Hitachi 51/57/65F59A CRT RPTV Tweaks Thread - Page 162 - AVS Forum | Home Theater Discussions And Reviews
post #4831 of 4855 Old 11-30-2014, 06:06 AM
VivatHD's Avatar
Something better than Spray Way for lens cleaning?
Cleaned the lenses on my 51F59A the other day. Been about 18 months since last cleaning and they weren't as dusty as expected, however I still had smudging problems using Spray Way (blue and white can). Last time similar smudging tendency using my trusty can of Spray Way but this time was worse. Is there anything that is more smudge and streak free than Spray Way but also safe for the coating on our lenses?
Here's how I go about it:
1. Lint free paper towels
2. Spray Way plastics-safe foaming glass cleaner (ammonia-free)
3. Lens cleaning cloth for poly lenses obtained from Optical shop where prescription eyeglasses are sold
I spray the lens and let the foam sit for a minute or so and dissolve down, then I blot it up gently with the lint free paper towels, taking care to blot up and down and no sliding motions yet, turning the lint free paper towel as needed to absorb up most of the cleaner. I then spray it again and let it sit for a few moments, repeat blotting with fresh lint-free. 3rd spray and this time with gentle wiping motion. 4th spray a sparing amount and let sit briefly then use the eyeglasses lens cloth to gently wipe off the lens. Examine under led flashlight lighting for smudged areas. Quite a few actually. Keep repeating with light spray and eyeglass lens cloth until smudge-free.
Just looking for a cleaning fluid that might be less smudge prone.
I didn't have the upper section (mirror assembly) off this time. Last time I did, and the trick I used to clear up any remaining smudges was instead of spraying lightly with the Spray Way I would get up close and exhale on it to form condensate on the lens surface, then quickly and gently wipe with the eyeglass lens cloth. That cleaned up smudges very effectively. When I say smudges I am referring to small streaks on random areas of the lens that are only visible under illumination from a small flashlight-- in my case a small LED flashlight. Under room lighting the lens will look shiny and clean but put the flashlight on and some smudges are visible and removing those is the "final touch" to cleaning, for me. This time I did not remove the mirror assembly just the back panel and obviously I could not get my bucket head in there to put breath condensate onto the lenses for final touch-up and had to rely on Spray Way instead, which seemed to keep replicating tiny smudges over and over.
The good news is that I did finally get each lens smudge free, it just was more tedious then any time before. Picture is crisp and vibrant again. Like.
P.S. No smokers in the house.
VivatHD is offline
post #4832 of 4855 Old 11-30-2014, 06:21 AM
VivatHD's Avatar
Along the same lines as above, has anyone used Pec Pads for cleaning the lenses in the 51F series and did they work well?
VivatHD is offline
post #4833 of 4855 Old 11-30-2014, 01:50 PM
Mr Bob's Avatar
Quoted: 170 Post(s)
Liked: 105
My technique is slightly different. I use paper towels because the combination of absorbancy and evaporation of the light mist trail can be used to my advantage in not winding up with dried residue afterwards. To your credit you didn't even MENTION micro fibre cloths, which have no absorbency at all! Good show on that.
I never rub back and forth on the lenses AT ALL. Any smudges you can't get out have to be suspected of being scuffs now, which are simply thousands of tiny scratches at a time. And just as impossible to remove once indelibly forced into the soft plastic. If they will not go away with repeated attention, I am afraid that's what you have there. Luckily, everything is out of focus at that part of the light path and if the scuffs are not too big they will remain unnoticeable. But if your cleaning methods caused them, more will appear in the future with the same cleaning methods, and eventually they will be visible in your content. If you actually got them out I congratulate you. If they were scuffs rather than smudges they would not come out at all. You have to be careful of repeated applications of any cleaning method, tho. The natural urge is to grind away harder when smudges won't come out, which is the worst thing you can do.
I use one swipe/third of the lens after my 15 seconds of allowing the liquid to suspend the gritty particulates in there, being sure to LIFT ahead of me on the paper towels so as to lift any gritty particulates OFF the plastic rather than grinding it in. I never blot anything. And I never use eyeglass equipment for cleaning lenses that are subjected to endless static cling by the high voltage, drawing any and all airborne contaminants out of the air and onto the lenses, winding up being glopped onto and dried onto those lens surfaces, after years of non-cleaning. Eyeglass cleaning equipment is not designed for that.
Other than those things I congratulate you on your cleaning technique. If it did not do any damage to your optical surfaces, you have done it right.
