Samsung 1080p Owner's Thread --- HLSxx87W/HLSxx88W DLP Models - Page 715 - AVS Forum
 6Likes
post #21421 of 21423 Old 01-08-2015, 08:34 AM
K-Dawg's Avatar
Fire Stick
Originally Posted by juny View Post
So i just purchased the Amazon Fire Stick and tried to connect it ot my TV, but I just get a Display not supported message on the TV. I can successfully use the HDMI ports for my cable box, blu-ray player, xbox 360, but the amazon fire stick does not work. Anybody else able to get the Fire Stick to work with their tv?
Nothing wrong with the fire stick as it works on other tvs.
I was pre-ordered and received a Fire Stick as well. Mine is on another TV at the moment. I will move it to my DLP and circle back on this thread tonight.
K-Dawg
"People vote with their dollars!"
K-Dawg is offline
post #21422 of 21423 Old 01-14-2015, 07:35 AM
miker104's Avatar
Is it time for LCD?
I've really been itching to buy a new television the last few months. I bought my 5687 new in 07 and have had zero problems . 19,000 hours on my first bulb(although could have been replaced at about 17,000) and have probably 19000 on the current bulb. I've been looking at the samsung 6350, but don't want to be disappointed. What are you thoughts on making the change to LCD? Have you guys made the change and if so, what are your thoughts? I still feel like the 5687 has a great picture but hard to compare unless the LCD is in my House!
miker104 is offline
post #21423 of 21423 Old 01-14-2015, 08:21 AM
Ph8te's Avatar
Quoted: 1404 Post(s)
Liked: 680
I made the change from a 6188 to p60 Vizio and am very happy. The blacks and contrast are leagues ahead of the DLP. The only thing you will need to get used to really is the motion. It is handled differently then with DLP, but really I haven't been bothered by it. You will most likely not be disappointed by any current TV as long as you stay away from entry level sets. Personally I am just waiting for OLED or another tech to get cheaper so I can upgrade.
Sent from nowhere
Ph8te is online now
Reply Rear Projection Units
Samsung , Displays
