Don't dump your CRT RPTV! - Page 441 - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #13201 of 13201 Old Today, 03:56 PM - Thread Starter
Mr Bob's Avatar
Quoted: 142 Post(s)
Liked: 97
Sometimes I find internal lenses be glass, like 1 of the 4 inside the lens barrel. But have never seen the lenses that are actually exposed face up being glass, only plastic. Very soft and vulnerable to scratches - or scuffs, which are thousands of tiny scratches at once.
How are you getting your signal to your set? If it's with component, how is the SAP audio getting there? It has to be encoded in whatever signal your set receives. Using your set's tuner, with channel 3 picking up your cable box's RF modulated signal or your antenna feeding your set's tuner via the coax, you would not be getting HD.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
bob at imageperfection dot com
www.projectiontvtroubleshootingadvice.com
YouTube channel: mrbobbigscreen
Mr Bob is online now
Reply Rear Projection Units
convergence , Panasonic Tc P65v10 65 Inch 1080p Plasma Hdtv , Pioneer Elite , pioneer sd-p5181-k , Plasma Hdtv
