Samsung RS232 Port Specifications - AVS Forum | Home Theater Discussions And Reviews
post #1 of 57 Old 07-25-2006, 09:18 PM - Thread Starter
sixdoubleo's Avatar
Does anybody have ANY technical information on the Samsung DLP's RS232 port? Even as far back as the HLN's or hell...even an old Samsung CRT set that had RS232....any Samsung TV ever that has had an RS232 port.
I know the manual states that it is a "service only" port, but I have a hard time believing that. I bet we can send a command to it and make it switch modes and do whatever.
I am a developer and want to write a command line utility for scripting various TV functions (mainly Source/Volume/Mute/Power/Sleep)
A google search of "samsung dlp rs232" produces lots of reviews stating the RS232 is for CONTROL. Not what the manual says though.
Anybody have anything?
Dave
sixdoubleo is offline
post #2 of 57 Old 07-25-2006, 09:25 PM - Thread Starter
sixdoubleo's Avatar
OK, I found this:
http://www.crutchfield.com/S-ZlEgxNV...o&i=305HLR5078
In the little side bar thing that says "What's Included?" right at the bottom, it says:
"Procedures for Controlling a DLP DTV using an RS-232 Connection"
That was just last year's model. Anybody with one of these TV's have this document?
Dave
post #3 of 57 Old 07-25-2006, 09:34 PM - Thread Starter
sixdoubleo's Avatar
Bingo....
Hah...gotta love the Internet. That crutchfield site above had the HLR5078 manual for download. Low and behold in the index was what I need.
I really have a hard time believing that Samsung changed anything on the RS232 port since last year. Wonder why they took it out of this year's manuals.
I'm gonna hook a laptop up and try to query the port. With any luck I should have a utility available for anybody who's interested.
If this works, this will be really cool. I see on the spec sheet that there are commands for setting Contrast, Brightness, film modes, etc. One could easily switch between preferred calibration settings by selecting them on an HTPC menu. Also it could provide a possible workaround for the people wanting a "Set Overscan OFF" macro...etc. I'll report back.
Dave
post #4 of 57 Old 03-10-2007, 12:05 PM
jbInPhx's Avatar
Reviving an old thread to see if anyone's had luck controlling a Samsung DLP via their "service only" RS-232 ports?
Saw an HL-S6167W last week at Sam's Club for $2100, but without RS-232 control beyond "service only", it's out ...
jbInPhx is offline
post #5 of 57 Old 07-28-2008, 05:19 PM
midiman1's Avatar
I made a cable for the 61A750 and wrote a very small PBWin program and was able to control the TV.
The TV end is a 3.5mm stereo plug. The PC end is a female DB-9.
The main sleeve of the 3.5mm plug connects to the DB-9 pin 5.
The small sleeve connects to pin 3.
The tip connects to pin 2.
Communications consist of a 7 byte request to the the TV and a 3 byte response from the TV.
A list came with the TV showing the functions and codes for each. My problem is that some of the functions I wan't are not in the list. Like setting the LED level or controlling the power on light.
If anyone's interested I can provide these but another thread referenced a Crutchfield's manual that has all of them in it.
The reason I started on this quest today was because my TV seems to do a power-on reset occassionaly and the settings I want revert to some default value.
So I used a voltmeter and figured out how to make a cable and wrote a short basic program to set the one's that I could to the values I want. Works great!
I've notified Samsung but haven't received a response. Cycling power also causes the values to revert to the defaults. It doesn't seem to save these values to flash. Hope they respond soon.
midiman1 is offline
post #6 of 57 Old 08-14-2008, 12:41 AM
freddan's Avatar
Hi!
Midiman, could you please send me this application, and if it's ok, include the source code? Thanks
My e-mail is freddan85@gmail.com
thanks!
EDIT: Also, what list of commands do you have? I've attached two .gif pictures with some commands and a "drawing" of how the cable should be pinned
freddan is offline
post #7 of 57 Old 01-24-2009, 02:36 PM
mholgate's Avatar
Quoted: 49 Post(s)
Liked: 46
Help someone!
I've wired my cable correctly and plugged it into to my Samsung Series9 LCD TV (LE46A956) but it's not responding to anything.
I'm trying to communicate to it by sending a few commands as a test using these simple commands in the command prompt:
mode com3:9600,n,8,1
echo v>com3
..but nothing happens!
