Samsung HLS xx87/xx88 Tech Links - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 143 Old 07-10-2006, 11:44 AM - Thread Starter
docrings's Avatar
Last update:14 AUG 2007 (Calibration using the Service Menu, and Spyder2)
Now includes some HLT links, as I have upgraded to an HL-T replacement...
Due to the burgeoning "official" thread, I will be posting links of interest on different technical specs/tips/tricks on the Samsung HLS xx87/xx88 models. Please feel free to reply with ideas for links and specific thread topics on pertinent discussions.
No questions, please: keep those in the official thread or in a separate thread.
Some threads may be lost due to archiving.
And the winner of the most oft-asked questions by n00bies:
HELP! My new TV has a BLURRY PIXELATED picture during fast moving scenes...is my TV to blame? NO...it's compression artifact of your satellite or cable provider.
Begin regular Tech links below:
HL-S model thread
HL-T model thread (Just FYI, as this is the HL-S Tech Links Thread...)
HLT Tech Links (FYI, for those looking for the HL-T Tech Links page...)
Winner of the RPTV shootout!
Differences between 87 and 88 models
AVICAL's in-depth analysis report on HLS
Diff between HLR and HLS models
Samsung HLS-6187W
HLS-6187W manual download
HLS-6187W Spec Sheet (updated specs)
Samsung HLS-6188W
HLS-6188W Manual download
HLS-6188W Spec Sheet (updated specs)
Purchase Service Manual
Samsung service phone number
With *any* problem: power off, unplug from wall for 30seconds, restart TV
HLT Firmware version access
10- bit processing for HLS-6187W
Dimensions (same for 6187 and 6188)
December Factory Firmware update (do *NOT* upgrade firmware or you will very likely KILL your TV!)
Shipping box dimensions
AVS Member Review Links
Another AVS Member review and pics
TV Authority Description
What's Inside: chips, photos, descriptions and service menu tech tips
Service menu picture
Turning off overscan in service menu
Latest OVERSCAN links and tips
Permanently disabling DNIe in the service menu
Service Menu discrete hex codes for HLS
Discrete codes for HLT
Service menu JP1 code for remotes
Ring Focus
1920x1080 via DVI to HDMI from computer
1:1 Pixel mapping for PC hookup with Powerstrip
Another 1:1 Pixel mapping thread for 6187's
Overscan not sticking on 6187 : multiple links
Perfect 1080p via PC computer running ATI videocard
XBOX 1080p via component
XBOX 360 via VGA: "how to"
XBOX via VGA, video settings for best performance
XBOX 360 "washed out" over VGA input
PS3 Blu-Ray settings
Access Service Menu / Reset lamp hours / Firmware version (Caution: resets settings)
View Firmware version (does NOT reset settings)
Bowing on 4:3 Material - when to service?
A couple of "custom" video settings
Custom Gamma and Video settings for VGA input (PC)
Pictures of the TV in a member's home
Lamp replacement post (with links)
More tweaks from user Eliab
Manual Iris Control
TV problems/concerns
TV set "resets" to Dynamic every 30 minutes... what's up? Shop Mode Explained
Cabinet tweak for geometry problem (but better to adjust the DMD module...see "what's inside" post)
Harmony 880 Programming for 6187 to get discrete codes
Remote control discrete files for Philips TSUxxxx and MX-850 remotes
Remote programming file link
Philips Pronto service menu and discrete input file
Discreet input remote codes
JP1 discrete codes
Screen Smudge Cleaning
Loud popping noises and causes/fix
Screen shadow problems
High Pitch Whine Problems?
Cablecard issues?
Getting Toshiba HD-DVD player v1.4 firmware to work with Samsung xx87, 88
Another big discussion thread on the Sammys...
HLS compared to Sony KDH-60A2000 from calibrator's opinion
Reducing rainbow effect with a calibration
Diagnostic II hidden screen
How to get to the screens
Calibration Topics in-depth:
Curt Palme calibration website... very good!
HLS Service Menu Calibration for Dummies and Cheapskates
HLT Service Menu Calibration for Dummies and Cheapskates
Excel Spreadsheet for tracking Service Menu changes... VERY NICE!
More HLT setup tips, including CCA calibratioin, sRGB, etc.
COEFF tweaks for grayscale accuracy
Changing GAMMA in the service menu prior to tweaking
Calibration pros
How to input your calibration data into the CCA menu
Calibration questions and CCA
Calibration (tips by Eliab and DVE)
Turn off CCA prior to DVE or AVIA calibration
ISF Calibrators (Eliab link broken, see below)
Eliab ISF Calibration Link
Grey Scale and Tristimulus plot prior to calibration
GetGray Calibration Disk (love it!)
Videolan pattern player
DNiE grayed out in Movie mode... what's up with that?
Calibration patterns and videos
Self Calibration routine - "Steaming Rat" method
Calibrating output to match HTPC output
Go-to Guide for Source Options and self-calibrations
What is Gamma? What is Overscan?
XBOX 360 HD-DVD calibration disk
Cheers!
Doc Rings
AVS unofficial ophthalmologist
docrings is offline
post #2 of 143 Old 07-10-2006, 07:08 PM - Thread Starter
docrings's Avatar
Enjoy the updates for those looking for Samsung tweaks'n'tips !
