Official JVC HD-xxFH97 HD-xxFN97 HD-xxFC97 Owners Thread - Settings only - AVS Forum | Home Theater Discussions And Reviews
post #1 of 191 Old 10-31-2006, 11:26 AM - Thread Starter
Plastique's Avatar
I'm looking for suggestions on video settings.
Please post the settings you use for every video mode you use.
Plastique is offline
post #2 of 191 Old 11-01-2006, 11:38 AM
silverfx's Avatar
Quoted: 12 Post(s)
I just got my set last night and would love to know what others are using as well.
HT: JVC RS4910, Carada BW 150", Oppo 103D, Onkyo 876, Polk RT
Panasonic 65ST50, 55ST50, 50PZ85U
silverfx is offline
post #3 of 191 Old 11-01-2006, 12:00 PM
JETninja's Avatar
Me too, mine shows tonight. A central thread for them is a great idea.....
Would love to know if anyone has gone the Pro Cal (Grey Scale, etc) route on one yet also....
JET
JETninja is offline
post #4 of 191 Old 11-01-2006, 02:40 PM
Mosby's Avatar
I would like to know what everyone else is changing in the RGB settings in the service menu. I have only seen 1 post regarding the service menu and the RGB settings. I have not seen any questions or comments of using the Avia setup disc or others as well. I have tweeked the 56fn97 at my work but so far have not had any post to help lean one way or another. Any info would be appreciated
Mosby is offline
post #5 of 191 Old 11-01-2006, 03:40 PM
Al-berta's Avatar
I have a 61FC97 and watch TV in Standard mode with the following settings.
Tint +3
Color +10
Picture -20
Brightness+2
Detail 0
Iris 4
Color temp is low and all other auto settings are off.
I ran Avia on it from my Panny S77 upconverting DVD and got the following settings in Standard
Tint +3
Color +10
Picture -10
Brightness -18
Detail -3
Again I left the Iris at 4 and all the auto settings off. I really found the black levels deep once I adjusted the brightness.
As for the RGB settings in the service menu, I found all the factory settings to be within the 15% guidelines that the Avia test patterns and light filters showed.
I'm pretty happy about it, just wish the TV would remember my settings so I dont have to change it each time when watching a movie or HDTV programming.
Al-berta is offline
post #6 of 191 Old 11-01-2006, 07:11 PM
nicholas's Avatar
Do you have re-apply your settings every time you switch the TV on?
nicholas is offline
post #7 of 191 Old 11-02-2006, 06:37 AM
Al-berta's Avatar
No, they are always saved, but I would like it if HDMI1 which I use for TV had a separate memory of my settings than when I use HDMI2 for DVD. I was told that DVD and TV signals will differ and that is why the pic didnt look too good on TV when I used those Avia settings.
Al-berta is offline
post #8 of 191 Old 11-02-2006, 08:01 AM
Shane D's Avatar
So, you can't save settings to inputs? I have read on the main thread that you can, and that you can't???
Which is it Al? Whenever I get a TV, I want to use one HDMI for STB and the other for DVD. I will only ever use those two inputs.
TIA!
Shane D
Shane D is offline
post #9 of 191 Old 11-02-2006, 09:55 AM
Al-berta's Avatar
TIA!
Shane D
I know. I thought I read somewhere that you can save settings per separate inputs. I'm just too lazy/busy to have figured it out yet. I'll give the manual a read and let you know sometime soon.
Al-berta is offline
post #10 of 191 Old 11-04-2006, 08:53 AM
Z4Dave's Avatar
Ran DVE on my 56FH97 through Component on my Xbox360 (outputs DVDs @ 480P)
My settings in :
Tint 00
Color -02
Picture +18
Brightness-26
Detail -21
Iris +4
Temp Low
off
off
off
auto
off
Worked good with SD Tv through HDMI also
edit: in theater mode
edit#2: 56"
Z4Dave is offline
post #11 of 191 Old 11-04-2006, 12:47 PM
suntzu7708's Avatar
My 56" settings look best at:
Tint -2
Color -8
Picture -7
Brightness -25
Detail -18
Iris +2
Temp Low
off
off
off
auto
off
Wonder why there is so much difference in individual settings.. Maybe personal preferences??
