Samsung HLR-6168W Shuts Off - AVS Forum
post #1 of 9 Old 09-10-2006, 08:44 AM - Thread Starter
Ed Weinman's Avatar
In the past three days I've had shut off problems with the Samsung HLR6168W:
- The set shut off while I was watching a DVD (I turned the set back on and it was working).
- Yesterday, the set shut off twice; I turned the set back on after the first...it came back on for about 20 seconds then went off again. I did not turn the set back on until about an hour later and it worked.
Any thoughts would be appreciated.
Thanks, in advance
Ed Weinman is online now
post #2 of 9 Old 09-10-2006, 08:45 AM
rnick1976's Avatar
It sounds to me like an auto-off for overheating ...
rnick1976 is offline
post #3 of 9 Old 09-10-2006, 08:50 AM
Mr. Thompson's Avatar
My HL-S7178 does the same thing. Samsung had me unplug the set and press the power button 10 times to reset it. They are supposed to replace the set although the last time I heard from them they were considering sending out a tech again.
Mr. Thompson is offline
post #4 of 9 Old 09-10-2006, 09:31 AM - Thread Starter
Ed Weinman's Avatar
Is this such a big problem as to result in a set replacement? What did Samsung id as the problem? What was the resetting procedure supposed to accomplish?
post #5 of 9 Old 09-10-2006, 01:44 PM
Samsung believes the problem is the light engine overheating. Since the parts are not available yet they told the tech they would replace the set.
post #6 of 9 Old 09-10-2006, 06:38 PM - Thread Starter
Ed Weinman's Avatar
I watched the front panel LED indicators when the set went out today. It appears that the "stand by/temp" LED remained on while the "lamp" LED was flashing.
I hope that this is ONLY (he said!) a lamp replacement issue.
post #7 of 9 Old 09-12-2006, 10:24 AM - Thread Starter
Ed Weinman's Avatar
I just finished talking to Samsung Service. The technician had me turn on the set, unplug it for 2-3 minutes then replug it (at which point the set came on without my having to push any on buttons).
I believe this was a factory re-start procedure. I was given a transaction no. to refer to in case this should happen again at which time Samsung service could further advise me.
So...hear's hopping!
post #8 of 9 Old 05-14-2007, 12:04 PM
Oktoberfest's Avatar
This same thing started happening to me a couple of months ago. I can turn the set back on after a couple of minutes. Sometimes it stays on and other times it shuts off again. Any resolution to this issue? I'm not sure I need a new lamp. Picture is bright. Sounds like the Lamp is overheating from what I've read, but not sure. Could this be a fan issue? I understand there are 2 fans, 1 easily accessible and, 2 not accessible without removing hardware. Any advice would be appreciated. Thank you.
Oktoberfest is offline
post #9 of 9 Old 05-19-2007, 02:31 PM
Anyone else have problems with their Samsung DLP fans and temperatures? Anyone?
Reply Rear Projection Units
User Tag List
