Sony KDS-R60xbr1 service menu codes - AVS Forum | Home Theater Discussions And Reviews
Old 06-06-2006, 01:52 PM - Thread Starter
robbie246's Avatar
Does anyone have a listing and descriptions for the service menu codes for the the KDS-R60xbr1 RPTV? I have the service manual which gives instructions how to enter the service mode but there is no listing of the codes. I am particularly looking for the convergence settings codes.
Thanks in advance.
robbie246 is offline
Old 06-06-2006, 06:11 PM
Uninvited Guest's Avatar
Do you have that in electronic format? I'm having an optical block replaced for the second time. I'd like to ask the guy a few questions before he's done with the service.
Uninvited Guest is offline
Old 06-07-2006, 03:08 PM
rlb
rlb's Avatar
Quoted: 1701 Post(s)
Liked: 1355
Thanks in advance.
Try this for convergence:
http://www.avsforum.com/avs-vb/showt...&&#post6806765
Samsung 65JS9500 and 65F9000 w/SEK-3500U, Denon 4520ci & Outlaw 755
Samsung K8500, OPPO 103-D, PS3, HR44, and Roku Ultra
rlb is offline
Old 06-07-2006, 04:21 PM
JohnnytheSkin's Avatar
Originally Posted by rlb
Any other posts by Chad B? I remember reading that he posted multiple SM instructions but I can't find them for the life of me.
JohnnytheSkin is offline
Old 06-08-2006, 06:05 AM
rlb
rlb's Avatar
Liked: 1355
Go to following post. Right click on his name on upper left block. Pulls up a small insert screen and right lick on find other posts.
http://www.avsforum.com/avs-vb/showt...&&#post6734886
rlb is offline
Old 07-03-2006, 01:54 PM
plasmabuyer's Avatar
Send me a PM and I will give you the Service Manual in electronic format if you already don't have one :).
plasmabuyer is offline
Old 07-03-2006, 02:10 PM
PM sent, thanks!
Old 07-03-2006, 02:43 PM
PM sent, thanks!
Manual Sent ..... ;)
