Don't dump your CRT RPTV! - Page 433 - AVS | Home Theater Discussions And Reviews
post #12961 of 12977 Old 04-16-2015, 11:16 AM
Turnbough's Avatar
Quoted: 33 Post(s)
Originally Posted by pman View Post
Thanks, I will try that.
Good luck. Hope everything works as well for you as it has for me.
If you need cables order from monoprice.com I've ordered, DVI, HDMI and toslink optical audio cables among other things great quality, prices and not a single wiring problem for me in last 3 years.
Turnbough is offline
post #12962 of 12977 Old 04-16-2015, 06:29 PM
Turnbough's Avatar
Quoted: 33 Post(s)
After reading a lot more up on the vision HDP you'll need to make sure you have the latest firmware update on it. It probably has it since it was back in '08 but it needs to be there so it will accept 1080@24, 1080@25 and 1080@30 as an input resolution ( native blu-ray red and all 1080p streaming boxes). Good luck, let us know how it turns out
post #12963 of 12977 Old 04-20-2015, 09:02 AM
pman's Avatar
I think I have enough cables, and I also have purchased from Monoprice with good results. My concern is with my Roku 2xs having composite audio out.
I just connected the HDP to the tv and all I get is a blue screen?
pman is offline
post #12964 of 12977 Old 04-20-2015, 09:09 AM
Turnbough's Avatar
Quoted: 33 Post(s)
Do you know what the previous output resolution was on the HDP? It may be as simple as its sending a 720p or 1080p signal and the TV won't do anything with either of them.
post #12965 of 12977 Old 04-20-2015, 11:07 AM
pman's Avatar
Ok, I called Lumagen and got to the menu and was able to setup my blueray player but the Roku which shows their menu system but when a bookmark is selected all I get is a purple screen. I don't think Roku will work off dvi?
pman is offline
post #12966 of 12977 Old 04-20-2015, 08:05 PM
Turnbough's Avatar
Quoted: 33 Post(s)
Is there an option to turn HDCP on and off or auto? My DVDO edge does not sure about the HDP though. Check, if it does make sure its on. The roku may think your trying to view HDCP protected content on a non HDCP device if its off.
Looking at it further on the audio side it looks like your only going to get left right stereo out of the roku if its not over the HDMI. You may need to leave the roku hooked directly to the receiver via HDMI so you get your surround sound and run the HDMI output from your receiver to the HDP via DVI since you won't need sound anymore. Its extra processing so you wouldn't want to do it that way unless you have to. Once you get everything functioning through the HDP you'll also be able to eliminate most if not all overscan from all your sources going through the HDP.
post #12967 of 12977 Old 04-23-2015, 12:44 AM - Thread Starter
Mr Bob's Avatar
Quoted: 90 Post(s)
Liked: 90
I don't know of any way to turn on or off the HDCP copy protection circuits. Seems they would not want them switchable, as the copy protection is not supposed to be able to be turned off.
That said, I have never seen a Roku box - or Apple TV - that puts out 1080i. The only way I know of to get a Roku's 1080p to our CRT sets is to use a dedicated scaler, or an HD Fury 4, that will transcode 1080p to 1080i.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
bob at imageperfection dot com
www.projectiontvtroubleshootingadvice.com
YouTube channel: mrbobbigscreen
Mr Bob is offline
post #12968 of 12977 Old 04-23-2015, 12:49 AM - Thread Starter
Mr Bob's Avatar
Quoted: 90 Post(s)
Liked: 90
Originally Posted by rptvtomi52 View Post
Where do I find how many hours my mits ws55315 has been in use? My rca has a hour counter in the service menu...just wondering if its the same for the mits. And how many hours before it starts affecting the picture quality and brightness of the crt's. More directly....what is the average lifespan for the CRTs in the mits? And the rca d52w20? If anyone knows the brand and quality of these...any input is much appreciated...thanks.
Personally I have never seen an hours counter on any CRT RPTV, and I have been in many service menus. Not part of the price point, I figure.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12969 of 12977 Old 04-23-2015, 01:25 AM
Turnbough's Avatar
Quoted: 33 Post(s)
On my DVDO edge you have an output HDCP mode that can be toggled between auto and always on. And an input HDCP mode that can be toggled between on and off. That being said it has an on screen warning that the edge handles HDCP violations by blanking the output picture (blue screen). If the lumagen HDP has a similar setting and for whatever reason it was turned off (HDCP violation) it could explain the purple screen. If so then simply turning it back on may fix the problem.
post #12970 of 12977 Old 04-23-2015, 04:25 PM
csnow's Avatar
I am getting back into retro gaming, and I am in search of a 4:3 TV. I would like a larger size, but the larger ones I found on Craigslist (32"/36") have terrible geometry issues. I found a couple of rear projection CRT that are 4:3 format. One is an Hitachi, which back in the day, were considered high end (if my memory serves me correctly). I remember people were impressed when you had either a Mitsu, Hitachi, or Pioneer CRT. My question is, can parts still be sourced for these older sets or are they boat anchors if they fail. I would assume most of the CRT guns would be near end of life on these older sets.
Chris
Denon 4520
Mitsu 92" DLP
SVS PB13 Ultra (2)
Oppo BDP-103
Rocket RS850 (2)
Rocket Bigfoot Center
Rocket RS450 (4)
Emotiva XPA-3
csnow is offline
post #12971 of 12977 Old 04-23-2015, 08:21 PM - Thread Starter
Mr Bob's Avatar
Quoted: 90 Post(s)
Liked: 90
Nep. Properly treated, CRTs - direct view or projection - just keep going, and going and going...
