2007 Mitsubishi WD-XX73X and XX831 Owner's Thread - Page 315 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #9421 of 9426 Old 11-12-2016, 11:49 AM
infoseeker's Avatar
65831 firmware update
Hello All, I was hoping for some help locating the firmware/software update for my 65831? It does not seem to be available on the Mits site any longer. TV is working fine, but I have never updated it since I bought it new. I replaced the bulb and the chip and figured I might as well do the firmware too. Can anyone point me in the right direction? It would be much appreciated.
infoseeker is offline
post #9422 of 9426 Old 11-13-2016, 08:50 PM
Tspeer's Avatar
If everything is working, there's really no reason to worry about it. The only thing I recall being in any firmware fixes was something about the built in tv guide. If you use cable, it isn't something you will use.
But if you really want to update it, way back when I just called Mitsubishi. and they mailed it to me on an SD card with the procedure, and then I had to return it.
Be sure you know your current firmware version, no point if you already have the latest.
I Bet You Wish You Could! - Roger Wilco
Directions for updating your Onkyo xx5 receivers firmware. **Newly updated 7-22-2009**Re-uploaded 2-23-2015**
Something from damninteresting.com
Tspeer is offline
post #9423 of 9426 Old 11-14-2016, 11:13 AM
infoseeker's Avatar
Thanks. I just figured since I replaced the dlp chip and bulb might as well go for the whole ball of wax, but I do not use the TV Guide, so maybe I will just try and look up my current version first.
post #9424 of 9426 Old 07-15-2017, 02:07 PM
kwanamaker's Avatar
Finally sold my 831 after ten years of great use. It will be missed. Having 4k is a nice upgrade, but the DLP movie quality picture served me well.
kwanamaker is offline
post #9425 of 9426 Old 07-15-2017, 02:10 PM
kwanamaker's Avatar
As an FYI, sold my 831 for next to nothing. If anyone else stumbles across the thread because they see one for sale for cheap, go for it, it is a great TV.
post #9426 of 9426 Old 07-15-2017, 03:56 PM
matt314159's Avatar
I ordered a Samsung KS8000 this January when a good deal came up. It must have been the perfect time to make the switch because in the time between ordering my new one and it arriving, my WD-65737 got its first two white dots. I sold it to a college kid for $50 with instructions on where and how to replace the DLP chip. He emailed me six months later to say thanks and let me know he went through with the chip replacement and it's good as new. I'm glad it's still being used by someone who appreciates it.
kwanamaker likes this.
matt314159 is offline
Reply Rear Projection Units