Cheers!
docrings is offline
post #3 of 143 Old 07-12-2006, 12:46 PM - Thread Starter
docrings's Avatar
Added 10-bit processing link for xx87 model
docrings is offline
post #4 of 143 Old 07-13-2006, 12:04 PM - Thread Starter
docrings's Avatar
Added "What's Inside" tech link with chips, tech descriptions, photos of case removed, etc. Nice link!
docrings is offline
post #5 of 143 Old 07-13-2006, 12:09 PM
jhferry's Avatar
Quoted: 28 Post(s)
Is there anything in there on how to turn the Overscan off in the service menu?
jhferry is offline
post #6 of 143 Old 07-13-2006, 01:37 PM
jhrace2's Avatar
Thanks SO much, docrings! My HL-S6187W is supposed to arrive in just over a week, and this makes my life 10 times easier
jhrace2 is offline
post #7 of 143 Old 07-13-2006, 05:44 PM
AVBill's Avatar
docrings,
Wow, what a comprehensive list. This makes me want a Sammy even more (I'm just so paranoid about RBE). Great work!
AVBill is offline
post #8 of 143 Old 07-13-2006, 05:49 PM
paxi's Avatar
Oooh very cool! Might want the add some info/links re: the firmware update (1.4?) for getting around the Toshiba HD-DVD via HDMI problem
paxi is offline
post #9 of 143 Old 07-16-2006, 08:10 AM - Thread Starter
docrings's Avatar
New to the list:
Adding HLS-6187 to Harmony 880, and have discreet input codes:
http://www.avsforum.com/avs-vb/showt...&&#post8012387
enter HLS6188W as your model.
docrings is offline
post #10 of 143 Old 07-16-2006, 10:02 AM - Thread Starter
docrings's Avatar
Added link to v1.4 firmware update for Toshiba HD-DVD player which had prior issues with HDMI interface with Samsung DLP TV's (include 6187 and 6188).
Doc
docrings is offline
post #11 of 143 Old 07-16-2006, 10:42 AM - Thread Starter
docrings's Avatar
Added link to contrast between HLR and HLS models.
docrings is offline
post #12 of 143 Old 07-16-2006, 01:54 PM - Thread Starter
docrings's Avatar
Added the other discussion thread to the links...
Doc R
docrings is offline
post #13 of 143 Old 07-17-2006, 10:51 AM - Thread Starter
docrings's Avatar
Added Eliab's smudge cleaning tips...
docrings is offline
post #14 of 143 Old 07-18-2006, 09:42 AM - Thread Starter
docrings's Avatar
Added link to comment on overscan "off" only 'sticks' on the 88 model, not the 87.
docrings is offline
post #15 of 143 Old 07-19-2006, 06:11 AM - Thread Starter
docrings's Avatar
Updated Eliab's smudge cleaning techniques
docrings is offline
post #16 of 143 Old 07-21-2006, 09:00 AM
dropKickMurphy's Avatar
Nice work, doc.
This should be a sticky thread, imo.
dropKickMurphy is offline
post #17 of 143 Old 07-27-2006, 12:46 PM - Thread Starter
docrings's Avatar
Eliab link updated (old link broken)
docrings is offline
post #18 of 143 Old 07-29-2006, 12:33 PM - Thread Starter
docrings's Avatar
Remote programming link inserted (from official thread)
docrings is offline
post #19 of 143 Old 07-31-2006, 09:15 AM - Thread Starter
docrings's Avatar
Added shipping dimensions to links...
docrings is offline
post #20 of 143 Old 07-31-2006, 08:09 PM
rocko1290's Avatar
docrings, how about a link to Eliabs recommended user menu settings?
XBL: Rocko1290
PSN: Rocko1290
rocko1290 is offline
post #21 of 143 Old 07-31-2006, 09:30 PM - Thread Starter
docrings's Avatar
Added UMR's (ISF calibrator) opinion of HLS vs. Sony KDH-60A2000 LcOS unit (he prefers the processing in the HLS units...)
docrings is offline
post #22 of 143 Old 07-31-2006, 09:32 PM - Thread Starter
docrings's Avatar
I think it's under "More tweaks from user Eliab" ... there are a couple "settings" links with suggestions for initial out of the box rough calibrations/settings.
Cheers!
Doc
docrings is offline
post #23 of 143 Old 08-01-2006, 12:56 PM - Thread Starter
docrings's Avatar
Added JP1 remote discrete data link
docrings is offline
post #24 of 143 Old 08-01-2006, 01:01 PM - Thread Starter
docrings's Avatar
Added gray scale plot prior to calibration
docrings is offline
post #25 of 143 Old 08-05-2006, 02:02 AM
tg2k's Avatar
Should you link to this post about the shadows on the sides/corners?
tg2k is offline
post #26 of 143 Old 08-05-2006, 07:49 AM - Thread Starter
docrings's Avatar
Added link to firmware viewing mode...
docrings is offline
post #27 of 143 Old 08-05-2006, 07:51 AM - Thread Starter
docrings's Avatar
Done... need to include the good and the bad.
docrings is offline
post #28 of 143 Old 08-05-2006, 08:21 AM - Thread Starter
docrings's Avatar
Added "Steaming Rat" calibration/tweaking method to links...
docrings is offline
post #29 of 143 Old 08-05-2006, 10:47 AM
mczolton's Avatar
docrings,
You've done a wonderful job of compiling a list of technical links for us. Thank you. I was, however, wondering if you wouldn't mind categorizing the links? Do you think this is possible?
Mark
mczolton is offline
post #30 of 143 Old 08-06-2006, 08:21 AM
paxi's Avatar
The list is really coming along. How about a link to the 7178W owners thread? (Ok, technically not 87/88), but pretty much the 88 series. I agree with the previous poster that the longer the link list becomes it may be most helpful to either alphabetize or categorize (although I have no idea how to break down the categories). Great job, again.
paxi is offline
Reply Rear Projection Units
