New Sxrd "green Blob" Poll - AVS Forum
View Poll Results: DOES YOUR SXRD HAVE or DOESN'T HAVE "GREEN BLOBS"?
Yes...My 50" SXRD Has "Green Blob" Problems 55 13.58%
Yes...My 60" SXRD Has "Green Blob" Problems 97 23.95%
No...My 50" SXRD Does Not Have "Green Blob" Problems 106 26.17%
No...My 60" SXRD Does Not Have "Green Blob" Problems 147 36.30%
Voters: 405. You may not vote on this poll
Closed Thread
post #1 of 1340 Old 01-25-2006, 09:11 PM - Thread Starter
audiomixer's Avatar
OK...GUYS!!!
Here is the "new" SXRD Green Blob Poll...
It allows ALL SXRD owners to vote.
But, please...Can you give give build dates on your sets?
And this poll is NOT about "blue hue" or other anomalies?
GREEN BLOB ONLY!!!
AND "GREEN BLOB" THAT STAYS AROUND DURING ACTIVE PICTURE TO VARYING DEGREES!!!
Thanks for playing...
Santa Claus has the right idea...visit people only once a year...Victor Borge
audiomixer is offline
post #2 of 1340 Old 01-25-2006, 09:22 PM
noxpurt's Avatar
My brother and friend have a 50 and 60 respectively with GREEN BLOB. I am on my 2nd SXRD with GREEN BLOB after returning the first for the same problem. Im going to keep returning it until I get a good one.
noxpurt is offline
post #3 of 1340 Old 01-25-2006, 11:54 PM
TheMoose's Avatar
Mine is a November build.
I can see a green doughnut at cold startup but it's completely gone in a few mins when it's warmed up.
I watch quite a bit of B&W on the history channel & such so if it was there I'd see it.
I don't consider it a problem.
"Racing is........Life.......Everything before & after is just waiting"
TheMoose is offline
post #4 of 1340 Old 01-26-2006, 03:23 AM
ranamy's Avatar
November 2005 build...NO Green Goblin at this point.....of course it probably helps that I'm just a bit red/green colorblind
Don't want to skew the research/poll, so I'll ask the wife and report anything different.
ranamy is offline
post #5 of 1340 Old 01-26-2006, 07:03 AM
AL B.'s Avatar
Ranamy trying to get things clear.You have no green blob in center area or green at sides of set at startup.Are you looking on the memory stick screen by pushing memory stick button with no stick in there and set menu to gray or do you mean it fades like most do until you can't really notice it?
If there are any sets out there that dont have the green blob at turn on I want to know and will push twice as hard for one that doesnt' have it as if it don't have it at turn on it likely won't have it after warmup when it fades down.
I find it hard to believe any sets don't have it on startup.Many many guys have said they have it at startup.
The problem is not at start up of couse only if there is residual showing up after warmup even hour or more later.
Video:Hitachi 55HDT79,STARCHOICE HD SAT,HD -DVD.
Audio:INFINITY FRONTS,CENTER,REARS,VELODYNE SUB,SONY 5.1 RECIEVER/UPSCALING DVD.
Games:XBOX,PS2,360.
AL B. is offline
post #6 of 1340 Old 01-26-2006, 07:03 AM
fugufish's Avatar
Mine has a huge green blob in the center and a small one in the top left of the screen. 50" Nov. 2005 build. It does go away after about 10 minutes.
SXRD #2 same thing. Also Nov. 2005 build.
fugufish is offline
post #7 of 1340 Old 01-26-2006, 07:08 AM
Big J's Avatar
Then why are you so obsessed about start up? If they go away after 10 mins., who cares if they have it on start up?
J
Big J is offline
post #8 of 1340 Old 01-26-2006, 07:09 AM
Big J's Avatar
Ditto.
J
Big J is offline
post #9 of 1340 Old 01-26-2006, 07:13 AM
ranamy's Avatar
Al,
I haven't noticed it but I will try to get my wife this evening to double check these places this happens on start up. I don't see any green glob, etc. on start up even on a white background.....like I said I am a bit RG colorblind but usually can see green on white.....keep in mind too that I don't have a good feed yet...my directv HD box is supposed to be installed this afternoon. I've been watching mostly SD if that means anything.
Ciao
ranamy is offline
post #10 of 1340 Old 01-26-2006, 07:31 AM
Desert Heat's Avatar
green blob in center (a little to the right) and some in the top area of screen. December 2005 SP1 build.
Desert Heat is offline
post #11 of 1340 Old 01-26-2006, 07:35 AM
kensnyd's Avatar
no green blob at all my set is a sept build
kensnyd is offline
post #12 of 1340 Old 01-26-2006, 07:56 AM
steve's Avatar
No problem on my 60" Oct. 2005 build unit
steve is offline
post #13 of 1340 Old 01-26-2006, 09:45 AM
AL B.'s Avatar
BIG J.Some guys seem to say they have no green blob at all even on start up.If that is true than why bother with a green blob set that has to fade out after 5 ,10 whatever minutes.Its still an annoying 5 or 10 minutes.
If some sets have absolutely no green blob at startup then I will make them exchange till get me one like that.
And as said mine has the green haze in active picture..subtle but there.You can help it out a bit with vivid and cool temp setttings,playing with white balance don't seem to do that much.
