Don't dump your CRT RPTV! - Page 256 - AVS Forum | Home Theater Discussions And Reviews
 62Likes
post #7651 of 13361 Old 12-07-2010, 10:18 PM
RobDec's Avatar
Quoted: 139 Post(s)
Hello
Can anyone give some feedback as to how the Pioneer Elite 710 compares to the mits 75" Laservue. I know it has different sizes and technology so comparing them might not be easy. but before i upgrade i like a comparison between the two.
thanks for any input,
Rob
RobDec is offline
post #7652 of 13361 Old 12-07-2010, 10:22 PM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
Let me supertweak your 710 and you won't care. Your upgrade will have been taken care of.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
bob at imageperfection dot com
www.projectiontvtroubleshootingadvice.com
YouTube channel: mrbobbigscreen
Mr Bob is offline
post #7653 of 13361 Old 12-08-2010, 01:05 PM
IsaacT's Avatar
Originally Posted by LastButNotLeast View Post
One of these:
http://www.avsforum.com/avs-vb/showthread.php?t=948496
@LBNL: Thanks, again!
For real, this is one of the most useful threads I've ever seen.
IsaacT is offline
post #7654 of 13361 Old 12-08-2010, 01:18 PM
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
And after you calibrate your set, you need DEMO material...
Then go to http://www.avsforum.com/avs-vb/showthread.php?t=1243227
and you can have your very own BLU-RAY HIGH DEFINITION DEMO DISC.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #7655 of 13361 Old 12-08-2010, 01:46 PM
RobDec's Avatar
Quoted: 139 Post(s)
Hi Bob,
Thanks for recomending an alternative! Ill give it some serious thought!
Happy Holidays!
And thanks once again,
Rob
RobDec is offline
post #7656 of 13361 Old 12-08-2010, 02:09 PM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
See the screenshots on page 45 of this thread -
http://www.avsforum.com/avs-vb/showt...402397&page=45
to see what you'd be throwing away. There are other screenshots in that thread too, and also in this one -
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7657 of 13361 Old 12-09-2010, 08:13 AM
Verge2's Avatar
Quoted: 640 Post(s)
Liked: 156
I cannot get the convergence to work on the far right hand side of my screen, but only when i'm displaying 480p. I can get into the service menu and correct everything at 1080i, but the service menu doesn't work at 480p....
Kinda lost on what exactly to do about it?
Verge2 is offline
post #7658 of 13361 Old 12-09-2010, 05:03 PM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
What kind of set is it?
If the SD and HD have 2 different/separate memories, chances are some of your points on the right side are maxed out and need to be taken in, back more towards their midpoints, leaving the more Coarse registers to do the heavy lifting.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7659 of 13361 Old 12-09-2010, 08:27 PM
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
RPCRT in all its might!!!
superleo is offline
post #7660 of 13361 Old 12-09-2010, 09:35 PM
Verge2's Avatar
Quoted: 640 Post(s)
Liked: 156
b
Panny 47x53.
1080i looks pretty good, i might be able to get it a bit better by messing with the geometry. But man, 480, about 2 inches around the entire screen, is hosed. I decreased the overscan a bit so i could see scores on playstation3, i see why it was set so high now, the geometry on the edge is poop.
Verge2 is offline
post #7661 of 13361 Old 12-10-2010, 07:08 AM
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Originally Posted by Verge2 View Post
Panny 47x53.
If you want to have positive results with overscan the best way of doing it is by shimming the gun array... there is plenty of information about it. You would like the results.
superleo is offline
post #7662 of 13361 Old 12-10-2010, 08:00 AM
mr_jbloggs's Avatar
Maybe I should have read this thread before giving away my Sony KP-65WV700 which had the convergence issue and the blue lamp was almost dead. I was quoted upwards of $500+ to repair it so went head and bought the Mitsubishi 82-738. Even though the mits is a fantastic tv, I do miss my Sony, it gave me many years of joy.
mr_jbloggs is online now
post #7663 of 13361 Old 12-10-2010, 02:19 PM
Blambert007's Avatar
I have an issue with my Mitsubishi WS-55857 projection TV. It's been working fine then 1 day i went to turn it on, it came on, then two seconds later turned off. I repeated the process a couple time with the same outcome. Came back a few days later and it didn't even turn on, no red light nothing.
