 66
Can anyone tell me where the IR remote sensor is on the p70r1u?
I can't find in anywhere on the front, so I have to assume it's behind the screen somewhere.
I'd like to attach an emitter from an IR repeater, but have no intention of taking the thing apart...
For anyone interested, I've had the thing for almost 10 years, replaced the bulb once with the spare that came with it, and I have to say in terms of home theater, it's likely the best $4K I ever spent.
For reference, I look at $30K Sony OLED monitors displaying uncompressed HD images all day long, so my standards are moderately high
DougDingle is offline
post #4018 of 4019 Old 10-04-2015, 10:05 PM
ChuckF.'s Avatar
Yes, behind the screen, just forward of the main lens. The signal from the remote bounces off the main mirror and goes down where it can hit the sensor. You can probably see it by removing one of the side ports and looking inside. As a matter of fact, I think you could put your IR sender inside that side port.
ChuckF. is offline
post #4019 of 4019 Old 10-05-2015, 08:46 AM
DougDingle's Avatar
Quoted: 51 Post(s)
Liked: 66
Thanks. I'll have a look, see if I can figure out what's going on in there.
Reply Rear Projection Units
taboola here