But you have to have a method you can use once a year for the life of your set, over and over and over again, and once every few years on the internal optics that you have to remove the lens barrels to get to. If there is an air gap between the lens barrels and the CRT coolant covers and you have not cleaned the surfaces under that - 2 surfaces per gun - then only 4 of the 10 surfaces that get dirty in there have been cleaned so far and your job is less than half done. Which will show in your viewing, as to the inky transparency of your blacks and the faithfulness of your shadow detail being questionable. If your light path has not been restored to crystal clarity again, there will always be some level of bleariness in your viewing when the blacks are supposed to be being inky, transparent jet black, with no glow around any bright spot or area in the content. If any of those 10 surfaces that get dirty - of the 28 in there - are still not clean there will be bleariness, and a glow around bright objects when against a background of black. Worst offender will be the doughnut hole - black in the center with bright content in a circle all around it. What's in the black center will not have the proper shadow detail if the optics are still dirty. All you will see is messiness.
When I do optics cleanings, the set returns to brand new status on the sparklingness of the internal projection light path. It's like getting a brand new set, with blazing dynamic punch. If anything has been left out, it just does not look like new again. Not yet.
If anyone wants me to be there for them on the phone when they do it at their own location to make sure they stay on the straight and narrow and avoid potentially permanent-damage land mines, I often spend an entire Saturday morning coaching owners on this and other things about their CRT RPTVs.
I invite all readers of this thread to enjoy the thread I started in 2006 entitled "Don't Dump Your CRT RPTV!" It has had more than a million views and is still going strong. It is for anyone who is clued in to how amazing these sets are and always have been.
http://www.avsforum.com/forum/showth...1#post29417241
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
bob at imageperfection dot com
www.projectiontvtroubleshootingadvice.com
YouTube channel: mrbobbigscreen
Mr Bob is offline
post #4834 of 4855 Old 12-01-2014, 04:39 AM
VivatHD's Avatar
I've never had the barrels off. I'm in fear of such an operation, as I think upon re-install they might be micro displaced from where they were originally and thus change focus point on the mirror and throw convergence way off?
VivatHD is offline
post #4835 of 4855 Old 12-01-2014, 08:23 AM
Mr Bob's Avatar
Quoted: 170 Post(s)
Liked: 105
Your fears are not misplaced. When you put the lens barrels back on, they never go back EXACTLY where they were before, even when you make sure that they are all oriented exactly the same direction as before in terms of the clockwise/counterclockwise nature of where each lens barrel goes back in place. They all need to be oriented exactly as they were before - with the focusing wingnut shafts facing exactly the direction each was facing before. And of course don't untighten those wingnuts unless you intend to change the focus.
However what gets changed when you put the lenses back on is really only at the crosshairs. The rest of the convergence falls back into place, generally speaking, once the crosshairs are re-aligned. And micro differences MAY appear in the convergence, but not noticeably so, at least to my experience. But then I usually do a reconvergence after a cleaning anyway.
After a year it's good to redo the convergence anyway, so if you want to do that, be sure and do the cleaning first, then the re-convergence. Micro differences may appear when you put each lens barrel back on - always do that op 1 by 1 so you CAN'T get those lens barrels mixed up, each one's optical focus is tightly matched to its color - but you'll clean those up with the re-convergence.
If your set has that air gap, doing the lenses under the lenses is absolutely essential to regaining all your dynamic punch back again, like when she was new, so don't leave out that step. I have tests for whether your set actually needs to have the deeper optics cleaned, which I will be glad to share with you if you happen to sign up for a coaching hour with me.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #4836 of 4855 Old 12-01-2014, 08:34 AM
Mr Bob's Avatar
Quoted: 170 Post(s)
Liked: 105
Originally Posted by Aafter View Post
I have a 51F59A TV and the screen has a pink tint to it including the OSD.
Gimme some hot tips.
Edit: Got it. Turned the green pot. Things are swell!
Those pots establish a very delicate balance, they realign where the centerpoint is of the cutoffs in the grayscale registers. So be sure your b/w has been returned to the color of a thick cloudy overcast sky.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #4837 of 4855 Old 01-26-2015, 03:08 PM
Liked: 0
Screen Size Adjustment
Hello - looking for a little helping adjusting the screen dimension on my 65F59A. When playing the Playstation (using the HDMI input) much of the screen has shifted over the years. Seems mostly to be widened horizontally. I did a search within the thread but couldn't come up with a consistent answer. Sorry, my technical skills are limited. Would anyone care to send along some advice? Thanks in advance for your patience.
gwalton371 is offline
post #4838 of 4855 Old 01-26-2015, 08:53 PM
LastButNotLeast's Avatar
Quoted: 1779 Post(s)
Liked: 1396
Small pots inside on the front left labeled H and V are your horizontal and vertical size adjusters. Display a circle from any calibration disc and SLOWLY adjust the H (assuming your guess is correct) until the circle is round, or reduce them both slightly to make the circle smaller. If you do too much, though, it will throw off the convergence.
And welcome to the forum.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #4839 of 4855 Old 01-26-2015, 11:49 PM
Mr Bob's Avatar
Quoted: 170 Post(s)
Liked: 105
Yes, and if you don't have a test disc you can use most of the OTA station logos, the full size ones that cover the screen at commercials, not the little ones down in the corners. CBS and ABC both use big circles, which would be perfect. If you have a DVR you can freeze that logo up there for the duration of your adjustments. Or if you have a picture of the moon or some other big circle, that will work too.
