Don't dump your CRT RPTV! - Page 424 - AVS Forum
post #12691 of 12705 Old 10-13-2014, 06:53 PM
mustangdriver68's Avatar
Liked: 0
Originally Posted by Mr Bob View Post
Yes. They take 5 amp fuse protectors, 1 for the negative voltage rail and one for the positive rail. Those 5 amp protectors often blow when the conv ICs croak and short out, no conv repair is complete without checking them. Which can be done in circuit with the power cord unplugged and the unit dead. If both don't show a dead short, in circuit or out, then the one that doesn't - that shows wide open on a continuity test - is blown.
The 1 and 3 amp fuses will be for something else. b
I checked all the fuses and each one had continuity.
I am available for phone consultation, and have done this repair many many times on Mit's. On lots of different other brands too. Patterns begin to emerge when you have done it for as long as I have. I am your best shot at getting this done on your own. b
Looks like I will be contacting you.
That's probably your master power fuse. If your set is operating at all, it's probably just fine. What's its value? Probably 8-10 amps.b
Yes it is the master power fuse rated at 5 amp.
BTW, you stated that you cannot correct the 2 colors. This means you have not gone into the service mode. Which is good, doing so will not get you any further in this repair. But if you want to really trick out your set once it's working properly again, I can take you into the service mode on the phone and with texting me pictures, the difference I can help you create on your image will be absolutely stunning.b
Actually I did go into the service mode but made sure to put the values back. What I was trying to say is that in the advanced convergence menu the reset, red and blue do nothing to adjust the convergence.
Your set is the oldest 16x9 HD set ever made by Mit, and yet still has lots of good years left in her. She's a magnificent set, with those incredible 9" guns like mine has. I hope you hang in there with her.b
I cannot agree more. She has been great since the day I brought her home. This is set used at least 5 hours a day during the week and 12 hours on the weekend for the past 14 years. The HD on this set nothing short of amazing.
Leo
mustangdriver68 is offline
post #12692 of 12705 Old 10-13-2014, 11:42 PM - Thread Starter
Mr Bob's Avatar
Quoted: 37 Post(s)
Liked: 63
Looking forward to hearing from you.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
bob at imageperfection dot com
www.projectiontvtroubleshootingadvice.com
YouTube channel: mrbobbigscreen
Mr Bob is offline
post #12693 of 12705 Old 10-14-2014, 05:16 PM
richlo's Avatar
Not sure if this is allowed but some guy is giving away a 73" mits working crt on Craigslist in Chicago. I thought those things had 9" guns.
richlo is offline
post #12694 of 12705 Old 10-15-2014, 09:23 PM
Liked: 0
Forgive me if these questions have already been answered, a quick search hasn't revealed much and time is of the essence.
Are parts still available for RPTV's? How much should I expect to regularly spend to keep a RPTV functioning? I ask because I just came across a Pioneer Elite Pro-730HD, and Pioneer doesn't have replacement tubes anymore, along with the many other parts they show are unavailable. I found a class action legal settlement regarding "colored lines" on Pioneer x30 model tv's, is that still a common problem and was there a resolution?
Also, since I'm not tv tech knowledgable, what questions should I ask the seller? He's asking $200, says it's in excellent condition, but my concern is he's indicated that it's been stored in his garage for a timeframe I've yet to ascertain. He says it'll need recalibration, and recommends cleaning the tubes.
For background reference, I've only had CRT tv's and have always been disappointed in the picture quality of my friends flat-screens (not sure if led or plasmas, but surely not professionally calibrated). I'm now in need of a larger display so am days away from purchasing one of the last Samsung 1080p plasma tv's, but am concerned about its probable short lifespan and perhaps incomparable picture quality to that of a used CRT tv.
Also, I'm wishing to transition from my current 4:3 set to 16:9. Is there perhaps a different RPTV, or just a standard CRT I should be on the lookout for instead? Many thanks for any shared thoughts.
tubetop is online now
post #12695 of 12705 Old 10-15-2014, 11:20 PM - Thread Starter
Mr Bob's Avatar
Quoted: 37 Post(s)
Liked: 63
Parts are only legally required to be kept available from the manufacturer for electronics for 7 years. That said, many sets that had some one thing wrong with them that brought them down are being parted out on the parts that were not part of the problem. CRTs can always be found at Video Display Corp, where Mit sold 20,000 at a pop to them a few years ago.
Smart owner. Good advice. The longer it has been in cold storage the shorter the aging on the CRTs and thus the longer the set will go on producing extravagantly good HD.
$200 is extremely reasonable for a fully operational 64" big screen even if it needs some work. That set in its earlier 710 incarnation went for $7000 typically, and some sold for as much as $12000.