Those owners with unlimited funds regun their overhead projectors, not because they finally give out and die, but only because they have finally gone relatively dim, as the phosphors eventually will when pushed hard. On projection CRT sets they drive those guns a lot harder than on direct view CRT sets, and overhead projectors get driven harder than rear projection. I know of one Panasonic CRT RPTV that was 29 years old before giving up the ghost. My 26" Mit CRT in the bedroom here has to be at least 20 years old by now, and since it's been run at 40% contrast since I bought it, it shows no sign of impending end of life, never has. I bought it long before HD was even a twinkle in the eye of Joe Kane. The first HD sets hit our country just before Y2K at the turn of the century. They were actually in Japan before they were here.
Keep your contrast at its midpoint or below and keep fixed images off of it to prevent screenburn, and the one you buy for your purposes might last you 29 years also.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12972 of 12977 Old 04-23-2015, 08:24 PM - Thread Starter
Mr Bob's Avatar
Quoted: 90 Post(s)
Liked: 90
Won't turning the HDCP back on mute the picture BECAUSE of the content being an HDCP violation? Are you saying that that switching allows content to show up on the screen even tho it's an HDCP violation to do so?
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12973 of 12977 Old 04-23-2015, 11:03 PM
Turnbough's Avatar
Quoted: 33 Post(s)
b
No, if its in violation it will not show a picture. I played with it a little on blu-ray it just blanks the sceen. On the amazon fire TV it blanks the screen on protected content and drops the audio on all unprotected content and games. I really have no idea what the point is for having the ability switch it on and off from the input source. Just that if its switched off it messes things up (as expected).
post #12974 of 12977 Old 04-24-2015, 04:47 AM
Liked: 1
already dump it and got back $5 ! lol
IamLoser is offline
post #12975 of 12977 Old 04-26-2015, 06:47 AM - Thread Starter
Mr Bob's Avatar
Quoted: 90 Post(s)
Liked: 90
Enjoy your $5.
I am going to enjoy my fully pimped out 73" CRT - fully dialed in to its full design potential, like they all can be - that looks so good I seldom go out to the movies anymore. Last night we watched 2 episodes of The Americans on FX in scintillating HD and pure bliss. I enjoyed the grain of the film they used to shoot those episodes, the focusing on that grain is superb.
For that same $5 I can rent 2.5 bluray movies from my corner Redbox and sit at home a totally away-from-it-all time and space traveler, with mesmerizing suspension of disbelief and total immersion, and the ability to totally forget I am actually in my own living room. It is my Star Trek transporter.
I would not take $5 to dump my set if my life depended on it.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #12976 of 12977 Old 04-26-2015, 12:58 PM
Turnbough's Avatar
Quoted: 33 Post(s)
Enjoy your $5.
b
I couldn't agree more.
post #12977 of 12977 Old Yesterday, 10:43 PM
superman0234's Avatar
Welp, it has probably been a year plus since I last posted as I've been busy with work and enjoying my Pioneer elite 620HD. My last post was regarding the WD TV LIVE PLUS box which is one of the few streaming boxes capable of doing 1080i over component. I've returned to report on my experiences with this box as well as outputting 1080i over VGA from a laptop to the RGB input on Pioneer Elites without any sort of conversion box.
The WD box is pretty much everything I could have asked for. I mostly play digital versions of movies (read downloads...) and it will cleanly output any file type you throw at it 99% of the time. There are some exceptions such as dual audio mp4 and mkv files, but otherwise it does everything perfectly. Watching a 16-20 gig lossless BR Rip over component on my Elite is a wonderful thing. The box also has optical audio out via toslink which allows for multi channel audio with an appropriate receiver. The included firmware with the box, the newest version anyway, has an inherent issue of corrupting video files on your externally connected hard drive (the device has 2 USB ports for external hard drives). I highly recommend the use of the WDLXTV firmware which is homebrew created by a vast enthusiast community, as the device is fairly open source. You lose HD Youtube capability but the firmware is far faster and there is no corrupting of files as I and many others experienced with the latest official firmware. This box handles most streaming capabilities such as Netflix and Youtube (no HBOgo sadly) in addition to its ability to play near any codec file off an externally connected hard drive. Menu system is fairly well structured for both movies and music with the WDLXTV firmware and even the official firmware for that matter. I highly recommend it for anyone looking to add streaming and digital playback to their HDMI-less RPTV. They go for around 50+ bucks on ebay.
Recently I discovered the wonder that is XBMC/Kodi, which is a media center platform that allows the streaming of TV as well as other media options over the internet. When properly configured, it is a very powerful solution for those of us looking to integrate all of our viewing needs. Being that this is laptop software, I began looking for ways to output VGA to the RGB port on my Elite. After purchasing a 15ft VGA cable and reading ample documentation about custom resolutions, I was able to properly sync a 1920X540p image to my Pioneer via VGA off the laptop to the RGB port on my TV. In order to do this, you need a laptop/htpc capable of outputting custom resolutions, combined optimally with the Power Strip software application. It took quite a bit of trial and error on the pioneer but I was able to get a properly scaled image in 1080i with near perfect settings, though there is some overscan which is likely due to my TV itself. The syncs do not match the typical 60Hz Vertical x 34.75 Hz Horizontal, but they are quite close and display properly. I will list out the exact settings in the coming days for anyone that needs them as they are not found anywhere online, but if anyone needs them immediately, feel free to PM me.
On a side note, Mr. Bob is king of the RPTV world. He fixed my power board years back and it is still going strong. I also have a number of boards and parts from the 510HD series if anyone needs anything. Please let me know!
RPTV remains king
superman0234 is online now
Reply Rear Projection Units
convergence , Panasonic Tc P65v10 65 Inch 1080p Plasma Hdtv , Pioneer Elite , pioneer sd-p5181-k , Plasma Hdtv
Gear in this thread - P65v10 by PriceGrabber.com
