Question About DVD Player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-22-2007, 11:27 AM - Thread Starter
bradoneill's Avatar
Im not sure if this is the correct place but here we go.
Ok I have a Sony E2000 RPTV and the native resolution is 720p. I also have a Panasonic Progressive Scan DVD player (not sure which model as I am at work) and an Xbox 360 that I am currently using to play my DVD's.
Im just wondering what I should use to get better PQ. I thought that the 360 was upconverting but apparently that is only trough VGA and my TV does not have a VGA port. So do you guys think that the DVD player or the 360 would be better?
bradoneill is offline
post #2 of 2 Old 01-22-2007, 11:45 AM
BillP's Avatar
Quoted: 261 Post(s)
Liked: 202
Compare them and see which looks best to you with your equipment. You may want to consider an upscaling player like the Oppo (or the Tosh HD-DVD player or Xbox add-on).
BillP is offline
Reply Rear Projection Units