There won't be any screenburn for the short amount of time you'll need it up there.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #4840 of 4855 Old 01-27-2015, 05:04 PM
Liked: 0
Thank you both so much! I'll get it done before the big game. TV is 7 years and still going strong.
post #4841 of 4855 Old 01-27-2015, 05:06 PM
Liked: 0
Are those H and V pots under a panel in the front.... Or do I need to go in from the back?
post #4842 of 4855 Old 01-27-2015, 07:01 PM
Liked: 1396
In the front. You just need to pull off the bottom panel. They're little, so you may need a flashlight and magnifying glass to find them, but they're there.
post #4843 of 4855 Old 01-27-2015, 11:15 PM
Mr Bob's Avatar
Quoted: 170 Post(s)
Liked: 105
Find the circuit board that is floor-mounted under the guns, it is usually toward the back half of the unit. Near the front border of the floor mounted boards, the 2 pots will be sticking up off the circuit board and their screwdriver slots will be facing you as you are looking in from the front. They are side by side. maybe half an inch apart. A small screwdriver like you would use for your eyeglasses is all you'll need, and you won't need to turn either of them much.
Be sure to mark EXACTLY where they are currently set when you go in, so you can get them back there if you need to later. Make a mark with a Sharpie that hits both the moving and the non-moving parts of each pot before moving either one out of position.
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #4844 of 4855 Old 01-28-2015, 05:13 AM
Liked: 0
b
Thanks again for the info. Seems I'm getting two conflicting instructions. Are the pots in the front panel or rear body unit? I've looked in both (particularly with Bob's instructions) but can't spot them in either.
ID:	507562   Click image for larger version
post #4845 of 4855 Old 01-28-2015, 08:08 AM
Liked: 1396
You're working too hard. From the front of the set, remove the grill covering the speakers. They're along the front edge, to the left of center.
post #4846 of 4855 Old 01-28-2015, 08:41 AM
Liked: 0
I'm all for making the job easier! I keep looking as close as my 44 year old eyes can and not spotting your description on the map. Here's another pic of the front. SO appreciative of your patience.
post #4847 of 4855 Old 01-28-2015, 08:51 AM
Liked: 1396
That wooden panel with six screws needs to be removed. I forgot all about that, since I just left mine off.
Yes, I spent way too much time poking around in there.
But you're getting close!
Michael
post #4848 of 4855 Old 01-28-2015, 09:07 AM
Liked: 0
Michael
Finally spotted the buggers. Thank you both for the instructions. I'll gingerly make the attempt to adjust them tonight. Many thanks!
post #4849 of 4855 Old 01-28-2015, 10:22 AM
Mr Bob's Avatar
Quoted: 170 Post(s)
Liked: 105
Keep in mind that whenever you change the sizing, you change the efficacy of the geometry and convergence of all 3 images. That's why you will want to mark EXACTLY where those pots were before you turn either of them. When you see how contorted your pic gets, you may want to put them back where they were and abandon the idea.
If you do want to press forward, just know that you may be in for a roller coaster ride, in getting the pic coherent again. Michael and I love doing all that, we thrive on getting it the best it can be, whatever it takes. But we are nothing if not foolishly dedicated to these incredible sets! Michael knows what I am talking about...
b
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
post #4850 of 4855 Old 01-28-2015, 11:05 AM
Liked: 1396
Move them (or, preferably, just it) very, very little at a time.
Good luck.
post #4851 of 4855 Old 01-28-2015, 01:14 PM
Liked: 0
b
Made the adjustments with both of your help. You're right, I notice a slight bending of the image on the corners now. But it's very slight, and I practiced moving back to ground zero again. It's an improvement over that constant loss of graphics. Think I can live with it just fine. Plus I learned a whole lot!
post #4852 of 4855 Old 01-28-2015, 01:40 PM
Liked: 1396
If you know or are willing to learn how to redo the convergence, you can fix that (relatively) easily.
I don't know if Magic Focus will help in this case - never used it, myself.
Glad the operation was a success.
Michael
post #4853 of 4855 Old 01-29-2015, 06:52 AM
Liked: 0
Michael
I'm sure this is all old news at post #4853 in the thread, but, yes, I did play around with the 117-point convergence tool. Still see some red/blue ghosting on text in the far corners I can't seem to get rid of. But overall quite nice.
post #4854 of 4855 Old 01-29-2015, 07:57 AM
Liked: 1396
post #4855 of 4855 Old 01-30-2015, 09:48 AM
Mr Bob's Avatar
Quoted: 170 Post(s)
Liked: 105
Robert Jones
Image Perfection
510-278-4247
650-333-4808 cell
Mr Bob is offline
Reply Rear Projection Units
Hitachi