I disconnected all the cables and unplugged the power. Plugged it back in and no luck. Took the back off and checked if there were any loose boards...no luck.
Any other suggestions?
Thanks for your help in advance.
Blambert007 is offline
post #7664 of 13361 Old 12-11-2010, 09:56 PM
LoudmouthGTO's Avatar
I came back here with a Mitsubishi WS-65857 issue as well. The issue has already been pointed out in this thread (Post 7603 Page 254), but mine may be different. The TV goes on fine, but the picture is blue with no video. The menu does not come up, only the screen turns black. Simple OSD things work like volume, contrast brightness, input... The convergence is way out of whack. Same as in the video. Seems like the ICs may be bad but it may be something else (I have replaced ICs before).
Real confusing thing is I can get into the service menu, but in the convergence settings the values only go from -1 to 1 for all of the settings. Any idea what this may be caused by? Is this IC related?
Also, two of the guns have leaked coolant onto the board. There are a couple of spots on the signal board and the center board with the ICs.
Any help is appreciated. I do not want to throw money into new ICs if they are fine.
Or you could pick up a used DVDO VP30 on eBay for around $300 and get the full picture.
LoudmouthGTO is offline
post #7665 of 13361 Old 12-12-2010, 01:13 AM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
Panny 47x53.
On a Panny you might have to do a reset on the entire scanrate. If you clear just the 480, the 1080 should not be affected, but I take no responsibility! I accidentally cleared my 1080 once on my Panny 65", and no other scanrates were affected.
Sometimes the points just get driven off the chart and you have to start over.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7666 of 13361 Old 12-12-2010, 01:14 AM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
+1!
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7667 of 13361 Old 12-12-2010, 01:15 AM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
I coulda kept it going for you indefinitely.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7668 of 13361 Old 12-12-2010, 01:18 AM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
I have access to Mit tech assist, if you want to give me a call -
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7669 of 13361 Old 12-12-2010, 02:08 AM
Hockeytown Fan's Avatar
bob, i was thinking of buying either the laservue or the 73838 mits but it looks like i might have to put that on hold for a while longer. my question is, i have a Hitachi 65swx20b and its gorgeous but seeing as though i'm gonna keep this set for about another year or so, do you do ISF cals still to customer types like me or just just for close friends and such?
I wanna get the works done to this set, the complete ISF calibration on 2 inputs. one is DVI and one Componant. i mean EVERYTHING... geometry, overscan, convergence, grey scale and color.
as far as deep cleaning, i pretty much just did that myself, so outside of something you may notice i dont think it'll need it.
to have you do something like that, how much and when? if you dont or cant do that could you recommend someone that you trust to me please! i'm in the metro detroit area.
Thank you
Chris
Help a Family in need, Show Them We Care! Like it on Facebook and tweet it!
http://igg.me/p/171832?a=874546
Hockeytown Fan is offline
post #7670 of 13361 Old 12-12-2010, 08:50 AM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
Panny 47x53.
Hope you didn't ONLY use the fine points to do that! On Panny there are Coarse geometry settings that can be used to much greater advantage. Same on Pioneer Elite and non-Elite, and on Mits. On Hitachi there are coarse sets of points and fine sets of points, each set doing its own proper job. Using JUST the fine points is not recommended at all! It pushes things way outside of their design parameter limits, stressing the system. Things need to be calibrated for shaping and placement to stay appropriate within their linear operating ranges, not outside of them.
On second thought to my post above, perhaps what you are seeing is the natural hosing that goes on anytime you reduce the overscan, in any way, shape or form. Doesn't matter whether you're using the shimming op plus service mode or just the service menu alone, your pic gets massively hosed with o'scan redux and has to be corrected afterwards, bigtime. Don't believe you mentioned that till later.