suntzu7708 is offline
post #12 of 191 Old 11-04-2006, 10:58 PM
vagos's Avatar
My settings are in Standard mode:
Tint: 00 to 04 (depending on what is being played. eyeballed)
Colour: 00 to 04 (depending on what is being played. eyeballed)
Picture: -11
Bright: -13
Detail: +10 for HD 00 for SD
iris: -04
colour temp: High
everything else: ON
Again my settings differ from the rest of you, I guess its personal taste. I tried all settings in this thread here but I found my settings more to my personal preference. These settings work very well for HD and SD. I played around a lot to get SD looking really good with these settings.
vagos is offline
post #13 of 191 Old 11-04-2006, 11:12 PM
iove's Avatar
So what is iris in relationship to brightness? Would setting the iris at a lower level affect the overall contrast ration as the dynamic iris is advertised to be the reason why this set at 10K:1 contrast ration?
iove is offline
post #14 of 191 Old 11-05-2006, 05:07 AM
jubess's Avatar
Originally Posted by suntzu7708 View Post
My settings look best at:
Tint -2
Color -8
Picture -7
Brightness -25
Detail -18
Iris +2
Temp Low
off
off
off
auto
off
I'm wondering if settings differ according to the size of your display. a 56" might require different settings vice a 70". I am getting my 70FH97 installed on Friday finally I"ll post my settings shortly thereafter. I think my HT installers are supposed to calibrate my display.
jubess is offline
post #15 of 191 Old 11-05-2006, 02:54 PM
suntzu7708's Avatar
Could be.. Mine were on a 56"
post #16 of 191 Old 11-05-2006, 02:55 PM
suntzu7708's Avatar
note: Please Add Size Of Your Tv When Posting Settings! Just In Case... Thanks!!
post #17 of 191 Old 11-05-2006, 03:33 PM
Z4Dave's Avatar
OK, I put the same settings I have on theater transferred them to standard and it looks different
any one els notice this?
Z4Dave is offline
post #18 of 191 Old 11-05-2006, 09:06 PM
silverfx's Avatar
Quoted: 12 Post(s)
I think Theater Pro mode limits the max light output. This could explain the different picture even with the same user controlled settings.
My settings after Avia on my 61FN97 (Has less than 30hrs on the lamp)
Theater (for DVD viewing in dark):
Tint +01
Color +03
Picture +5
Brightness -06
Detail -07
Iris -04
Temp Low
off
off
off
auto
on
Standard (for HD/SD viewing, eyeballed settings):
Tint +01
Color +03
Picture +2
Brightness -15
Detail -08
Iris -04
Temp Low
off
off
off
auto
on
silverfx is offline
post #19 of 191 Old 11-05-2006, 10:48 PM
Z4Dave's Avatar
Is there a way to check the hours it has been on?
Z4Dave is offline
post #20 of 191 Old 11-06-2006, 06:41 AM
suntzu7708's Avatar
Yup. You gotta enter the service menu:
USE AT YOUR OWN RISK!
1) Hit SLEEP once.
2) Hit VIDEO STATUS + DISPLAY together. You'll see the service menu.
3) Hit the number 2. You'll see another screen with 4 digits at the bottom left: like 0045 or 00A1, etc.
4) It's in Hex, so fire up your Windows calculator, switch it to Scientific mode, choose Hex as input, enter the digits and switch back to the Digital mode. You'll see your total hours in digital. Btw, leave the first few 0's out in Hex (eg: for the above, enter only 45 or A1, etc.).
post #21 of 191 Old 11-06-2006, 07:31 AM
phlydude's Avatar
I have the 56FN and am using these settings:
DYNAMIC PICTURE MODE
Tint=0
Color=-12
Picture=-13
Bright=-12
Detail=-20
Iris=-2
Color Temp Low
Color Management Off
Dynamic Gamma Off
Advanced Smard Picture On
Digital VNR Off
MPEG NR Off
Seems to work pretty good and the set is plenty bright.
