Samsung 71' 1080P DLP HL-S7178W (owners) - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1711 of 1723 Old 09-09-2011, 06:13 AM
RayPaganJr's Avatar
Purchased my tv September of 2006. Five years later I check the lamp hours and it's only 2900. Though we don't use it like our bedroom set, only during football season and new blu-rays, thought the hours were much more than this. Was thinking it was time to change the bulb, but the PQ is still looking very good. I wanted to get a 3d tv to replace my 7178. After serious thinking and research, I'll just replace the one in my bedroom.
RayPaganJr is offline
post #1712 of 1723 Old 11-12-2012, 02:26 PM
samsungrox's Avatar
HELP PLEASE FELLOW SAMSUNG OWNERS
I need help with a fan replacement! Lost the link I had with good instructions/guide!!
Samsung HLS7178W
And I only see one " colling fan" spelt wrong on ebay for 32usd
seems like the right one but lost my bookmark i had when i replaced my bulb on how to replace lamp housing/fan
any help would be greatly appreciated
It's not color wheel as it stays on BUZZING after power off tv for 1-2 mins and you can see it spinning and when it finally stops
the sound stops
ALSO WONDERED there is more then 1 fan in this dlp but it seems like only 1 is making alot of noise
should/can we replace the other one that I can kind of see and is it easy?
Same fan?
Thanks going to research the forums and hopefully check back for some wicked info asap smile.gif
long time lurker didnt even have a login anymore wanted to post and ask so thanks again!!
samsungrox is offline
post #1713 of 1723 Old 11-12-2012, 05:54 PM
samsungrox's Avatar
seems like fan #1
looking at the back where inputs are
the right side behind the lamp is the noise
Press power on the tv and 30-45 seconds after lamp goes out it continues humming buzing then u can hear the click and power drains and u hear "it"slow down and stop the noise also
slows
post #1714 of 1723 Old 11-12-2012, 05:55 PM
samsungrox's Avatar
sorry meant to say is it fan #1?
color/pic is very nice since i recently replaced the lamp with a phillips
replacement
Wouldnt we have bad pic/color/black and white if it was color wheel not just noise? :c
post #1715 of 1723 Old 11-18-2012, 11:20 AM
calentz's Avatar
Quoted: 88 Post(s)
Liked: 53
It has been months since I looked at this thread. This might be the thread you ask for (I did not test the link)
http://www.avsforum.com/t/697413/samsung-hls-xx87-xx88-tech-links
--Carl
calentz is offline
post #1716 of 1723 Old 11-27-2012, 10:53 AM
samsungrox's Avatar
Booted hl-s7178w and found no noise :c
and then saw Check fan #2 on screen :c
anyone have stats links to the exact fan
would love to buy one locally if possible today
post #1717 of 1723 Old 11-28-2012, 09:02 AM
samsungrox's Avatar
Fixed fan no 2 ! It is the fan behind the lamp so you need to slide that whole piece out
Soon as I replaced it and hard reset it booted and sounds amazing!
thanks to all
post #1718 of 1723 Old 02-22-2014, 11:39 AM
sigibmw's Avatar
what are the 2 bulbs #'s.....I'd like to replace both of mine
sigibmw is offline
post #1719 of 1723 Old 10-08-2014, 02:22 PM
morbos's Avatar
Wow 8yrs already.
8yrs and still going.
1) Samsung replaced the light tunnel when the glue failed (early in its life 2007?)
2) that repair failed and they replaced the entire lightbox (2007/8?)
3) New lamp end of last year. Reset bulb count: 10k hours
4) Now I see a small black dot in the center. Where there's 1 there's prob 2.
5) In prep I bought a new DLP chip for ~$100.
Samsung #4719-001969 / Ti marking: 1910-6003W
If we deem the display has too many dots, we will do the DMD DLP replacement. Looks pretty straightforwards.
Not too many TV's that you can service these days quite so readily. We are still very satisfied with the TV. Movies look very good to us as LCD just looks a little too crisp and clean and there is something about having a bulb project the image, makes it look more like a movie theater experience to us.
Hope I am not the only one still enjoying the HLS7178!
H.
morbos is offline
post #1720 of 1723 Old 11-22-2014, 08:26 PM
jeo393's Avatar
Hello Morbos,
I too still enjoy my 7178 Sammy! It sounds like you know what you are doing in the repair department. I would love to run a couple of issues by you. If you dont mind assisting me getting to the bottom of these issues. Thank you in advance.
jeo393 is offline
post #1721 of 1723 Old 08-27-2015, 09:05 PM
NFLnut's Avatar
Still loving my HLS7178 although I did have to replace the light engine about 4 years ago and now my light tunnel failed and I had to replace it. Botched up the repair (the light tunnel is a *itch to get out and get back in without breaking a tab .. there is a ridge on the metal block that the DMD board is connected to that makes it difficult) and had to find a used part on eBay which fortunately cleaned up the shadow (except for a maybe 1/8" blue shadow on the top left about a foot long that is hardly noticable but is driving me nuts! .. probably won't fix it though in fear that I may make things worse) .. The picture on this TV is still fantastic and looks much better than even the new 4K LCDs (obviously, running 1080p, not 4K). The screen door effect on LCDs just drives me nuts! Waiting for OLEDs to get bigger and cheaper.
Point of this post: I noticed that the picture is actually too large (is this what they call "overscan?") and I am missing top, bottom, left, right .. maybe about 1/2" to 3/4" all sides (I have a second TV in the room and there is scrolling info and banners that are not in the 7178's picture). Is this a "service menu" adjustment, or is this a mechanical adjustment? I know how to physically manipulate the DMD board to adjust the position, but that is not the problem. The whole picture is slightly too big. Unlike the other Sammy DLPs, there are no "white" horizontal/vertical adjustment knobs on the light engine (at least, that I can find).
NFLnut is offline
post #1722 of 1723 Old 09-14-2015, 08:38 PM
NFLnut's Avatar
Just in case anyone else is still using their -7178 and has the same problem .. I went into the service menu and found that Overscan was set to 'ON." Turned it off (I don't remember this problem before I replaed the light tunnel, so I'm not sure how it got set to ON) and the real estate has returned to close to normal. Comparing it to the other TV in the room, I can see that there is still a little of the picture that I can't fit into the screen, but it is real close now compared to before when tickers and score displays on the top and bottom weren't fitting into the picture. I would still like to know if anyone knows how to tweak it further, but this change helped a lot.
NFLnut is offline
post #1723 of 1723 Old 12-18-2015, 09:10 AM
Jond0's Avatar
Quoted: 203 Post(s)
Liked: 97
Did you try a factory reset? I accidentally did the reset on mine while trying to reset only the lamp timer, and it cleared up issues I've been having for two years!
Jond0 is offline
Reply Rear Projection Units
