DVI to HDMI cable problem for Hitachi 51F59 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-26-2006, 06:07 PM - Thread Starter
Teegee's Avatar
I have digital cable and the converter box has a DVI output, so I bought the DVI to HDMI cable(the 51F59 does not have a DVI input just HDMI). The image is crisp and clear but the colors are all wrong. Everything looks green and blue. Anyone have this problem??? If I run the digital cable through the component inputs everything looks fine. The DVD video looks fine too.(both component inputs)
Help!
Teegee is offline
post #2 of 8 Old 06-26-2006, 08:24 PM
Lee Bailey's Avatar
Lee Bailey is offline
post #3 of 8 Old 06-26-2006, 10:09 PM
Bill's Avatar
Quoted: 69 Post(s)
Liked: 50
Is there an RGB option for your HDMI input?
Bill is offline
post #4 of 8 Old 06-28-2006, 10:44 AM - Thread Starter
Teegee's Avatar
I'm not to sure what you mean? Isn't RGB component video? The component video inputs to the tv work fine. ???
Teegee is offline
post #5 of 8 Old 06-28-2006, 11:08 AM
Ballz2TheWallz's Avatar
Component is not RGB, RGB is SCART or VGA(or RGBHV via BNC cables)
Ballz2TheWallz is offline
post #6 of 8 Old 06-28-2006, 12:05 PM
Lee Bailey's Avatar
In the cable box, does it offer an option of sending RGB, or YcbCr to the DVI port? You may need to set it to to YcbCr, since I don't know if the Hitachi can properly use the RGB signals.
post #7 of 8 Old 06-30-2006, 10:00 AM - Thread Starter
Teegee's Avatar
Thanks for the help everyone. I have yet to solve the problem. If I find a solution I will let everyone know.
Thanks again.
Teegee
Teegee is offline
post #8 of 8 Old 06-30-2006, 10:23 AM
Lee Bailey's Avatar
Since your colors are only green and blue when on HDMI, I would really suspect you cable to be at fault.
Closed Thread Rear Projection Units