The streaking thing on the x30 series - like your 730 - that kept happening to them was covered by warranty and for a few years later too, after Pioneer was ordered to, in the class action lawsuit that Pioneer lost. If that streaking never happened on the set in question, chances are it won't be happening now. But you should definitely ask the owner if he had that streaking fixed, either under warranty or out of his pocket.
Also ask if the set has been used as the family baby sitter, on 12-16 hours a day, or as a videophile set, on maybe a few hours a day or maybe just a few times a week.
Ask if the Contrast has ever been set higher than the default centerpoint of zero, halfway between -30 and +30. If so then it may have been pre-aged on its CRT lifespans.
For background reference, I've only had CRT tv's and have always been disappointed in the picture quality of my friends flat-screens (not sure if led or plasmas, but surely not professionally calibrated). I'm now in need of a larger display so am days away from purchasing one of the last Samsung 1080p plasma tv's, but am concerned about its probable short lifespan and perhaps incomparable picture quality to that of a used CRT tv. Also, I'm wishing to transition from my current 4:3 set to 16:9. Is there perhaps a different RPTV, or just a standard CRT I should be on the lookout for instead? Many thanks for any shared thoughts.
I share your devotion to CRT, we here all do. Welcome! I am honored that here was your very first post!
All HDready TVs past a certain point were 16x9 after that. The 4x3 HDs were only for a short time during the transition to HD and were then phased out.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12696 of 12705 Old 10-16-2014, 06:26 AM
sideswiper's Avatar
If i was you Tubetop i would GRAB THAT 730 you will not be Sorry. I have a 710 series Elite & Love it. I had to have the power supply resoldered a year ago because Pioneer did a poor job on soldering the power supply on the 710 & half of the 720 series boards the 730 Do Not have this Issue. Give it a good cleaning inside & out ( Bob can help you with that) if you do not know how. Good Luck & hope you enjoy it
sideswiper is offline
post #12697 of 12705 Old 10-16-2014, 11:20 AM - Thread Starter
Mr Bob's Avatar
Quoted: 37 Post(s)
Liked: 63
I can also help with anybody who needs their power supply board resoldered. I am the only one in the world supplying a lifetime warranty on that resoldering when done on the Pioneer HDready CRT RPTVs, which have been coming up with breakdowns on their PS boards since 2004. After my protocol, that is a thing of the past and your set is stable again.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12698 of 12705 Old Yesterday, 03:32 PM
Liked: 0
Sorry if this is the wrong place to post this.
I just purchased a house and they left a Pioneer Elite Pro-730HD in perfect working condition in the finished basement.
The TV came with two remotes, operating Instructions and the matching cabinet for the AV equipment.
I also have the original receipt.
Does this TV still have value, If so where can I sell it? My wife thinks it's too big and hates the shinny black finish.
John Henry
John Henry Hennessy is offline
post #12699 of 12705 Old Yesterday, 04:38 PM - Thread Starter
Mr Bob's Avatar
Quoted: 37 Post(s)
Liked: 63
Too bad. That "shiny black finish" - otherwise known as "gold trim piano black lacquer finish" is nowhere to be found these days, and would be hella expensive if you could find it. It was the primary difference between their Elite line of HDreadys and their regular HDready stuff, for which the electronics inside was virtually identical. It is the signature design look of all the Pioneer Elite components, audio and video, from way back when to today, and has been for decades. Furniture has been designed around it, some of which you have. It is classy, classic and a highly respected sign of superb quality in audio/videophile circles.
And too big??? Once you have immersive, engrossing size in your display that makes you forget you're actually in a viewing room, you never again want to go back again to small. And 64" is not the biggest size in displays, not by a long shot. What size is your wife used to?
Unfortunately none of that makes your set any more valuable on resale.
The resale value of these sets has been dashed due to the fanatical backlash market response to flat panel, seeing as how when these CRT sets were in their prime, flat panel prices were thru the roof. Only the wealthy could afford them. Now that anyone can get one for a reasonable price, these masterful CRT sets are now looked upon as big and clunky, and therefor reselling them has no profit motive anymore. Esp. with the wives. Their size has not changed, there is simply something out there on the market that's thinner, and CRT's size is needed to fit the folded reflection design that preserves the quality they possess. In my book size means nothing compared to the value of the precision, crispness, depth, dynamic range and lifelike fleshtones that can be brought out of a CRT set. The suspension of disbelief is truly hypnotic.
All digital sets OTOH, still struggle with things our CRT sets have never had to worry about. See the very first post of this thread - 423 pages ago, in 2006 - for details on that.