Do I need to enable the 'Service port' by doing something in the Service menu, or did the port just work with factory settings for you guys?
mholgate is offline
post #8 of 57 Old 05-26-2009, 11:35 PM
usernotfound's Avatar
I know this is an old thread, but is the closest I could find to an active discussion. I have an hl50a650, and have set up the serial communications, as well as hotkeys on my media PC keyboard to trigger the commands.
However, i did all of this on a plane ride, without being able to test on the TV. I get home, everything works, except the TV only spits back 0x03 0x0C 0xFF, which is the 'fail' response. I should be getting 0x03 0x0C 0xF1 if the command succeeded.
I have no idea why following their rs232 spec ( http://akamaipix.crutchfield.com/Man.../30550A650.PDF ) doesn't work...I am clearly communicated between my PC and TV, but the commands aren't working. Has anyone gotten this to work??
Waiting to move to get a TV...
usernotfound is offline
post #9 of 57 Old 05-28-2009, 09:48 PM
grep-v_BS's Avatar
Hi usernotfound,
I have a HL67A750 and have the serial control working. The protocol is exactly the same as the HLxxA650 models. It is possible that your check sum calculation is incorrect. The example in the manual is wrong. The example check sum should be 0x6f not 0x70. Here is a sample C implementation of the check sum.
Code:
#include
int main(int argc, char *argv[])
    int i;
    char cmd[] = "\\x08\\x22\\x0b\\x02\\x00\\x5a";
    unsigned char cs = 0;
    for(i=0;i
Also, don't forget that 0x00 is a valid command byte not a NULL terminator.
Hope this helps.
grep-v_BS is offline
post #10 of 57 Old 10-20-2009, 08:09 AM
Fiasco's Avatar
I have a couple Samsung TV's I want to control w/ RS232.
one is a LN40B550 and the other LN26B360.
I tried downloading the RS232 spec from the crutchfield site but it's either down or no longer available.
Does anyone know an alternate source to get the RS232 specs for the above TV's?
St Louis, MO - Lutron certified
www.jag-es.com
Fiasco is offline
post #11 of 57 Old 10-20-2009, 08:34 AM
Lee Bailey's Avatar
Try this link:
http://akamaipix.crutchfield.com/Man.../30561A750.PDF
This is the user manual at the crutchfield site. Starting at page 116 are the RS232 docs.
Now, can someone supply me with some code for this interface. I too have built the cable, but have been unable to get any responses from the TV, using various terminal software.
Lee Bailey is offline
post #12 of 57 Old 10-20-2009, 08:40 AM
Fiasco's Avatar
From what I've read you can't turn a Samsung on via RS232 which is a no go for me (unless someone has figured it out ).
www.jag-es.com
Fiasco is offline
post #13 of 57 Old 10-20-2009, 11:52 AM
Lee Bailey's Avatar
Well, the docs clearly show there are RS232 commands for it on the A750.
post #14 of 57 Old 10-20-2009, 12:38 PM
Fiasco's Avatar
From everything I've read thus far, when the Sammy goes into power saving mode or power off it shuts down the RS232 port preventing powering on the set over RS232.
www.jag-es.com
Fiasco is offline
post #15 of 57 Old 10-20-2009, 04:04 PM
grep-v_BS's Avatar
Hey Fiasco,
I don't know about the LN40B550 or LN26B360 but I know for a fact that the HL67A750 does turn on via RS232 power on command. I use this feature all the time.
post #16 of 57 Old 11-24-2009, 06:53 PM
ryan_mc's Avatar
id like to control my tv with serial i have a cable but need some kind of software could someone point me in the right direction or share what your using ?
ryan_mc is offline
post #17 of 57 Old 11-24-2009, 08:11 PM
Fiasco's Avatar
I use a combination of a eventghost (free) running on a HTPC and CommandFusion remote interface (CF iViewer $150ish license, can do 1 page flip (2 page remote) for free)(can't give this remote building GUI tool enough props) on my iPhone and GUC232A USB->serial adapters ($12-16 each).
You end up w/ a remote featuring your own artwork, set up exactly the way you want that gives feedback on the state of the various devices under it's control (power state, frequency, channel, listening modes, lighting modes ect)
nirvana....
www.jag-es.com
Fiasco is offline
post #18 of 57 Old 11-25-2009, 06:52 PM
Fiasco's Avatar
Now... how to generate the checksum for the panny in python....
www.jag-es.com
Fiasco is offline
post #19 of 57 Old 11-25-2009, 10:39 PM
ryan_mc's Avatar
do you use the serial plugin for eventghost or how do you do it ? i use eventghost already so that would be perfect but i was unsuccessful using the serial plugin.
ryan_mc is offline
post #20 of 57 Old 11-25-2009, 11:44 PM
Fiasco's Avatar
I write my own plugins.
