Toshiba 50HM66, 56HM66 Discussion - Page 44 - AVS Forum | Home Theater Discussions And Reviews
post #1291 of 1295 Old 05-05-2013, 11:24 AM
Syd 0978's Avatar
having issues with toshiba 56hm66..... recently got rebuilt light engine and now gives me slow blue light blinking.... ii bus errors in service mode... any way to fix it
Syd 0978 is offline
post #1292 of 1295 Old 05-19-2013, 04:51 PM
JOHN07111239's Avatar
HELLO. HOPEFULLY YOU MAY BE ABLE HELP. I NEED THE SETTINGS FOR THE (SERVICE MENU) ON MY TOSHIBA 50HM66. HAVE TO RESET THE WHOLE LIST. KNOW IT WILL BE PAIN IN REAR. CANT WATCH PIC. TELL GET THINGS SET.
JOHN07111239 is offline
post #1293 of 1295 Old 06-17-2013, 01:02 PM
TheNeff's Avatar
Quoted: 17 Post(s)
I got a replacement Bulb (module) {bulb in module, easy to remove, at Amazon.com.
Very easy and inexpensive.
TheNeff is offline
post #1294 of 1295 Old 06-20-2013, 12:17 PM
lawtonmd's Avatar
Experience with ADVANCED LAMPS. Their site states GENUINE AL-Y67 LMP . Note that the "AL" stands for Advanced Lamp manufactured. Their AL-Genuine replacement lamps do not work in Toshiba Rear Proj. TV's. I bought one, sent it back, they sent another, it also did not work. They were very great to work with.
Finally bought a genuine TOSHIBA Manufactured lamp from them, and It worked great for 2 years and then bought another Genuine TOSHIBA from them, and still working fine. Looking for a lower price though.
The Real TOSHIBA manufactured lamps from them ran about $175- $185, which included shipping. Big difference between Y66 LMP and Y67 LMP, the housing is different because the Y67 LMP has a fixed handle that does not fold down. But the Y66 LMP handle is a heavy wire type and does fold down.
lawtonmd is offline
post #1295 of 1295 Old 06-20-2013, 12:17 PM
lawtonmd's Avatar
lawtonmd is offline
Reply Rear Projection Units
Toshiba , Displays