I dont' think the green is an actual color thing..its there in black and white with color turned down so its more likely a bulb problem like hots spots or alignment engine problem,maybe shipping problem or defective screen manufacturing problem or uneven
lcos panel problems.I would love to open set and poke around a bit but not on warranty.I have some technical experience in electronics but not going to void warranty
fixing sonys mistake.
And that is why I am harping on this now where before agreed with you.If the set only has this problem on 5 minute warmup then can live with it. But if its in active picture that crosses my line in the sand.Sony can damn well fix it or give me money back.
Games:XBOX,PS2,360.
AL B. is offline
post #14 of 1340 Old 01-26-2006, 09:48 AM
AL B.'s Avatar
I think mentioned my set is October Build.Build month dont' seem to be showing much.Maybe sets made in January as reported are better now.
Games:XBOX,PS2,360.
AL B. is offline
post #15 of 1340 Old 01-26-2006, 09:53 AM - Thread Starter
audiomixer's Avatar
Al B. I have the slight blob problem...
It only affects B&W a little.
I had to turn down the Green Gain and Bias in the White Balance set-up.
ALL THE WAY DOWN...
post #16 of 1340 Old 01-26-2006, 10:06 AM
Zues's Avatar
Those with the green blob problem, i take it does not go away?
Zues is offline
post #17 of 1340 Old 01-26-2006, 10:08 AM - Thread Starter
audiomixer's Avatar
I have had friends over and none of them see it all...
Only me...
post #18 of 1340 Old 01-26-2006, 10:14 AM
harborhills's Avatar
No problems whatsoever, Sept build.
harborhills is offline
post #19 of 1340 Old 01-26-2006, 10:20 AM
Big J's Avatar
Do what you wish, if that makes you happy. I come home, turn on the set, go upstairs and change, check my e-mail etc. and then come downstairs and the blob is gone. It seems to be related to temperature , as I posted elsewhere when I accidentally turned off the set last night , and then turned it on a few minutes later, there was no blob on turn on.
Also note, despite what you may have observed, the question has been posted in the Qulaia thread-they don't get the green blob.
So, how many sets have you had?
J
Big J is offline
post #20 of 1340 Old 01-26-2006, 10:21 AM
Big J's Avatar
Only me...
So, is it really there?
J
Big J is offline
post #21 of 1340 Old 01-26-2006, 10:25 AM - Thread Starter
audiomixer's Avatar
J
It's there...I can probably show it to you on YOUR set...
post #22 of 1340 Old 01-26-2006, 10:30 AM
Big J's Avatar
You also saw it on a greyscale that didn't have it that was posted in one of the threads here.
J
Big J is offline
post #23 of 1340 Old 01-26-2006, 10:33 AM - Thread Starter
audiomixer's Avatar
J
It wasn't there...it is now...
That's been posted here, too!
post #24 of 1340 Old 01-26-2006, 11:00 AM
maximum360's Avatar
I am maximum360 and I am Xbox infected.
Some people have varying degrees of colorblindness (mostly men) so that can account for some seeing it while others can't. Then there's the level of color intensity (of the abnormality) which also varies from set to set.
My wife easily saw the blue hue issue in the last set but not so easily with this one but then again she's accustomed to watching tv on a 27" tv (which is horrible even for crt standards). She does however see the green halo.
My fear is that Sony and M$ are in a competition for complete dominance in my livingroom. I almost positive that everytime I turn on my Xbox 360, the tv just gets a little greener.
"Guns? Guns are easy."
maximum360 is offline
post #25 of 1340 Old 01-26-2006, 11:14 AM
AtlPaul's Avatar
I have a slight green blob even after several hours. Its only noticeable in mostly grey scenes and I don't consider it a problem for me in viewing. When I first got the set around Jan. 1st it didn't have the blob (and I was aware of the issue so I looked for it.) Considering the blob showed up after a few weeks of use it makes me wonder if the lamp has something to do with the issue - something like contamination, like skin oils perhaps, on the lamp that over time affects the surface and hence the transmission of light. But I'm guessing here.
I have a November build.
AtlPaul is offline
post #26 of 1340 Old 01-26-2006, 11:16 AM - Thread Starter
audiomixer's Avatar
SO THERE YOU GO...BIGJ
post #27 of 1340 Old 01-26-2006, 11:23 AM
Big J's Avatar
J
Big J is offline
post #28 of 1340 Old 01-26-2006, 11:24 AM
kclfoxtrot's Avatar
Ditto here. I did not notice the green blob at first, but it has definitely gotten worse and when you bring up the show screen under the cablecard menu (gray background) it is very obvious. When watching hockey games, it is noticeable in the same areas, but I would say it is more yellow than green. I am going to pull my bulb out and see if I can detect any discoloring of the bulb.
kclfoxtrot is offline
post #29 of 1340 Old 01-26-2006, 11:26 AM - Thread Starter
audiomixer's Avatar
J
It is just that the problem can crop up down the road which you accuse me complaining about it now. It was not there when I first had the set and has developed over time...
post #30 of 1340 Old 01-26-2006, 11:36 AM
Big J's Avatar
OK, gotcha.
J
Big J is offline
Closed Thread Rear Projection Units
User Tag List