And no, if you still want to sell it you'll have to do so elsewhere, like Craig's List or ebay, or in the For Sale section here on the AVS. In this thread descriptions of what you have are always welcome, but all you can do is give those sets away, you can't sell them here on this thread.
The real value of these sets is in the use of them. Or as gifts to the younger set who cannot afford much of today's equipment. Even today these sets - and yours too - can be made to look better then when they came out of the box. Far better, actually.
Properly cleaned and fully dialed in they are a wonder to behold, they stand tall with everything else out there today and soundly trounce many of the less expensive displays. They can be dialed in so tightly that you can study the grain of the film they used to shoot that movie you are watching. And nothing short of OLED has better blacks and resultant transparency and depth. Not DLP, not plasma, not LED-lit or flourescent-lit LCD, not D-ILA, not LCOS, not Hughes light valve...
Fly me in. I'll show you.
b
TeflonSoul likes this.
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12700 of 12705 Old Yesterday, 07:53 PM
taichi4's Avatar
Quoted: 131 Post(s)
Liked: 85
Yes. Only OLED beats CRT's blacks.
My Mitsubishi 65813 has piano black finish, too.
taichi4 is offline
post #12701 of 12705 Old Yesterday, 09:06 PM - Thread Starter
Mr Bob's Avatar
Quoted: 37 Post(s)
Liked: 63
I'm jealous. Mine's gray and it's not glossy. But it's a 73! I can live with that.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12702 of 12705 Old Yesterday, 09:19 PM
taichi4's Avatar
Quoted: 131 Post(s)
Liked: 85
Well, we must both make do with what we have.
taichi4 is offline
post #12703 of 12705 Old Yesterday, 10:41 PM
UofAZ1's Avatar
Quoted: 27 Post(s)
Liked: 62
I have a Pioneer 620 58" and after adding a cheap DVDO VP30 to reduce overscan (eBay 125.00). And proper calibration and with Mr. Bobs on the phone deep optics cleaning assistance my 13 year old Pioneer has a picture as nice as my plasma and LED TV but without the issue of pixcellation like current flat screens have. Also Infinate black level and a beautiful piano black outside big enough to hold my very large center channel speaker.
UofAZ1 is offline
post #12704 of 12705 Old Yesterday, 10:59 PM - Thread Starter
Mr Bob's Avatar
Quoted: 37 Post(s)
Liked: 63
Well, we both have the big guns, anyway!
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12705 of 12705 Old Today, 06:08 PM
Liked: 0
b
Thanks, Mr. Bob (and others) for your guidance. After a few emails I have more info to share.
I've learned the seller is the original owner, and it was the main TV for 3 years. For the last 2 years it has been stored in an insulated (not climate controlled) garage. Our summers are 100F and winters 15F, should I be concerned about electrical connections?
It was watched only a few hours a night. The owner said he replaces his TV's every few years as he's a fan of audio and video. For reference, this CRT RPTV was replaced by a plasma, and now he has a Sony 4K.
Regarding the streaking, he's never had any issues with the TV, and was never notified by Pioneer about any defects. He had it calibrated by the Geek Squad once, but doesn't know what the contrast was set to. A few months ago (for a garage sale) he "hooked a bluray player to it and was amazed at how good the picture, sound, everything still worked".
He said he's only selling it so cheap because he hasn't used it in a few years, and it's just taking up garage space. How much are people usually selling this model for?
Again, thanks to all for your guidance. I'm trying to arrange a time to see it, and told the seller I'll likely buy it. Now my dilemma is transporting this behemoth. I plan to rent a small trailer. Any moving suggestions?
Lastly, though probably should have been my first question. Pioneer suggests a viewing distance of 10 - 23 feet. My viewing distance is limited to a maximum of 8 feet, will this be too close to enjoy or cause eyestrain?
Also, I watch over-the-air broadcast using an HD converter. As I understand it the converter reads the HD broadcast signal and then converts it to SD (standard definition) regardless of watching on an HD TV. Will an SD broadcast on a 64" screen with an 8 feet viewing distance be horrid?
PS: Mr. Bob, thanks for welcoming me to the forum. I was both pleased and honored to have you answer my first post. My dearly departed grandfather owned and operated a radio repair shop, which later became a TV repair shop as the market shifted. Needless to say, he had the first TV in his neighborhood. I wish I shared in his knowledge, as you know it's a joy being able to fix things. I absolutely abhor disposable electronics.
Reply Rear Projection Units
Pioneer Elite , Panasonic Tc P65v10 65 Inch 1080p Plasma Hdtv , Plasma Hdtv
Gear in this thread - P65v10 by PriceGrabber.com