You can use the Serial thread though.
www.jag-es.com
Fiasco is offline
post #21 of 57 Old 11-26-2009, 11:41 PM
Fiasco's Avatar
I spoke w/ a rep from samsung and he pointed me to this RS232 spec file for 2008-2009 Samsung TV's for RS232 control
Unfortunately there is no mention of the checksum, ack responses ect.
The commands appear to be different then those listed in the DLP manual linked in this thread.
www.jag-es.com
Fiasco is offline
post #22 of 57 Old 11-27-2009, 04:37 PM
ryan_mc's Avatar
Fiasco,
the eventghost plugin you made is working really good with my
hl-61a750 thank you.
Ryan
ryan_mc is offline
post #23 of 57 Old 12-09-2009, 11:42 PM
stbluesrul's Avatar
Has anyone had any luck controlling samsung LCD TV's over rs232?
I have the spec sheet from samsung for the 2008-2009 TV's. However, I'm unable to send any commands to the TV.
stbluesrul is offline
post #24 of 57 Old 12-10-2009, 07:58 AM
Fiasco's Avatar
yup, thats what the last four or five posts in this thread were about.
www.jag-es.com
Fiasco is offline
post #25 of 57 Old 12-17-2009, 01:41 AM
stbluesrul's Avatar
I spoke with Samsung and they stated that the ex-link port can receive RS232 commands by default. So I shouldn't have to change anything in the service menu. I have built my serial to stereo cable correctly but I'm unable to get the TV to respond. I'm just sending a volume up command to see if I can get it working and nothing happens. I'm inputting hex 0x01 0x00 0x00 0x01 into my terminal program and its a no go. Is the there a prefix or suffix I am missing? Because its not listed on the RS232 control codes page. See below:
h**p://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=0&AT_ID=135932&PROD_SUB_ID=0&PROD_ID=41
This is the last device I'm trying to get serial control working on. I already have it going for my Yahama and the DirecTV HR-23.
My Sammy is a LN46A750. Should have gotten a Sharp in hindsight.
post #26 of 57 Old 12-17-2009, 09:54 AM
Fiasco's Avatar
You are missing the checksum and prefix
Here is how I calculate a checksum in python
Code:
def generatechecksum(value):
    data = value.decode("hex")
    sum = 0
    for byte in data:
        sum += ord(byte)
    print "Two's complement:", hex((~sum + 1) & 0xFF)
    data = hex((~sum + 1) & 0xFF)
    data = str(data)[2:]
    if ( len(data) < 2 ):
       data = '0' + data
    print "checksum " + data
    return data
So, for the volume up command (01000100) the checksum is d4 and for the volume dn command (01000200) the checksum is d3. All commands are prefixed with 0822
volume up 082201000100d4
volume dn 082201000200d3
pwr standby 082200000001d5
pwr on 082200000002d4
ect ect
www.jag-es.com
Fiasco is offline
post #27 of 57 Old 12-18-2009, 01:37 AM
stbluesrul's Avatar
Fiasco,
Thank you so much. Finally was able to get the TV to respond. Power On and Off works and so does the volume. However, just one more question. How do I calculate the checksums for the different commands? I don't really have a solid understanding to go about doing that and I'm not much a of a programmer.
post #28 of 57 Old 01-28-2010, 12:04 PM
euclidez's Avatar
Had anyone could turn on the LN40B550 Samsung LCD with rs232 "service port"?
Thanks al lot.
euclidez is offline
post #29 of 57 Old 02-01-2010, 08:41 PM
htpcnoob's Avatar
Just got a new htpc and am discovering how great eventghost is. ryan_mc mentions an eventghost plugin by fiasco for controlling samsung via ex-link rs232, but I don't see a link to it. also, i've got the usb-rs232 cable but not the one that goes into the ex-link mini-plug. Is there a pin-out diagram somewhere? Or do they sell them pre-made online or otherwise?
htpcnoob is offline
post #30 of 57 Old 02-01-2010, 08:55 PM
Fiasco's Avatar
Fiasco is offline
Reply Rear Projection Units