If so, you simply need to do the proper recalibration of your set in response to this. There is a lot more to do with service menu only method, but still a lot to do with shimming op.
I have mentioned this ad infinitum in other threads where we get into it in explicit detail - among other things I have been writing about just this phenom for more than 10 years. Earlier on in this very thread I give an intense expose of what I did to my 73" Mit and what the pix looked like along the way, hosed and then corrected. Find it, and also search out other threads that have been dedicated to overscan redux/reduction, there is an especially good one written about a Hitachi around here somewhere, where I also contributed screenshots of my own display in transition.
Superleo and LastButNotLeast have both done the o'scan redux, they can verify what I am saying here. To really pull off o'scan redux, you gotta have a lot of time available and be willing to man a strong learning curve.
This op is invaluable, but definitely not for the faint of heart. If you don't have at least those 2 things to offer to the project, don't even embark on it! Don't even start - and if you do, prepare a GOOD bread crumbs trail back to where you started before changing a thing! Mark your focus barrel settings, record all your geometry settings, and if you really want to have fun, try charting all your point values, if they are actually given on your brand - before changing a thing. (I usually do everything but the point values, but have done so - charted out all the points I was gonna change - in the past on Pioneer Elites, to my great relief later!)
I am available for phone coaching if you want to contact me directly. No pms please -
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7671 of 13361 Old 12-12-2010, 01:35 PM
LastButNotLeast's Avatar
Quoted: 1490 Post(s)
Liked: 1090
Keep in mind that there will still be some overscan. Mine's about 4% or less. The shimming also greatly increases sharpness, but some overscan is unavoidable with this technology.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #7672 of 13361 Old 12-12-2010, 08:14 PM
Verge2's Avatar
Quoted: 640 Post(s)
Liked: 156
This op is invaluable, but definitely not for the faint of heart. If you don't have at least those 2 things to offer to the project, don't even embark on it! Don't even start - and if you do, prepare a GOOD bread crumbs trail back to where you started before changing a thing! Mark your focus barrel settings, record all your geometry settings, and if you really want to have fun, try charting all your point values, if they are actually given on your brand - before changing a thing. (I usually do everything but the point values, but have done so in the past on Pioneer Elites, to my great relief later!)
b
There is no points in 480p. All options in service menu are greyed out. That's what I'm confused about. On my CRT projectors you set everything up for each resolution.
Verge2 is offline
post #7673 of 13361 Old 12-12-2010, 10:09 PM
BradP's Avatar
Quoted: 42 Post(s)
I'm trying to hang onto my old Pioneer 64" RPTV from Costco, the SD-643HD5 to be exact. Problem is, I managed to mess up the component inputs on the back pretty good from them repeatedly banging into the UPS I had behind it over the years, and I think they are a little, I dunno, loose or something. When using them now, plugging in the component cables usually requires I jiggle them to just the right spot/angle to not get any issues with the color (hard to describe, things just get blurry or a little "off". I am certain the issue resides in the inputs there at that board, but I don't want to spend a ton to fix this.
I took the back off and it doesn't look like it's easy to just tighten them up. I'm also a bit afraid of running into voltage (never had to open up the set to work on it before). Any advice or fixes would be very much appreciated. For a set as old as it is, the picture is still beautiful especially viewing high definition. I was surprised at how clean it was inside too.
Help?
BradP is offline
post #7674 of 13361 Old 12-14-2010, 10:43 AM
b
Bob-
I will take you up on that. I'm at work now and would prefer to be in front of the set prior to troubleshooting. Do you have any suggestions as to what the issue is or anything i can do ahead of time? Thanks for the reply.
post #7675 of 13361 Old 12-14-2010, 02:23 PM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
That's because you need a 1080i signal going in to be able to change the 480p. If you just have a 480p - or i - sig going in, it grays out on you. The set needs that 1080i sig to lock up on the sync properly. Its sync needs 1080i to be able to work with 480p or 1080i, on the image structure.
