Official JVC HD-xxFH97 HD-xxFN97 HD-xxFC97 Owners Thread - Page 222 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #6631 of 6642 Old 09-01-2014, 08:04 PM
ChuckF.'s Avatar
Originally Posted by drlava View Post
Hi everyone. I recently picked up a JVC HD-61FN97. After replacing the lamp, the yellow blobs were noticeable, mostly at the top of the picture. After doing some reading, I decided to look closer to see what the trouble was, expecting to find that same damaged filter, but found this (attached):
<pictures clipped>
The filter is perfect, but there is a burn spot and general haziness INSIDE the first PBS cube. This means that the PBS cube, as manufactured, was defective and the failure cause is not dust buildup because there is no way for dust to find its way into the inner optical surface of the PBS cube.
What is there in the BPS cube? the optical adhesive. Is it possible that JVC or the company that manufactured these optical blocks was using contaminated or defective optical adhesive? We know that the most common failure is the waveplate filter (retarder stack filter) at the entrance of the block which repolarizes blue from horizontal to vertical. Each of these filters is composed of several layers which are also attached to each other with optical adhesive. Let's review photos of a fractino of the failures which happen to be posted online:
<pictures clipped>
One thing becomes clear. The burns always begin at the location of highest optical flux, at the center of the input. The burns start over a 1/4" size area which browns first, then burns. The burns don't begin at speckled areas but evenly over a specific area. This is evidence that what is damaging these filters is not dust, but the filter construction and materials themselves, most likely, the optical adhesive failing in the same way it has failed in my PBS.
What this means is that each of these JVC TVs is at risk of burning and potentially fire in the plastic optical block area due to defective assembly, most likely defective or contaminated optical adhesive. This is not a 'natural aging' of the TVs core, but a widespread defect that existed from the moment they rolled off the assembly line. Not every component, as evidenced by these photos and my experience contains defective optical adhesive, but a significant portion of the TVs do. Mine was manufactured October 2006.
What do you think? Should this be enough to get JVC to do something about it?
You said "The filter is perfect, but there is a burn spot and general haziness INSIDE the first PBS cube."
What I have seen is that the haziness is in fact in the RSF. If you remove it by cutting the little blobs of glue top and bottom, I believe you will see that the cube is fine. The seal between the RSF and the cube is poor too, and there can be a layer of dust between the two.
I doubt if JVC will do much about it at such a late date.
These RSF's don't all do this. I don't know why you can take apart these sets of the same age and find that some of them are still fine and some look like they were tortured with a cigarette butt. Environment may have something to do with it, as a dirty piece of optics will absorb more heat than a clean one. There will also be variances in airflow due to component tolerances.
I've replaced mine with a salvaged unit. All JVC D-ILA tv sets use these same RSF's, they are interchangeable even though they might look a little different.
I have slightly modified the copper plenum cover that sits under the optical engine so a little more air blows over the RSF. I have also changed one of the resistors in the set which controls the regulator that feeds the optical engine fan so that the fan blows just a little faster. I won't know if these steps make any difference for a year or two.
ChuckF. is offline
post #6632 of 6642 Old 09-04-2014, 09:26 PM
drlava's Avatar
I know the images don't give 3D vision, so I've taken the filter off so you can see:
The spot and hazing really is in the PBS cube.
Take a close look at your burned filters. If you have any that haven't burned, but browned, look very closely and see if the browning is on the front or back, or instead inside the filter.
If you have a light engine that has a good PBS cube, I'd be interested in replacing the blue-off cube in this set.
bigcat777 likes this.
drlava is offline
post #6633 of 6642 Old 09-05-2014, 09:43 PM
ChuckF.'s Avatar
<clipped pictures>
I've not seen a defect like that in a JVC D-ILA X-cube, but it's certainly possible. I have seen defects in the X-cube in Sony and Hitachi 3-LCD sets that I suspect are partial fractures of one of the glued joints. That manifests as an inability to get one of the colors to sharply focus.
In my FN the bad RSF first showed up in the picture as a faint yellow cloud high-left and a magenta cloud low-right. The filter only looked a little cloudy, nowhere near the charred spot like some of the bad ones in this thread.
I replaced my 61FN RSF with a better RSF from an older 61Z456, a 720p set, which you can do. The rest of the cube though is quite different in the 1080p set. If you want to replace your 52/61/70FN (or FH, FC, FB) X-cube I believe you need to stick with those codes.
One of these days I want to set up a R, G & B source (LEDs) and some polarizing filters and test the marginal RSF's to see what they look like.
