toshiba dlp fans - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-11-2007, 10:35 AM - Thread Starter
jammer1's Avatar
Hi was wondering if someone can answer this?I understand the fan runs after you shut the tv off for a few mins to cool the lamp but there is another fan that runs all the time.What is it cooling and what does it run all the time?Thanks
jammer1 is offline
post #2 of 5 Old 01-11-2007, 01:10 PM
garciab's Avatar
Quoted: 156 Post(s)
Liked: 71
It is speculated that the constant running fan is cooling the circuitry for the cablecard slot. Yes, even if you don't have a cablecard installed
bg
garciab is online now
post #3 of 5 Old 01-11-2007, 09:01 PM
magredc5's Avatar
There's a low fan always on to cool the tuner and CableCard module since they're always powered on even when the TV is OFF. If you use a CableCard the module is always powered in order to remain authenticated with the network, and if you use TVGOS the tuner and processor is always powered in order to download listing data.
Toshiba 62MX195 1080p DLP w/ Cablecard
Comcast Cable of New England
magredc5 is offline
post #4 of 5 Old 01-12-2007, 11:05 AM - Thread Starter
jammer1's Avatar
ok thanks for the info
jammer1 is offline
post #5 of 5 Old 03-28-2014, 05:26 PM
smiley1965's Avatar
 I have a fan on my DLP Toshiba that runs all the time also,even after the tv has been off for hours, I can hear it
smiley1965 is offline
Reply Rear Projection Units