~Dennis
PSN ID: phlydude
phlydude is offline
post #22 of 191 Old 11-07-2006, 07:12 AM
Lankness's Avatar
Quoted: 38 Post(s)
Liked: 33
Copied/pasted from the other thread:
After DVE on a 56FN97:
Video Status: Standard
Tint: +3
Color +14
Picture: -8
Bright: -6
Detail: -6
Iris: -4
Color Temp: Low
Color Mgt: Off
Dynamice Gamma: Off
Advanced Smart Picture: Off
Digital VNR: Off
Mpeg NR: Off
This introduced a tinge of yellow dingyness to the whites, so I messed around with the drives in the service menu to restore a true white...
Service menu defaults (on mine):
S001 (Red Drive): 132
S002 (Green Drive): 138
S003 (Blue Drive): 108
Updated drive settings:
S001: 122
S002: 128
S003: 116
I am by no means a professional, and probably not very good at doing this either, but the settings work for me and the PQ is fantastic.
FWIW
Lankness is offline
post #23 of 191 Old 11-07-2006, 08:01 AM
suntzu7708's Avatar
S001: 122
S002: 128
S003: 116
How do you access the RGB section in the service menu, and where are these values noted? Thanks!
EDIT: Forget it. I figured it out. Doh!!!
post #24 of 191 Old 11-07-2006, 10:12 AM
Lankness's Avatar
Quoted: 38 Post(s)
Liked: 33
I found the information in this thread: http://www.avsforum.com/avs-vb/showthread.php?t=598154
There are some attached images that basically give all the information from the service manual and key you in on how to do some of the adjustments.
I take no responsibility for what you or anyone does with that My best advice is to read and decide if you understand it, you can really screw your tv up in there.
Hope that helps.
Lankness is offline
post #25 of 191 Old 11-07-2006, 10:14 AM
suntzu7708's Avatar
post #26 of 191 Old 11-13-2006, 02:42 PM
silverfx's Avatar
Quoted: 12 Post(s)
Anyone else dive into the SM to change RGB settings?
Although the picture looks fantastic on my set (I'm still 'breaking in' the lamp, well under 100hrs), I think it could greatly benefit from a grayscale adjustment.
Standard/Dynamic look a bit cool (blue) and TheaterPro looks a bit too beige...
silverfx is offline
post #27 of 191 Old 11-14-2006, 01:35 PM
silverfx's Avatar
Quoted: 12 Post(s)
Bueller? Bueller?
1300+ posts on the Sony A2000 settings thread and only 26 for this set. I know SONY's a much more popular brand but....
Any FH96 owners want to chime in with their settings?
silverfx is offline
post #28 of 191 Old 11-14-2006, 05:00 PM
Z4Dave's Avatar
Finally got HD the way I like it
on a 56FN97 in standard setting
Tint +03
Color -03
Picture +18
Bright -23
Detail 00
Iris +04
Temp LOW
ColorMan OFF
Dyn Gam OFF
ADV smart Pic OFF
Dig VNR Auto
MPEG NR OFF
Z4Dave is offline
post #29 of 191 Old 11-14-2006, 05:12 PM
eapleitez's Avatar
I still haven't done a disc cal yet, waiting on HD DVE (and now the A2 as well )
_____________________________
eapleitez is offline
post #30 of 191 Old 11-16-2006, 09:37 PM
silverfx's Avatar
Quoted: 12 Post(s)
I worked up the courage to jump into the SM tonight to get rid of the yellow dingyness in Theater Pro. My factory settings were R 132 G 138 B 125. I eyeballed them to R 133 G 130 B 134 and already made a HUGE impact on the picture. I'm going to run my AVIA and work more on the various saturation/hue and color tests tomorrow. I am absolutely convinced that the picture can improve tremendously with a good grayscale calibration. Now I'm really considering getting the Spyder TV Pro.
silverfx is offline
Reply Rear Projection Units