ChuckF. is offline
post #6634 of 6642 Old 10-03-2014, 08:13 PM
jedclampit's Avatar
My HD61FH97 set is off to the electronics recyclers tomorrow (10/4/2014) morning, I have four bulbs. If anyone wants parts from it you have a 8 hour window to respond. Will be rolling out @ 7am EST. Bulbs I will still have.
jedclampit is offline
post #6635 of 6642 Old 09-05-2015, 09:27 AM
Liked: 0
Hd-61fn97
If the bulb is bad in these TV's can you still see the menu onscreen?? It tells me its time to change the bulb but i can still see the menu.. Would needing to change the bulb also disable the sound as well? thanks..
Thomas C. Bolton is offline
post #6636 of 6642 Old 09-07-2015, 03:09 PM
drummernrg's Avatar
Quoted: 75 Post(s)
Liked: 91
Thomas, the bulb will slowly become dimmer until it fails: depending on how heavily you use your TV, it could take many months. So, if you can see the menu, your bulb is still working.
The TV has a timer to start warning you to replace the bulb after 6000 hours of use. You will need to reset the timer after bulb replacement.
You can ignore warning until the bulb fails, but I would order a replacement bulb now. I've had poor experiences with after market bulbs failing in less than 100 days, so I recommend going with OEM equipment to get a bulb that will last for years so it may be worth more than twice the cheapest bulb price you find.
You'll also see how much brighter your TV is with a new bulb!
Hope this helps.
drummernrg is offline
post #6637 of 6642 Old 01-10-2016, 06:24 PM
Voller's Avatar
I just found 2 brand new OEM lamps for the HD-56FH97 that I no longer own. I completely forgot that they were in the closet.
Is there still a market for these? I spent a lot of money on them thinking I would need them.
Voller is offline
post #6638 of 6642 Old 01-18-2016, 12:01 PM
VincentFAA's Avatar
I have the 61FN97 model. If your lamps fit my model I will take them off your hands.
sent from my Note 4 using tapatalk
"Leave the gun. Take the cannoli."
VincentFAA is offline
post #6639 of 6642 Old 01-18-2016, 12:40 PM
jedclampit's Avatar
I still have the four bulbs and remote, available too, the remainder is loooooooong gone.
JVC# TS-CL110UAA
post #6640 of 6642 Old 01-20-2016, 06:27 PM
mattbatt's Avatar
JVC# TS-CL110UAA
So are you selling them on ebay or something? Assuming I can get my TV working again I need a new bulb. My current challenge. JVC HD-61FN97 gray screen non responsive
Anyone ever get the Gray screen of Doom? I hit a "test mode" button on my universal remote and now the TV is just gray and only responds to power on/off commands.
mattbatt is offline
post #6641 of 6642 Old 04-16-2016, 08:26 PM
JETninja's Avatar
My 61" is still rocking, use it quite a few times every week when I'm in the Bonus room. Need to take it apart and clean out the dust, its been awhile since I last did it. May replace it with a 2016 4K M Series Vizio 70" sometime, though it may just move into the bedroom. But no blobs or missing colors or any issues so far....
JET
JETninja is offline
post #6642 of 6642 Old 03-21-2017, 10:10 PM
spocko's Avatar
After almost 10 years of ownership and 6500 hours of use, my HD-56FH97 finally started displaying a message that the lamp needed to be replaced. I had an original JVC lamp on hand that I had bought a few years ago, so I just installed it and kept the old lamp as a backup.
The new lamp makes a huge difference! The TV is so much brighter than before and the colors look better. I actually turned the brightness all the way down for now because it's so bright. I should have installed the new lamp sooner, it was very easy to do.
On the downside, my JVC has unfortunately developed the dreaded "yellow blob" issue over the last 2 years. The lower 1/3 of the screen has significant yellow tint, mostly noticeable when showing screens with white or grey in that area. It's really unfortunate that this otherwise great TV has this fatal flaw. It's probably some cheap plastic lens or filter that gets discolored, and kinda ruins the whole set. If only JVC had chosen a different material for that part.
Oh well, I'm not too worked up about it, since this TV got moved to the bonus room a few years ago, primarily for video games. I still feel like it served me well, and was definitely the best option available at the time.
My main TV has been a Panasonic plasma for the last 6 years. I was a bit reluctant to replace the JVC at the time, but am sure glad I did. I love my plasma, and hope it will last until OLED is affordable.
Edit:
I just checked the hours on my plasma (purchased in 2011) and it already has over 6800 hours, and the picture still looks as good a new. Both TVs cost about the same, so the technology definitely did improve.
spocko is offline
Reply Rear Projection Units