I got caught with my pants down when I was flown up to Vanc. Canada years ago by a Burbank screenwriter to calibrate his Panny directview HDready, and had not yet equipped myself with my current Accupel HD pattern generator gear. And at that time no Bluray existed yet.
I had called Panasonic to check things out ahead of time, they neglected to tell me about this. I could only do his 480i, as he didn't have any HD at all. All he wanted was 480p, didn't even want 1080i. But could not have it because at that time 1080i was very rare.
He was not pleased...
Sometime even the most credible and trusted information cannot substitute for experience...
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7676 of 13361 Old 12-14-2010, 03:56 PM
movax's Avatar
Help?
You either have to replace the jacks, or maybe just re-solder the connections of the jack to the PCB. Either operation is relatively simple; if you have a buddy that's handy with a soldering iron, that and a few bucks worth of RCA female jacks from Digi-Key is all you will need.
Note that I've never seen the inside of a Pioneer RPTV, and this job might be a little more challenging if the jacks are buried under an EMI shield of some sort. Either way, it's a cheap (<$10) fix for yourself, maybe $10 + a six-pack of beer if you find a buddy to do the soldering for you.
Just to confirm though, if you jiggle the green jack (Y), the picture should appear to go in and out, and if you jiggle one of the other two connectors (Pb or Pr), the picture should end up with weird colors?
Multimedia Software / Hardware Dev
movax is offline
post #7677 of 13361 Old 12-14-2010, 05:19 PM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
Right. You won't find a quicker, cheaper fix to do on a CRT RPTV!
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7678 of 13361 Old 12-14-2010, 05:25 PM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
Thank you
Chris
Awesome set. Yes I still do them, stem to stern, anywhere in the world an owner would like to fly me in to.
Contact me directly and I'll fill you in. No pm's please -
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7679 of 13361 Old 12-14-2010, 05:30 PM - Thread Starter
Mr Bob's Avatar
Quoted: 167 Post(s)
Liked: 100
The bugaboo on the leaked coolant issue is that the Signal board is a 4 layer board, and once compromised has a really hard time coming back. Some techs have been known to do it, but most just shy away when that happens. I can always save the 2 layer boards, but even I shy away from the 4 layer boards.
The trick is that the inner 2 layers are not involved. If you know that you at least have a fighting chance.
If any of the coolant has seeped under any of the ICs tho, you're probably SOL.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #7680 of 13361 Old 12-15-2010, 04:02 PM
johtj's Avatar
Yes.
No, not without replacing the 3 guns.
Not likely.
Way overdue for a cleaning; other "tweaks" are optional. However, everything you do to make the picture better will only make the aging look worse.
Here's a fairly active thread of a slightly newer model:
And here's how my 57F59A looks:
You guys have some amazing shots posted in here. I'd settle to get their set just to look close to that!
I had an interesting experience calling Hitachi support in an attempt to see where I could get my hands on the parts. The guy wasn't able to find the 57G500 in the system anymore but gave me a parts distributor in the area. He advised that I was better off getting a new TV as the current one "wasn't worth anything" - he also said that if I did get my hands on the parts installing and configuring them "is like rocket science." I can appreciate the skill and difficulty that is required to calibrate and repair these TV's but I found the exchange rather amusing. Apparently trying to repair something is frowned upon.
Calling up the distributor, more of the same. Buying all 3 guns is about $250 each and I was told again that I'm better of buying a new set. While it seems parts alone may be close to $1,000, restoring something that is a known quantity is better than spending 3-4 thousand on new TV.
My assumption that installing the new guns IS that difficult and my last step is to attempt to find someone that can do that. For calibration purposes should I be looking for someone that can do "ISF" or is that too generic? Do they need specific CRT training of some sort?
Thanks for the help guys!
johtj is offline
Reply Rear Projection Units
convergence , Panasonic Tc P65v10 65 Inch 1080p Plasma Hdtv , Pioneer Elite , pioneer sd-p5181-k , Plasma Hdtv
